Old 09-13-2012, 10:52 PM   #1
subatoy
subatoy's Avatar
Drives: subatoy
NA engine mods for turbo money?
ok so I'm a turbo guy but I wanted to see how much power you could achieve if you used the money from a turbo kit to buy NA mods.
so far AVO will cost around $3,800 (cheapest kit around) plus ECUTEK stuff u need to tune the car would cost another $800 which makes $4,600.
This kit should easily give 250whp-300whp (numbers based on existing kits running 4-8psi) I know theres installation costs but lets keep it easy so lets just talk about parts.
Lets say we had $4,600 what mods would net the most power without using Forced Induction. I'm talking Engine mods only to make it comparable to a turbo kit.
from the research I've done I can list:
-Intake system including silicon pipes
-Headers (I hate the way they sound)
-full exhaust system
-Light weight pulleys
-light weight flywheel
-Ecutek tuning
-E85 tune
please feel free to add more and the cost of the parts cuz I'm unsure.
subatoy is offline   Reply With Quote
Old 09-13-2012, 10:54 PM   #2
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
E85 tune I would add seperately from base tune
The Following User Says Thank You to JoeBoxer For This Useful Post:
subatoy (09-13-2012)
Old 09-13-2012, 11:06 PM   #3
drifter
Drives: truck and old car
For me it's not only about the money, but the ability to make power with mods that are reliable, (won't damage the engine) retain warranty, and be within the legal CA limits
drifter is offline   Reply With Quote
Old 09-13-2012, 11:12 PM   #4
Turdinator
Señor Member
Turdinator's Avatar
-Ecutek tuning
-E85 tune
Lightweight rotating components don't add power. They effectively reduce how much weight the engine is having to accelerate. So you'll reduce your 1/4ml not increase your HP on a dyno.
I'd say with the money you're talking 200whp should be achievable.
1974 TA22 Celica
2013 86 GT
Old 09-13-2012, 11:17 PM   #5
Grishbok
Volunteer Fire and Rescue
Grishbok's Avatar
Drives: Ambulance... sideways.
600$ nitrous injection. Enjoy turbo power when you want it.
It's more fun to drive a slow car fast, than a fast car slow.
Grishbok is offline   Reply With Quote
The Following 3 Users Say Thank You to Grishbok For This Useful Post:
20valvewynn83 (11-20-2012), ngabdala (09-14-2012), youcantseeme24 (11-28-2012)
Old 09-13-2012, 11:21 PM   #6
serialk11r
Drives: '06 AM V8V Coupe
Those might hit 200, but has anyone actually released a new intake header yet? The problem with this engine is that to shorten runners (to move powerband up) you would lose some of the acoustic effects that happen between cylinders, as the cylinders that fire one after another are on opposite banks. A new header that gives more grunt at 7k could help a bit. The part of the intake before the header is not going to affect performance nearly as much.
But then there is the issue of the cams, and I think the cam specs are actually pretty conservative on this motor. Those will have to go if you want to push beyond 200 ish.
Old 09-13-2012, 11:27 PM   #7
Turdinator
Señor Member
Turdinator's Avatar
I thought Nameless had suggested they needed to lengthen the runners to make more power which they couldn't do without removing the first cat.
The cams aren't too bad for a stock single duration setup. I think they were about 252*
1974 TA22 Celica
2013 86 GT
Old 09-14-2012, 12:28 AM   #8
Blue86
Drives: Sonic Blue 86GT Manual
how much is an LS conversion? :-)
Blue86 is offline   Reply With Quote
Old 09-14-2012, 12:40 AM   #9
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Im not too sure but if im not mistaken lightweight pulleys do add power to a dyno. Not to sure if its true hp or it just tricks the dyno..when i had my tc2 NST released a pulley and had dyno results from their pulley..it didnt put down alot of power but it did increase power throughout the power band..took a look at their blog http://nonstoptuning.wordpress.com/2...2011-scion-tc/
By the way on the 22nd im doing a before and after dyno with the perrin pulley so lets see if we actually gain anything on the dyno.
