Old 08-25-2012, 01:52 PM   #1
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
100LL Fuel - Any repercussions?
Hey folks!
Wondering if there are any of you out there who know (legitimately) how lead can or will affect the FRS or BRZ exhaust system?
I have access to 100LL fuel (LL stands for Low Lead) and had considered running it as a high performance fuel. 100LL aka AVGAS is used in almost all piston powered aircraft. As you may have guessed, aircraft dont have CATs or O2 sensors. I have used 100LL in an old car before (78 Ford) but that was pre emission days.
Im also slightly curious if lead could have any effect on the soft metals in this FA20 engine? I'm still trying to get an engineer to find out what the valves and guides in an aircraft engine are made of. Almost everything is aluminum and the lead certainly doesnt hurt that.
Any takers on this debate?
RandomHero is offline   Reply With Quote
Old 08-25-2012, 01:56 PM   #2
jeebus
I'm sure it won't destroy your cats immediately, but eventually it will. I wouldn't run it.
jeebus is offline   Reply With Quote
Old 08-25-2012, 02:59 PM   #3
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
yeah seems to be the consensus down at the hanger as well. Damn. Well, maybe ill get a full race exhaust and delete the Cats... thats a PITA though...
Old 08-25-2012, 03:05 PM   #4
xwd
Yeah leaded gas, cats, and O2 sensors don't mix very well. Occasional use fine, but not every day driving.
Old 08-26-2012, 04:17 PM   #5
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
Yep, you will write off all o2 sensors and cats in a short period of time. This would screw the ECU's ability to make car run efficiently as well
Toyota 86 test driver
Tradewind is offline   Reply With Quote
Old 08-26-2012, 04:27 PM   #6
serialk11r
Drives: '06 AM V8V Coupe
Bigger problem would be the O2 sensors, your ECU loses closed loop function and thus will have no idea how much fuel it's metering after a while. Actually I don't know how much they actually need to trim but just a few percent off can cost you a lot of power, or blow your engine.
Old 09-10-2012, 11:42 PM   #7
F3dzo
F3dzo's Avatar
Drives: 13 fr-s whiteout
I'll be back!!
F3dzo is offline   Reply With Quote
The Following User Says Thank You to F3dzo For This Useful Post:
Sportsguy83 (09-11-2012)
Old 09-11-2012, 07:18 AM   #8
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by F3dzo View Post
where's this?
Old 09-11-2012, 09:38 AM   #9
MattQ-WP
MattQ-WP's Avatar
Drives: Pearl White
AVGAS is an oxygenated fuel designed to be run at super high altitude.. not at normal driving altitude.. you CAN run it in pretty much any car but its octane (normally 100) doesn't behave exactly like 100 octane vehicle fuel would behave... the high oxygen content actually makes the fuel run slightly leaner at lower altitudes due to the ambient pressure PLUS the oxygen in the fuel
You WILL toast your O2 sensors, you WILL toast your cats.. you WILL feel a bit more power and then you WILL feel a big repair bill
I ran Avgas for a few months in my previous modded car and the net result was a cataclysmic engine failure... melted pistons... cracked block... oil in water, water in oil, cats and dogs living together... the end of life as we know it
An opinion is like a bad smell, every A$$HOLE has one!
INITIAL DRIVING CLIP
MattQ-WP is offline   Reply With Quote
Old 09-11-2012, 12:37 PM   #10
SkullWorks
Drives: SSM LT MT BRZ
I'd stay away from lead and DI until I understood the effects of the high injector tip temperature and leaded gas were understood, that is really the only thing mechanically different, in a substantial nature, from any other normal gas internal combustion engine. I would worry about potential for build up or clogging of the very fine holes in the injector...I have no foundation for this, but I'm sure they were not worrying about leaded gas while proving out the DI fuel system....
other than that...there are the aforementioned cats, dogs??? and O2 sensors,
for which there are test pipes, dog biscuits??? and replacement intervals...the sensors will last a couple thousand to 10,000 miles depending on how rich the motor runs......
Old 09-11-2012, 01:02 PM   #11
NeedsmoreCowbell
toyotas are practical :)
NeedsmoreCowbell's Avatar
Drives: Hot Lava FRS
i like it in the lawn equipment but i blend it
NeedsmoreCowbell is offline   Reply With Quote
Old 09-11-2012, 05:17 PM   #12
Guillaume
Guillaume's Avatar
Drives: Exige S 240
I'll just leave that here http://jalopnik.com/5938552/why-you-...el-in-your-car
Guillaume is offline   Reply With Quote
The Following User Says Thank You to Guillaume For This Useful Post:
tripjammer (09-11-2012)
What fuel do you put on your FRS/BRZ? dhpinoy Southern California 61 06-15-2018 05:35 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
FUEL JDMSushi AUSTRALIA 23 07-18-2012 11:01 PM
94 AKI vs. 91 AKI Fuel smbrm Scion FR-S / Toyota 86 GT86 General Forum 14 05-28-2012 06:45 PM
E85 Fuel? Siriusly.Andrew Scion FR-S / Toyota 86 GT86 General Forum 60 02-11-2010 05:00 PM
