Old 09-07-2012, 10:20 AM   #71
Visconti
Drives: 05 STi
Originally Posted by dwx View Post
The way the Crawford is designed the vapors escape out the top of the aos and back into the intake. They originally had issues in colder climates where the water vapor would condense so they actually run the engine coolant through the AoS to keep that from happening. It's designed as a separator, not a catch can with a drain back into the oil pan.
On my 600whp+ STi I don't have the top vent back into the intake. We normally run it under the car - with out any problems.
Crawford told me they did things a little different on this unit ... Can't wait to have one
John
Visconti is offline   Reply With Quote
Old 09-11-2012, 10:46 PM   #72
Crawford
Crawford's Avatar
Drives: 2013 Subaru BRZ
Crawfords Performance today told me that after a long track session they checked they're can/lines and saw oil
John
Oil in the inlet of the AOS bot no oil in the outlet lines to the motor
Crawford is offline   Reply With Quote
Old 09-11-2012, 10:49 PM   #73
Crawford
Crawford's Avatar
This is a correct assessment... 70% of the oil going through the intake is from the PVC valve.
Team Crawford
Originally Posted by roddy View Post
Guys, I could be wrong here, but I don't think so. I'm looking at the way that these are hooked up and it just doesn't look right. There is very little vacuum (if any) at the hose going into the intake tube before the throttle body. There may be some oil vapor there, but not much. It may show a little grime on your TB butterfly in time, but this is not where most of the oil finds its way to the combustion chamber. Where is the PCV valve on this engine? There is usually a large (3/8" I.D. or so) vacuum hose that runs from the PCV valve directly to the intake manifold after the throttle body. There is strong vacuum there (except at WOT or under boost), and that one sucks a lot of oil vapor/droplets. I experimented with placement before and after the throttle body on my Mustang, and found that I caught FAR more oil running the catch can between the PCV valve and the intake manifold. My Mustang is pushing 10-12 PSI of boost and the oil on the before throttle body side was negligible, so I doubt a naturally aspirated engine would see much accumulation. That said, it wouldn't hurt to run 2 cans...some people do.
That Moroso one looks pretty slick. I have a similar can on my other car, but no drain. The bottom section of the can unscrews so I can dump it out.
One more thing... letting the gunk that accumulates in the catch can get back into the engine is bad mojo. Don't even think about it.
Old 09-12-2012, 06:48 AM   #74
Apex Chase
El Presidente
Apex Chase's Avatar
Drives: it like I stole it!
Crawford Performance: Will there be separate N/A and F/I options?
Apex Chase is offline   Reply With Quote
Old 09-12-2012, 06:52 AM   #75
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
@Crawford
seeing you're offering your AOS for the BRZ as v.2 - it means it's heated via the coolant lines?
could you provide more info on that specific connections diagram for the BRZ?
I live in severe-cold climate, so having a heated AOS would be a bless, since there is no condensation happening, right?
http://store.crawfordperformance.com/store/products/652
MSTiFK8R is offline   Reply With Quote
Old 09-12-2012, 09:10 AM   #76
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
John
yep. my top vent is routed right into the fender well on my sti. AOS is where it's at.
VSGTS14 is offline   Reply With Quote
The Following User Says Thank You to VSGTS14 For This Useful Post:
Crawford (09-12-2012)
Old 09-12-2012, 11:05 AM   #77
wootwoot
Drives: FRS
This^
Also, why does the add now say version two? It just went to production and we are already on V2?
Old 09-12-2012, 11:09 AM   #78
gmookher
what does the inside baffle structure look like? any gauze or anything? what media inside?
Old 09-12-2012, 12:23 PM   #79
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by wootwoot View Post
This^
they had two versions previously of their AOS. the first one didn't have the coolant lines like the V2 has. This was to keep the can warm to prevent condensation in the tank.
xxscaxx is offline   Reply With Quote
Old 09-12-2012, 01:10 PM   #80
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by gmookher View Post
I added a moroso, reused some piping from the removed sound generator that I removed earlier:
will report back after this weekend's auto-x event if I am able to catch any oil!
Yuuuuup!
Got the last one at a sweet price. Should be just as effective as the Crawford one for less than half the price.
Can you elaborate on your mounting? I'm pretty sure mine will come with the same bracket. Did you remove the passenger's side strut brace to drill small holes then use metal screws or what? Details please :happy0180:
Old 09-12-2012, 01:44 PM   #81
gmookher
Originally Posted by ATL BRZ View Post
Yuuuuup!
well, for the money shipped, its a great value, unless it only actually catches 40% the oil, its 40% the cost of some of the solutions being offered, minus a name, moroso is dated, but solid design, dig that its a clamshell.
volume wise, blow by pressures should be fine and airflow does remain positive even with smaller 3/8 hoses and barbs. they do sell a bigger kit but for a 2.0L motor there is no need for overkill
You got it install was easy, I cannibalized the old fittings off the sound pipe, one of them is a grey plastic that I will replace with brass; the pipe diameter is 3/8 and to get one end on to the factory barb I used some hot water to soften the rubber. this is another part of the install I will redo with a brass step down or a molded hose for a more permanent setup, but what i have for now did fine on a spirited 2 hr run.
Now if the crawford has coolant lines and is a superior design, then hey, I will likely ante up for a better solution when I can afford it, priority wise this is better than nothing for now
anyone have pics of this v2 aos from them? I'm interested in knowing more
The Following User Says Thank You to gmookher For This Useful Post:
ATL BRZ (09-12-2012)
Old 09-12-2012, 06:47 PM   #82
Crawford
Crawford's Avatar
I do not think so, but if it's necessary to make a change for a turbo motor then we will. The current AOS was designed with a turbo application in mind.
Team Crawford
The Following 2 Users Say Thank You to Crawford For This Useful Post:
Apex Chase (09-12-2012), ngabdala (09-12-2012)
Old 09-12-2012, 06:53 PM   #83
Crawford
Crawford's Avatar
Originally Posted by MSTiFK8R View Post
@Crawford
There is not scoop in the hood of the BRZ to freeze the AOS, so we think the under-hood temps will be enough to keep the AOS from freezing. Also we have changed the design on this unit so the drain has a 300% larger opening.
Team Crawford
The Following User Says Thank You to Crawford For This Useful Post:
Old 09-12-2012, 06:54 PM   #84
Crawford
Crawford's Avatar
This^
Sorry... just cut our IT dudes balls off!! All better now
blow by, carbon build up, catch can, crawford catch can, radium catch can, saikou michi
Catch Can ArKiTeCkT Engine, Exhaust, Transmission 31 09-15-2013 03:07 PM
Oil Catch Can? eblamble3 Engine, Exhaust, Transmission 4 03-15-2013 10:58 AM
where to plug the oil catch can hose... :S dompower Engine, Exhaust, Transmission 29 11-14-2012 12:30 PM
Cusco Oil Catch Can for BRZ/FR-S at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 0 07-01-2012 03:16 AM
Purpose of oil catch can? denverizzles Engine, Exhaust, Transmission 1 06-28-2012 03:55 PM
