Old 09-24-2012, 05:12 AM   #1
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
OBD2 Bluetooth Adapter
Which one do you guys use?
I wanna get TORQUE on my tablet so i can read error codes etc when they come up.
Saw [ame="http://www.amazon.com/Soliport-Bluetooth-OBDII-Diagnostic-Scanner/product-reviews/B004KL0I9I/ref=dp_top_cm_cr_acr_txt?ie=UTF8&showViewpoints=1"]this bluetooth adapter for $15 on amazon[/ame] and wanted to see if anyone is using it, and/or if there is another unit they'd recommend.
I already tried searching and read through a bunch of posts but couldn't find what i was looking for.
I'd love to know what you guys are using, as i want to get a low cost solution for clearing/diagnosing error codes.
Thanks in advance!
Ravenlokk is offline   Reply With Quote
The Following User Says Thank You to Ravenlokk For This Useful Post:
calis5nest (01-24-2014)
Old 09-24-2012, 05:32 AM   #2
serialk11r
Drives: '06 AM V8V Coupe
I got an 11 dollar one off Ebay.
It certainly does work, but the response is pretty slow and the refresh rate is like 2hz or so, which is kinda pathetic.
Old 09-24-2012, 06:48 AM   #3
d1ck
Drives: Black 2013 FRS
I've got an ebay one as well. I hear the non-knock offs are much better for refresh rate though so I'd recommend getting one of the real ones.
d1ck is offline   Reply With Quote
Old 09-24-2012, 06:52 AM   #4
RJ_
RJ_'s Avatar
I got the kiwi BT one. It costs more but it works and the refresh seems quick.
RJ_ is offline   Reply With Quote
Old 09-24-2012, 08:00 AM   #5
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Any of you guys using Android ? I've been thinking of getting the OBDII also
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 09-24-2012, 08:06 AM   #6
2forme
I have an ELM327 bluetooth OBD2 adapter. Works flawlessly.
Old 09-24-2012, 08:29 AM   #7
Foobar
SLO NO MO
Foobar's Avatar
ELM327 here, running Torque on Android. I've had it for a couple of years now and used it on several cars and Android devices without a problem. Picked it up on eBay for 25 bucks, but I see they sell for less than 10 bucks these days.
Old 09-24-2012, 10:38 AM   #8
Saw this bluetooth adapter for $15 on amazon and wanted to see if anyone is using it, and/or if there is another unit they'd recommend.
Here you go, with photos from my Owner's Journal. Works with my gTablet, and my Droid X.
Old 09-24-2012, 10:41 AM   #9
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
I have the vgate 1.5 and it works great. Im able to use faster communication and it seems faster than my old school elm327
brichard0625 is offline   Reply With Quote
Old 09-24-2012, 10:51 AM   #10
brichard0625
Are u able to use faster communications without error message? i had the same one and it wuddnt read unless it was phone
Old 09-24-2012, 11:12 AM   #11
Yruyur
Yruyur's Avatar
Do a search on eBay for elm327 super mini. it's the one in this pic. About the quarter if the size if the original elm. Does not hang below the dash when plugged in. 15 $ shipped on eBay
The Following User Says Thank You to Yruyur For This Useful Post:
Dadhawk (09-24-2012)
Old 09-24-2012, 11:14 AM   #12
Yruyur
Yruyur's Avatar
It's 1.5 as well
The Following 2 Users Say Thank You to Yruyur For This Useful Post:
calis5nest (01-24-2014), Dadhawk (09-24-2012)
Old 09-24-2012, 11:18 AM   #13
BlueLeader
Drives: Ultramarine Blue Scion FRS
Elm327 hands down. Easy bluetooth connectivity to torque pn thunderbolt. Handy when u want live readings on your car. Cheap and does the job.
Sent from my ADR6400L using Tapatalk 2
BlueLeader is offline   Reply With Quote
Old 09-24-2012, 11:19 AM   #14
b.e
Drives: 2013 FR-S Hot Lava, 2007 Tundra
I used an ELM327 bluetooth adapter for a while (with Torque Pro on Android), then once, near a power plant, the FRS threw a CEL code indicating the network CPU lost contact with the display CPU and the car went into "limp home" mode. Probably a poor ground on the adapter unit let some radio frequencies into the car network. I don't drive with it always in anymore, just when I need it.
b.e is offline   Reply With Quote
The Following 2 Users Say Thank You to b.e For This Useful Post:
calis5nest (01-24-2014), whataboutbob (01-01-2013)
Antenna Adapter Alternatives solution Electronics | Audio | NAV | Infotainment 20 08-24-2020 10:52 AM
OBD2 Port RJ_ AUSTRALIA 33 08-25-2016 10:25 PM
Bluetooth/Nav inimitable Electronics | Audio | NAV | Infotainment 40 09-26-2012 08:35 PM
FRS bluetooth set up jym89709 Electronics | Audio | NAV | Infotainment 16 09-08-2012 03:04 PM
