#15 |
Drives: Limited WRB AT6 BRZ
#16 |
Functionally Retarded
Drives: LinkECU V6 MR2 - MKVII Golf R
If you want the car level.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
![]() I'm not really an asshole, but I play one on the internet. |
#17 |
Drives: '13 Ultramarine
#18 |
#19 |
Drives: 2013 BRZ Limited
How about just ramps on the front to change the front pipe? Would this be possible?
#20 | |
Reverse Burnouts
Drives: 2013 Argento FRS
to make the install easier buy new rubber hangers and just cut the old ones off so you arent wrestling the car back and fourth just to get the oem rubber hangers off, rubber hangers dont cost much and will make the process about 5--20 minutes faster depending on your skill level and there is 0 hassle when tightening the exhaust up, align all sections of the cat back up first with a little bit of play but all the hangers in place and bolts in the correct holes slowly tighten each bolt a little bit until you find resistance on each bolt in the whole exhaust system, then continue to tighten them down to spec , this is to ensure your exhaust tips align correctly with the bumper cut outs for the exhaust tips ohh yeah and let the car cool off before instal, like mentioned above a hot exhaust pipe smack against the face is NOT a pleasant feeling, kinda like hot oil in the face and dont forget the gaskets
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#21 |
Drives: 2013 Raven FR-S
S/Be pretty easy just roll the car onto the ramps, turn it off and leave it in reverse. (Assuming you're on flat ground, its more likely the car will roll foward off the ramp) also CHOCK YOUR WHEELS. scrap 2x4 is great for that if you dont have real wheel chocks.
#22 |
I do this too. I'm paranoid, but anytime I'm under a car I imagine the worst and so I use the ramps and the jack stands.
#23 | |
Drives: Scion FR-S
#24 |
Drives: 2013 WRB 6MT BRZ Ltd.
Just did mine last night (starting at about 1am). It was my first time doing anything exhaust related, and it really wasn't that bad. There are some annoyingly tight screws that feel somewhat rusted, and my single largest issue was using a crappy jack that only gets up about 13" or so and was too high profile to get started. I had to use the jack in the trunk to get it lifted on the side high enough to get the hydraulic jack under the front jack point. Once that was done, I was able to get jackstands under each point, though they were quite low.
With a jack, 4 jackstands, and GrimmSpeed's Exhaust Removal Guide detailing which tools I'd need, I was able to do everything. I actually wound up using a boxwrench half of the time instead of the ratchet, as there are a lot of tight places. One huge piece of advise I can give you: using WD-40 makes a LOT of the job a ton easier. I can't tell you how long I was tugging on the exhaust hangers before applying WD-40, waiting a minute or two, and then easily sliding them off with my thumb. |
#25 | |
#26 | |
form follows function
Drives: RIP '13 BRZ
#27 | |
#28 | |
I also use 4 jack stands. Use the front central jack point, set up two stands under the side jack points. Move to the rear, repeat. If you need the car higher, see-saw it up, (jack the front up a few inches, raise the stands, do the rear, raise the stands, repeat). As mentioned, be careful if you're really yanking on a wrench or exhaust hangar, the last thing you want is to tip the car off it's stands... A muffler in the face is nothing compared to an entire car trying to occupy the same space as your chest. |
| Milltek Exhaust system | drifter | Engine, Exhaust, Transmission | 255 | 01-04-2016 04:58 AM |
| Exhaust System/Exhaust Manifold Removal and Replacement | GrimmSpeed | DIY (Do-It-Yourself) Guides | 52 | 11-11-2015 09:30 PM |
| TRD Exhaust System... | Griffdawg | Engine, Exhaust, Transmission | 2 | 07-18-2012 12:27 AM |
| Home Sweet Home, it made it today. Delivery party 5/11 though.. | MarkRacerX | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 05-14-2012 03:24 PM |
