Old 09-14-2012, 09:33 PM   #15
_F-R-S_
Drives: 13 whiteout scion frs
i just bought that cusco front sway for a bit more stiffness...works wonders..
_F-R-S_ is offline   Reply With Quote
Old 09-15-2012, 12:35 AM   #16
ESC POD
ESC POD's Avatar
Drives: Sterling Silver BRZ
Installed a 16mm WRX rear sway tonight...paid $40 in excellent condition, bolted right in...Test drove it, with the Nannies on, no worries or changes. With the Nannies Off...A little more tail happy, but Not Dangerous. The car is still very predictable...
I say Win. Anything larger than a 16mm would most likely be overkill without further upgrades throughout the suspension...In my opinion.
Activating: ESC POD...let's Drive!!
ESC POD is offline   Reply With Quote
Old 09-15-2012, 12:53 AM   #17
fatoni
Originally Posted by ngabdala View Post
I want better handling. I love kicking the rear out with the stock setup. I thought this would make things more fun for me. Also, a big concern is when I buy stickier tires and slightly larger wheels because I fear losing that and I watched the Rallysportdirect video about how the sway bars brought the ability to kick the rear out after they bought stickier tires and larger wheels.
if you love the stock setup, why are you changing it again? you kinda lost me on that one.
Originally Posted by Wolfking View Post
I've heard that the BRZ understeers a bit in comparison to my FRS. Stiffening an already rigid structure could only make it worse, I'd imagine. "you can over stiffen a car." If you absolutely must add parts, it makes sense to go with adjustable (settings) parts. You may find one setting more favorable over the others, is why! I'd also look at a front strut tower bar ( STB) before screwing with swaybars. As for Cusco...they are $$ for a reason. There are others. Tanabe, Eibach, all good.
Lowering a bit and providing wider tires make a big difference. neither of which call for upgraded sway bars. I'm partial to 225/45/17. I ran this set up on a 1998 S14 / 240sx SE for years. My car did "everything I commanded!"...an well! (daily driver)
Good luck and don't !@#$% up your car!
when you say over stiffen a car do you mean spring rate? because right before it, you sound like you are talking about the chassis and those are two entirely different things. a strut tower bar is in no way shape or form a replacement for sway bars. it really sounds like you are confusing chassis stiffness and suspension stiffness.
The Following User Says Thank You to fatoni For This Useful Post:
Dimman (09-16-2012)
Old 09-15-2012, 02:27 AM   #18
huma
Drives: ITR
What year wrx and is it a direct bolt on?
huma is offline   Reply With Quote
Old 09-15-2012, 08:04 AM   #19
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
So I've decided to go with the advice given to me earlier in the thread that said to get the wheels/tires first and see if I want sway bars based on my preferences with those installed.
I have some BC Racing Coilovers on their way to me. Other than that I'll wait it out.
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
The Following User Says Thank You to ngabdala For This Useful Post:
Calum (09-15-2012)
Old 09-15-2012, 08:36 AM   #20
Calum
That Guy
Drives: 2013 asphalt FRS MT
Everything we've seen so far points to this car not needing much to upgrade the suspension. The stock setup is great, 1.0g has been measured with no changes other wheels and tires. I'd say do the wheels and tire, get a good alignment and see where you're at. You could certainly be in the 1.1g area and theres not many people with the space, and skill to take full advantage of that.
Most cars, yes absolutely you should start with the suspension, but this isn't the norm. My personal plans are to put sticky tires on the stock rims, get some com-c top hats for the front and camber adjustment front and rear. Find an alignment I like and leave the suspension alone from there. I might get some regular guy springs from RC, but at the moment I'm not sure if I'd want them.
Old 09-15-2012, 09:11 PM   #21
ESC POD
ESC POD's Avatar
WRX '08-'11 Rear Sway bar...16mm. It uses the exact same End links so there is no need to remove them. Unbolt the end links (one nut each side) and the bushing caps (2 each side). Remove the stock bar. Shimmy the WRX into place. Thumb thread the 14mm nuts on the end links to to hold the bar in place. Thread the bushing cap bolts (12mm) and center the bar. Then lock it all down. Test Drive!! With TRAC off...she is tail happy!! with TRAC on...in Sport mode she flicks a bit, but in Normal Trac on all the fun buttons off...She's smooth sailing. For me at least...
My Wife and I decided on Pink...
All done...25 minutes install on the ground, of course the Nameless exhaust left me plenty of room to work under there without jacks.
Enjoy!
The Following User Says Thank You to ESC POD For This Useful Post:
huma (09-15-2012)
Old 09-15-2012, 10:11 PM   #22
huma
Drives: ITR
I didn't fully understand, so it uses all the same hardware from the BRZ? In your pics, it looks like you have new bushings/mounts for the bar. I didn't know if the BRZ bushings/mounts would work since it's for a smaller bar.
Old 09-15-2012, 10:21 PM   #23
ESC POD
ESC POD's Avatar
The BRZ end links are Identical to the WRX so all you need is a Sway bar and the appropriate size bushings and WRX bushing caps for the WRX bar. The BRZ bushings will be too small. However, it will all bolt in with the BRZ hardware.
Hope that helps!
huma (09-16-2012)
Old 09-16-2012, 09:59 AM   #24
huma
Drives: ITR
Hope that helps!
Thanks, understood now. Going to my dealership later this week to see how much it'll cost for everything (:
Old 09-16-2012, 01:43 PM   #25
Calum
That Guy
try here
http://www.subarugenuineparts.com/pr...f4023c49168a06
Old 09-21-2012, 02:13 AM   #26
Wolfking
Wolfking's Avatar
Drives: Asphalt FRS
I've made no mention of spring rates, therefore I'm still on the chassis. If factory swaybars are acceptable (for a daily driver) Then I'll always advise adding an STB before sways bars. I speak purely from my own tuning data. Your statement places words I've not uttered. Don't read into it. I'd read / study my comments again, good sir.
Wolfking is offline   Reply With Quote
Old 09-21-2012, 05:06 AM   #27
fatoni
you cant over stiffen a chassis and sway bars ARE springs so i im confused.
Old 09-22-2012, 02:33 AM   #28
Wolfking
Wolfking's Avatar
Drives: Asphalt FRS
you cant over stiffen a chassisbody ....
WHAT?
Please explain why you believe this is so. If that were true then we would have solid, not rubber or urethane bushings everywhere. A little "give" is necessary without question. (for a road car) If you've ever driven or rode in a battle tank, it would be crystal to you.
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Sway Bar Upgrades NYC BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 09-01-2012 06:43 PM
AMT rear sway bar bracket adamturbo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-13-2012 11:06 AM
adjustable sway bars!!! carbonBLUE Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 05-04-2012 08:42 AM
STI rear sway bar carbonBLUE Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-25-2012 12:58 PM
