Old 09-21-2012, 08:29 AM   #15
kwood9000
kwood9000's Avatar
Drives: Limited WRB AT6 BRZ
Originally Posted by ModBargains View Post
When I change out exhaust systems at home, I use a rhino ramps to get the car lifted in the front, jack up the rear, and put 4 jack stands on all 4 corners of the chassis.
Do you need jacks in the front if you use ramps?
kwood9000 is offline   Reply With Quote
Old 09-21-2012, 08:45 AM   #16
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
If you want the car level.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 09-21-2012, 08:50 AM   #17
roddy
roddy's Avatar
Drives: '13 Ultramarine
Originally Posted by Foobar View Post
Can you disassemble the stock cat-back down to small enough parts to fit in the trunk (with seats down if necessary) without breaking anything?
Yes. The mid-pipe bolts to the muffler just aft of the suspension and drive axle.
Old 09-21-2012, 09:50 AM   #18
j.t.
No its not necessary. There is enough room to work with the rear on ramps alone. It is tight, but not that bad.
j.t. is offline   Reply With Quote
Old 09-22-2012, 03:23 AM   #19
Innova
Drives: 2013 BRZ Limited
How about just ramps on the front to change the front pipe? Would this be possible?
Innova is offline   Reply With Quote
Old 09-22-2012, 05:04 AM   #20
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
or you can just lift 1 side of the car put jacks stand on that one side pull the ebrake and your car shouldnt move, i would refrain from just jacking up the back because the front wheels are free to move and the car might roll forward
to make the install easier buy new rubber hangers and just cut the old ones off so you arent wrestling the car back and fourth just to get the oem rubber hangers off, rubber hangers dont cost much and will make the process about 5--20 minutes faster depending on your skill level and there is 0 hassle
when tightening the exhaust up, align all sections of the cat back up first with a little bit of play but all the hangers in place and bolts in the correct holes
slowly tighten each bolt a little bit until you find resistance on each bolt in the whole exhaust system, then continue to tighten them down to spec , this is to ensure your exhaust tips align correctly with the bumper cut outs for the exhaust tips
ohh yeah and let the car cool off before instal, like mentioned above a hot exhaust pipe smack against the face is NOT a pleasant feeling, kinda like hot oil in the face
and dont forget the gaskets
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
The Following 3 Users Say Thank You to carbonBLUE For This Useful Post:
Innova (09-22-2012), kwood9000 (09-22-2012), wheelhaus (09-24-2012)
Old 09-22-2012, 05:12 AM   #21
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
S/Be pretty easy just roll the car onto the ramps, turn it off and leave it in reverse. (Assuming you're on flat ground, its more likely the car will roll foward off the ramp) also CHOCK YOUR WHEELS. scrap 2x4 is great for that if you dont have real wheel chocks.
Ravenlokk is offline   Reply With Quote
Old 09-22-2012, 09:05 AM   #22
Captain Insano
I do this too. I'm paranoid, but anytime I'm under a car I imagine the worst and so I use the ramps and the jack stands.
Captain Insano is offline   Reply With Quote
Old 09-22-2012, 10:39 AM   #23
travace
travace's Avatar
Drives: Scion FR-S
Originally Posted by ModBargains.com View Post
You can do it yourself, but be careful of course, you'll want to make sure that you jack up the car with a floor jack of course, but to put jackstands on all four corners. If you do it at home and your driveway is any bit at an angle towards the street, not completely flat, I'd maybe reconsider doing it at home. As long as you get four jackstands on there, good jackstands might I add, it's not that bad of an install. Of course you'll want the car high enough where the car isn't in your face, you'll need room to access everything properly.
slanted driveway's suck so bad. mine is slanted and it limits what it is that i can do with ANYTHING. wish i would have had the knowledge when i was younger and got this house.
travace is offline   Reply With Quote
Old 09-23-2012, 06:37 PM   #24
Smudgeous
Smudgeous's Avatar
Drives: 2013 WRB 6MT BRZ Ltd.
Just did mine last night (starting at about 1am). It was my first time doing anything exhaust related, and it really wasn't that bad. There are some annoyingly tight screws that feel somewhat rusted, and my single largest issue was using a crappy jack that only gets up about 13" or so and was too high profile to get started. I had to use the jack in the trunk to get it lifted on the side high enough to get the hydraulic jack under the front jack point. Once that was done, I was able to get jackstands under each point, though they were quite low.
With a jack, 4 jackstands, and GrimmSpeed's Exhaust Removal Guide detailing which tools I'd need, I was able to do everything. I actually wound up using a boxwrench half of the time instead of the ratchet, as there are a lot of tight places. One huge piece of advise I can give you: using WD-40 makes a LOT of the job a ton easier. I can't tell you how long I was tugging on the exhaust hangers before applying WD-40, waiting a minute or two, and then easily sliding them off with my thumb.
Smudgeous is offline   Reply With Quote
Old 09-23-2012, 07:36 PM   #25
Captain Insano
You can drive up onto a couple 2x4 or like boards. I actually (believe it or not) have several thick text books and if a vehicle is too low to get my jack under the side I drive the front or rear wheels or both (whichver side I'm jacking) onto the books and then that creates 2-3 additional inches it sits up in the air. Put it in gear/park, lock parking brake, jack up. I've actually made steps of books for a really low vehicle once to get it high enough to start jacking. Haha. I know it's hillbilly, but it is safe and works faster than getting that little jack out (which I wouldn't trust anyway). Then you can just start with your normal jack versus using two jacks (low and high).... ;-)
Old 09-24-2012, 01:55 AM   #26
Mitch
form follows function
Drives: RIP '13 BRZ
I'll have to make a build thread soon. I used planks of wood and old text books (calculus and automotive engineering) to get the car elevated, then put my jack on planks to lift the car up so it'd be high enough for my jack stands.
Mitch is offline   Reply With Quote
Old 09-24-2012, 02:29 AM   #27
Ravenlokk
Ravenlokk's Avatar
And they say taking calculus has no every day applications.
Old 09-24-2012, 02:51 AM   #28
wheelhaus
wheelhaus's Avatar
Originally Posted by Pudge Ate Me View Post
What do you mean remember the gaskets? And I always do my own maitinence on my cars and motorcycle just never replaced an exhaust system before. Any good jackstand recomendations? And should I use the 4 corners of the car or the 2 mid points front and rear?
If you're not joking... The gaskets are little thin pads that get squished between the flanges of the exhaust as it bolts together. They create a high heat seal that prevents leaks. (same idea as head gaskets, valve cover gaskets, etc). Slip joints for example, do not need a gasket because one tube wraps around the other and is then tightened down.
I also use 4 jack stands. Use the front central jack point, set up two stands under the side jack points. Move to the rear, repeat. If you need the car higher, see-saw it up, (jack the front up a few inches, raise the stands, do the rear, raise the stands, repeat). As mentioned, be careful if you're really yanking on a wrench or exhaust hangar, the last thing you want is to tip the car off it's stands... A muffler in the face is nothing compared to an entire car trying to occupy the same space as your chest.
Milltek Exhaust system drifter Engine, Exhaust, Transmission 255 01-04-2016 04:58 AM
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 09:30 PM
TRD Exhaust System... Griffdawg Engine, Exhaust, Transmission 2 07-18-2012 12:27 AM