brichard0625 is offline   Reply With Quote
Old 09-14-2012, 01:20 AM   #10
Turdinator
Señor Member
Turdinator's Avatar
There is discussion on this in other threads. But basically on a dyno that gives a reading whilst accelerating an engine will show a gain. But the effect will differ depending on what gear you are in. Redusing the rotating mass is like reducing the cars weight but multiplied by the gearing eg g/box ratio x final drive ratio x rolling diameter etc. Therefore in theory 1st gear will see a greater gain from a light flywheel than 5th gear will. Similarly a lightweight carbon drive shaft will be like lightening the car multiplied by the final drive ratio as its in between the g/box and diff so the reduction is more constant.
If you were to dyno an engine at a fixed rpm before and after a flywheel change the power would read the same. A dyno that accelerates through the RPM range will show a gain depending on the gear you dyno it in. People seem to dyno these cars in 4th gear for some reason where traditionally people use whichever gear is 1:1 which is 5th on these.
(sorry that turned into bit of a novel, still not sure i explained myself well)
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
zex (11-20-2012)
Old 09-14-2012, 01:28 AM   #11
subatoy
subatoy's Avatar
Drives: subatoy
I don't think too many mods that give power would retain warranty, I've always seen modding for people who are willing to lose their powertrain warranty, which is my case.
I owned an 06 WRX (selling that car was the biggest mistake)
and I drove that car on Stage 2 for 4 years FLAWLESSLY! never a single problem and I can say that It wasn't driven like a baby so I trust that these Subaru cars are tough!
It seems like Turbo for the money is the way to go for my goals, I understand why a turbo doesn't make much sense for those looking for throttle response and serious racing but I've never taken a car to ANY sort of track I just enjoy them.
I know pulleys or lightweight components aren't about power but they are still about enhancing performance through the engine so thats why I added them.
Old 09-14-2012, 01:28 AM   #12
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
I think the only reason you would want to stay with NA mods for making power is if you want to have amazing response at the cost of less in the numbers or make big numbers but add lag
port? head work? I dunno anything about boxers though so I'm not even sure of how much it would do
Out of the FRS game
Mr.Jay is offline   Reply With Quote
The Following User Says Thank You to Mr.Jay For This Useful Post:
mike2100 (09-14-2012)
Old 09-14-2012, 01:36 AM   #13
serialk11r
I was talking about the intake header. I have a strong suspicion that the intake headers are detuning the top, giving a "broader" powerband.
The cams aren't too bad, but longer cams could allow some more high rpm overlap and slightly improved VE. The VVT "charts" that Toyota gave show there's something like 8? (I forgot what it was exactly) degrees that the cam opening point can be retarded past TDC. So add 8 degrees before the stock cam (to maintain a good idle and low load characteristics), maybe like 16 after the stock cam closes, then that will allow 8 degrees overlap with the intake valves closing 8 degrees after they used to, that should give a bit of a boost up top. You could add more and create some overlap at all times, but the more you do that obviously the worse the low load and low speed characteristics will be.
Old 09-14-2012, 01:40 AM   #14
Dimman
Kuruma Otaku
Dimman's Avatar
Manifold. Avoids confusion.
Also still no cam news from manufacturers?
Because titanium.
1.6L DI TURBO ENGINE quik1987 BRZ First-Gen (2012+) — General Topics 39 11-30-2011 06:01 PM
FT-86 vote for you engine layout 2.0L NA vs 2.0L Turbo vs 6 banger Allch Chcar Scion FR-S / Toyota 86 GT86 General Forum 87 08-17-2011 02:31 AM
FT-86 / FR-S engine will be Toyota 2l turbo!! Slide Engine, Exhaust, Transmission 114 07-07-2011 11:58 PM
Do you want a turbo engine for the FT-86? Read here Ramo BRZ First-Gen (2012+) — General Topics 86 06-23-2011 09:39 PM
