Old 09-03-2012, 03:34 PM   #71
MidnightMonkey
I am the one who knocks!
MidnightMonkey's Avatar
Drives: 2013 Whiteout FR-S MT
The stuff does pour like water. Just changed at 1144. Couldn't find any Penzoil Premium 0w20 so just picked up 6 quarts from the dealer. I somewhat agree with OP. The sound difference is totally noticeable, I just don't think it's as drastic as what he described.
MidnightMonkey's MT Whiteout FR-S Thread!
MidnightMonkey is offline   Reply With Quote
Old 09-05-2012, 08:45 AM   #72
Akired86
Akired86's Avatar
Drives: 2013 Scion FR-S Asphalt
Really $20 dollars for Toyota Oil filter? Only $7.50 in SoCal. I change my oil at 2000 miles Mobil 1 Advanced Fuel Economy 0W-20. Engine smooth out about 2300, notice MPG going up as well.
Akired86 is offline   Reply With Quote
Old 09-06-2012, 05:04 PM   #73
SF-FRS
Drives: 2013 Scion FRS
Originally Posted by Dragon86 View Post
Does Toyota use Subaru oil during an oil change?
I just got my oil change done at a Toyota dealer....They have there own 0/20 blend motor oil
SF-FRS is offline   Reply With Quote
Old 09-13-2012, 05:54 AM   #74
mokhope31
Drives: BMW
Could it be that the overfill of the oil was the cause of the change in engine noise? To find out I went back under the car the next day. I attached a short hose with the little plastic connector that came with my Fumoto oil valve. I was able to drain exactly 0.5 quart of oil from the oil pan by only partially opening the valve to control the flow. Wow! I would not have been able to do this so precisely without the Fumoto valve. Also, I used only one blue paper shop towel for the entire procedure including checking the dipstick afterwards!
mokhope31 is offline   Reply With Quote
Old 09-19-2012, 06:23 PM   #75
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
If anyone is curious on the safety of using a fumoto valve on this car....
I just put mine on and it's very secure and surrounded by underbody panels. It's also recessed below the panels so I'm definitely not worried!
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
The Following 3 Users Say Thank You to Laika For This Useful Post:
AJUSA.com (09-19-2012), chas3wba0 (01-29-2014), mweidner311 (04-15-2014)
Old 11-02-2012, 12:20 PM   #76
ninjasaurusrex
Drives: 2013 Raven Scion FR-S 6MT
Originally Posted by Hawaiian View Post
I also used rhino ramps and a 2x4 to get my car up.
You can get the filter and crush washer from subaru dealers for about $10 bucks for the combo. I also posted a link in the oil filter thread if you plan to change your oil a lot. the site was selling them for 6.40 each.
I just called my subaru and Toyota dealerships, the price is like 50 cents difference, are they the same filters?
ninjasaurusrex is offline   Reply With Quote
Old 11-02-2012, 02:09 PM   #77
jazztennor
jazztennor's Avatar
Drives: Scion FR-s
does anyone know if i purchase the fumoto valve will it void the warranty for service? I get free oil changes and other maintenance. I would like to purchase the fumoto valve and have them install it when i call for an oil change.
Upgrades
EVO 3 Exhaust,Emblem swap,Full Carbon Interior,Greddy intake
jazztennor is offline   Reply With Quote
Old 11-02-2012, 04:09 PM   #78
st0k3d
Why would you waste your money on a part that makes it easier for a DIY guy on the ground to do an oil change, if you get free oil changes? What kind of oil drain bolt could void a warranty? Full of derp.
st0k3d is offline   Reply With Quote
Old 11-02-2012, 05:02 PM   #79
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
They are the same. But in the first few months some toyota dealers were charging $20 a pop for them while the subaru dealers were charging 8.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 11-02-2012, 11:14 PM   #80
Brzer
Drives: BRZ, 2011 Outback 3.6R
Does the valve make it possible to change the oil without using ramps or a rack?
Brzer is offline   Reply With Quote
Old 11-03-2012, 11:00 AM   #81
OrbitalEllipses
Drives: Attitude
If you can fit a tray under the car and wiggle your hand under there to open the valve.
Without this valve I used to change the oil on my stock height (4x4, heh) WRX without lifting it.
Old 11-03-2012, 12:28 PM   #82
gmookher
when installing my fumoto I tossed the iffy fiber washer and went with a copper washer combined witha factory crush washer, no leaks, and I get a bit better drainage, as the threads dont sit as high into the pan. I also too some sand paper and put some crosshair like roughness on one side of the dipstick, it helps the oil 'stick' if you will and makes it easy to read level
I think my ramps are the rhino 8000s... having lowered, I still need some wood to get it up....LOL
park one set of wheels up on the curb and oil changes under 5 minutes, no mess, no ramps
Old 11-03-2012, 10:35 PM   #83
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
You may still need a ramp, or at least a way have enough clearance to reach the valve to do the oil change, since you'll need to attach the plastic adapter/barb and tubing and be able to open the valve. I happen to have a steep enough curb on my garage that I can reach the valve from the side, so no need for my rhino ramps.
Old 11-08-2012, 08:55 AM   #84
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
I have an oil extractor, so I'm not even going to have to lift the car up to do my oil changes. Remove the dipstick, insert tube, and pump. It works really well on my Miata (I can spin off the filter from the engine bay as well).
No muss, no fuss, no mess.
[ame="http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=oil+extractor"]Amazon.com: oil extractor[/ame]
Grimlock is offline   Reply With Quote
Subaru Dealer Blacklist (Surprise markups and other shady dealings) Longhorn248 BRZ First-Gen (2012+) — General Topics 540 04-08-2021 07:25 AM
Extra wiring (and a Usb surprise) twincamRob Electronics | Audio | NAV | Infotainment 34 01-08-2014 09:25 PM
First Payment sent, Observations after 6 weeks. Scooby South BRZ First-Gen (2012+) — General Topics 27 08-01-2012 02:02 PM
My 24 experience owning an FR-S Doji Style Scion FR-S / Toyota 86 GT86 General Forum 7 06-06-2012 09:16 PM
Surprise from the dealer in the mail! Pat1usmc BRZ First-Gen (2012+) — General Topics 102 03-11-2012 02:35 PM
