Old 09-13-2012, 01:26 AM   #1
tric
tric's Avatar
Drives: Whiteout FRS
Exclamation HELP!!! FR-S Shutdown all lights on the dash came on!!!
A few min ago, pulled out from my driveway the check engine light came on. i ignore it thinking its a minor whatever. i'll take it to the dealer in the morn. but by the time i got to the end on my block all lights came on and i felt i lost the power steer. so i pulled over turn it off for a few second and now it just grinds the motor & wont turn over.
-Battery Check
-Starter Check
-All the Lights are still on when you turn on the ignition
me and my friends pushed it back to my driveway.
this could be the result of an idiotic act i did a few days ago. trying to prove my SCION. i peeled off @ 109 miles.
Could this void my warranty/or whatever coverage i have?
Could i loose the car?
btw im leasing from "millennium toyota"
im @#$%'ed...
tric is offline   Reply With Quote
Old 09-13-2012, 01:41 AM   #2
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Wait...you're the same guy that peeled off from the lot because a bunch of kids said it's just a Scion...!
Since the engine was not fully broken in yet, everything probably seized up. Depending on the dealer; I think they will try and plug in their computers to determine if you've eff-ed around with the car during the break-in period...(Correct me if I'm wrong, truly guessing here) and try to prove you in the wrong so they can void that warranty of yours.
Good luck with that...
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 09-13-2012, 01:43 AM   #3
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
I doubt its related to you breaking 4000rpm limit. Probably alternator OR the CEL has cause catastrophic engine failure. youll be covered under warranty.
dont sweat it bro theres a lot more to life than cars.
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
Old 09-13-2012, 01:44 AM   #4
cgrey
Drives: 2013 Argento Silver FR-S
-Battery Check
-Starter Check
im @#$%'ed...
This probably has nothing to do with what it sounds like you did.
Please describe how you "proved" your Scion.
cgrey is offline   Reply With Quote
Old 09-13-2012, 01:45 AM   #5
cgrey
I hope you're kidding. If not, please refrain from analysis or advice.
Old 09-13-2012, 01:50 AM   #6
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Nah this cant be the problem. I tracked my car with only 500 miles and its at 3k right now doing fine pulling like a champ, the brake in period is a myth on newer engines. This forum is full of people who love to make theories up.
OP:
Its hard to diagnose without pulling some codes or more details. You talk about a grinding noise in the engine, is it a knocking sound ? How is your oil? Share as much info as you can with us in order to help you.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
Old 09-13-2012, 01:52 AM   #7
DaJo
FT86Club Vancouver
DaJo's Avatar
You never know man. Please refrain from double-posting; you can multi-quote in one post.
2000 MR-S 5MT
2010-2012
Old 09-13-2012, 01:53 AM   #8
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
-Battery Check
-Starter Check
im @#$%'ed...
Although it probably wasn't the best idea ever, one burn out at low mileage should not cause a catastrophic failure...
Good luck...hope they can fix it for you.
Some will fall in love with life and drink it from a fountain
That is pouring like an avalanche comin' down the mountain
sho220 is offline   Reply With Quote
Old 09-13-2012, 03:58 AM   #9
jmaryt
Drives: 2012 honda civic ex
so true! don't be concerned! toyota will take care of you! just continue
to live your life to the fullest! don't let this set back pshycologically impair you!
it's just a car, an inanimate object! can be replaced no worries! don't f**k up
your life over it!
jmaryt is offline   Reply With Quote
Old 09-13-2012, 04:08 AM   #10
sho220
sho220's Avatar
your life over it!
Someone has had their coffee this morning! !
Old 09-13-2012, 04:13 AM   #11
jmaryt
tea! it gives me "brain farts!" must be the ''antioxidants"
Old 09-13-2012, 04:20 AM   #12
Grishbok
Volunteer Fire and Rescue
Grishbok's Avatar
Drives: Ambulance... sideways.
Keep us posted on what they diagnose the problem is, im curious as to what could have failed.
You will never 'convince' others to respect your car, or yourself. You earn it.
It's more fun to drive a slow car fast, than a fast car slow.
Grishbok is offline   Reply With Quote
Old 09-13-2012, 05:58 AM   #13
ragingSPAM
Photojournalist
ragingSPAM's Avatar
Drives: Firestorm FR-S, EG8 civic
one thing to add is that technically speaking the engines in the cars are already "broken in" from the factory...in reality, modern engines are made at such a precise level that the break in process is very minimal and takes very little time, the piston rings basically need to make grooves in the cylinder walls to get a good seal but that occurs rather quickly...just an fyi (hope you feel better)
ragingSPAM is offline   Reply With Quote
Old 09-13-2012, 07:56 AM   #14
encity5
encity5's Avatar
Don't know what it is, but GOOD LUCK and hope everything works out, sounds like a nightmare
encity5 is offline   Reply With Quote
brz, frs, fucked
Anyone use a dash cam? hansthegerman Electronics | Audio | NAV | Infotainment 54 01-12-2019 01:58 AM
Why I got a dash cam drifter Electronics | Audio | NAV | Infotainment 303 06-20-2014 11:24 AM
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 08:38 PM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 10:06 PM
Fog lights on with parking/running lights possible? BMWDavid BRZ First-Gen (2012+) — General Topics 1 06-16-2012 07:29 PM
