Old 09-13-2012, 08:08 AM   #15
alex86
alex86's Avatar
Drives: Argento
must be some electricals or the battery but no worries it is not the engine.
give us updates as soon you solve the problem.
alex86 is offline   Reply With Quote
Old 09-13-2012, 08:12 AM   #16
vobla6.0
Resident Douchebag
Drives: balla'
There was a CEL... so can you pull the original engine code using an Actron scanner?
Maybe its the same/similar issue Whiteout_FRS ran into... then youre eligible for a free scion FRS + pacifying benefits...
vobla6.0 is offline   Reply With Quote
Old 09-13-2012, 09:14 AM   #17
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
Originally Posted by DaJoian View Post
Wait...you're the same guy that peeled off from the lot because a bunch of kids said it's just a Scion...!
Since the engine was not fully broken in yet, everything probably seized up. Depending on the dealer; I think they will try and plug in their computers to determine if you've eff-ed around with the car during the break-in period...(Correct me if I'm wrong, truly guessing here) and try to prove you in the wrong so they can void that warranty of yours.
Good luck with that...
LULWUT...
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
The Following User Says Thank You to czar07 For This Useful Post:
ill86 (09-13-2012)
Old 09-13-2012, 09:17 AM   #18
FRSowner
Drives: Hot Lava A/T
The important thing is....do your friends think it's a cool car?
That's what's really important, right?
Let's get our priorities straight...
FRSowner is offline   Reply With Quote
The Following 2 Users Say Thank You to FRSowner For This Useful Post:
Dave-ROR (09-13-2012), steeloyangster (09-13-2012)
Old 09-13-2012, 09:24 AM   #19
Jaxxx
Drives: Acura TL, MDX, BMW 335
chances are your scion warranty will be terminated, any wheelspin detected above 60mph will automatically do that, keeping log at your scions black box. I woudnt bring the car to any dealership and just try to fix it yourself.
Jaxxx is offline   Reply With Quote
Old 09-13-2012, 09:26 AM   #20
FastLap
Drives: 2025 Toyota GR86 Premium PP
Covered under warranty. Take to dealer, they will fix it. End of story.
FastLap is offline   Reply With Quote
Old 09-13-2012, 09:29 AM   #21
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
Join the club. You're one of the *lucky* few that suffered a catastrophic failure. It shouldn't be related to your burnout. Call the dealer, get it towed, get it fixed. Should be all covered under warranty.
Here's the thread you should check out:
http://www.ft86club.com/forums/showthread.php?t=15577
Books is offline   Reply With Quote
Old 09-13-2012, 09:40 AM   #22
ML
ML's Avatar
Drives: 13 White MT FR-S
I like your thread tags btw...
Old 09-13-2012, 10:07 AM   #23
gmookher
proof that acting a fool/show off 109 mile motor not a wise choice.
better they dont pull evidence of you red lining it from your ecu...
Old 09-13-2012, 10:20 AM   #24
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Originally Posted by ragingSPAM View Post
one thing to add is that technically speaking the engines in the cars are already "broken in" from the factory...in reality, modern engines are made at such a precise level that the break in process is very minimal and takes very little time, the piston rings basically need to make grooves in the cylinder walls to get a good seal but that occurs rather quickly...just an fyi (hope you feel better)
While the engine does get broken in at the factory, the rest of the internals don't. Your drivetrain, clutch, and brakes all benefit from a break in period.
It's rarely wise to do clutch drops and burnouts with a sub 100m car.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
The Following User Says Thank You to Hawaiian For This Useful Post:
ragingSPAM (09-14-2012)
Old 09-13-2012, 10:50 AM   #25
Pete156
I like to eat!
Originally Posted by tric View Post
im @#$%'ed...
All from proving your Scion's 'manhood'
You live in NY. Just take it to a muffler shop. They'll probably be able to fix it with a hammer.
Pete156 is offline   Reply With Quote
Old 09-13-2012, 10:50 AM   #26
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Originally Posted by czar07 View Post
LULWUT...
LULNUTHN...
Here, let me explain... Because obviously you don't understand.
Assuming this problem is due to the fact that the engine did not break in properly, and the OP "peeled off" the parking lot at cold start...to amuse friends.
Engine that start up cold = thick oil = cannot get between the cam gears, piston rings and cylinder walls, and etc for proper lubrication.
So now you race the cold new engine that hasn't seat it's piston rings properly without proper lubrication; what do you get?
I'll let you figure that one out.
If you are racing the engine when there is improper lubrication to some of the engines vital components especially during a cold start... It could lead to engine seize. I'm just saying it's "possible".
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 09-13-2012, 11:57 AM   #27
jadewbj
jadewbj's Avatar
If the 4000 rpm break in was so important why is it not listed in the manual? Why did my dealer say absolutely 0 to me about breaking in the car or a break in procedure?
I am following it, but without it listed in the manual there is no way they could deny a warranty claim for not following it.
jadewbj is offline   Reply With Quote
Old 09-13-2012, 12:17 PM   #28
TuxedoCartman
Drives: '13 86
Reading comprehension... I hear it's all the rage with kids these days.
If you look in the back of the owner's manual, in the index, you'll see "Break-in Tips" is on page 125. And right there, at the top of that page, you'll find this...
*New vehicle break-in driving (the first 1000 miles [1600 km])
The performance and long life of your vehicle are dependent on how you handle and care for your vehicle while it is new. Follow these instructions during the first 1000 miles (1600 km):
-Do not allow the engine speed to exceed 4000 rpm except in an emergency.
There ya go. Took me longer to type that than it did to find it.
P.S.: Oh, and as for your dealer not telling you about it? Wow... you don't have a lot of experience with car dealers, do you? Most of the ones I've dealt with can't tell you the engine type or drivetrain layout on the cars they sell.
TuxedoCartman is offline   Reply With Quote
The Following 3 Users Say Thank You to TuxedoCartman For This Useful Post:
FBaxteR-S (09-13-2012), sho220 (09-15-2012), Spaceywilly (09-13-2012)
brz, frs, fucked
Anyone use a dash cam? hansthegerman Electronics | Audio | NAV | Infotainment 54 01-12-2019 01:58 AM
Why I got a dash cam drifter Electronics | Audio | NAV | Infotainment 303 06-20-2014 11:24 AM
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 08:38 PM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 10:06 PM
Fog lights on with parking/running lights possible? BMWDavid BRZ First-Gen (2012+) — General Topics 1 06-16-2012 07:29 PM
