Old 05-27-2012, 10:15 PM   #1
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
94 AKI vs. 91 AKI Fuel
Anybody have anything to report as yet regarding performance with 94 octane vs. 91 Octane fuel Premium pump fuel?
smbrm is offline   Reply With Quote
Old 05-27-2012, 10:31 PM   #2
fistpoint
Drives: Supercharged Golf Cart
Fuel with a higher octane rating doesn't have more power...
fistpoint is offline   Reply With Quote
Old 05-27-2012, 10:48 PM   #3
TheRipler
Reap the BReeZe
Drives: 04 LandShark STi
Not inherently, but it may allow the ECU to provide more timing, which could increase power output. In my experience, turbo Subaru ECUs (which require premium fuel) will react differently to 91 vs 93, and I would expect the same could be true for the BRZ.
The OP has a valid question, and I look forward to real world answers.
TheRipler is offline   Reply With Quote
Old 05-27-2012, 11:13 PM   #4
GirlyScions
Drives: Mazda3
The octane, AKI, is the anti knock index. It dose not have more power or MPG. What id dose do is the resistance to prevent the engine from "knocking". Your car dose not need anything other than what the car is recommended to use. Unless the engine is in not healthy and knocks use higher octane.
Turbo engines have a higher compression ratio and are prone to pre mature ignition (engine knock) require higher octane gas to cope.
Dont wast your money on octane if your car donst need it.
GirlyScions is offline   Reply With Quote
Old 05-27-2012, 11:28 PM   #5
smbrm
smbrm's Avatar
Thanks for the replies.
I think I need to rephrase my question.
My question is not about the difference between 94/93 AKI and 91 AKI fuels. I am familiar with fuel octane quality differences.
My question is for current owners and whether their car or they as driver perceive or observe any difference. Almost all cars are equipped with knock sensors today and so can adjust to a certain range of fuel octane level by retarding the timing when knock is detected.
"...The engine is designed to operate at maximum performance using
unleaded gasoline with an octane rating of 93 AKI (98 RON) or
higher. If 93 AKI (98 RON) fuel is not readily available in your area,
unleaded gasoline with an octane rating of 91 AKI (95 RON) may be
used with no detriment to engine durability or driveability. However,
you may notice a slight decrease in maximum engine performance
and you may hear some knocking (pinking) of an engine while using
91 AKI (95 RON) fuel. Use of 91 AKI (95 RON) fuel will not affect your
warranty coverage...."
The question is whether anyone has perceived or observed anything different when using 91 AKI fuel vs. a 94/93 AKI fuel?
example: knock with 91 AKI is everyday driving?
Just curious
cheers
Old 05-27-2012, 11:52 PM   #6
GirlyScions
Drives: Mazda3
I don't own one yet but if the owners manual recommends me to use 93 I wouldn't think twice. Im guessing its hard to get 93 octane in some country's and was easer to build all engine's with the same compression ratio. Ill have to go looking for those numbers.
Good question. I hope someone will have noticed the difference
Old 05-27-2012, 11:58 PM   #7
arbnpx
Some states max out at 91 AKI (meaning that the highest grade you can buy at a gas station is 91 AKI); particularly, California, home state of Toyota's US headquarters. I imagine that auto manufacturers keep this in mind; when I rented an E90 328i in LA, it said "minimum 91 octane" on the fuel filler, which makes sense, since it had a direct injected N52 engine.
The FA20 / 4U-GSE on the BRZ / FR-S is 12.5:1 compression, and direct injected, so feed it the highest grade you can get at the pump. I imagine that the ECU should be able to map 91 just fine, considering that other cars that require premium can do the same, and that they knew this car would have to be able to be fueled in states like California that don't stock 93.
arbnpx is offline   Reply With Quote
Old 05-28-2012, 12:35 AM   #8
AlmostMDD
AlmostMDD's Avatar
Drives: 99 2.5RS
I'm nearly certain that you won't get engine knock on 91 aki, I highly doubt that the manufacturers would do that. I don't think we'll know about the extent of the performance loss unless someone's dynos the same car, same day, same dyno with the two different fuels. I doubt subjective impressions will be terribly helpful in figuring anything out, unless it's a massive power loss.
AlmostMDD is offline   Reply With Quote
Old 05-28-2012, 02:21 AM   #9
Fish
Fish's Avatar
Drives: 2015 Yuzu RS1.0 Scion FR-S #893
I think 91 should be fine. I believe in the manual for my Evo it called for at least 97 or something like that. That was pretty impossible for me to find here in CA. I never had a problem running 91 though. I think as long as you run the premium fuel, you'll be alright.
Fish is offline   Reply With Quote
Old 05-28-2012, 02:49 AM   #10
Sonex51
Sonex51's Avatar
Drives: BRZ Limited (Pre-ordered). WR Blue
Originally Posted by GirlyScions View Post
(...) Your car dose not need anything other than what the car is recommended to use. (...)
From the BRZ Specs page on the Subaru Website:
"Fuel requirement: Premium unleaded gasoline (91 octane). Recommended: 93 octane."
I will let you go, Ricky. But first, I want you to say..."I... love... crepes."
Sonex51 is offline   Reply With Quote
Old 05-28-2012, 06:40 AM   #11
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Drives: BRZ Premium 6MT (SWP)
The owner's manual recommends 91 (at least that's what printed in mine).
I live in Southern California, and I can't even buy 93, so the point was kinda moot.
Symbiont is offline   Reply With Quote
Old 05-28-2012, 11:26 AM   #12
Fish
Fish's Avatar
I remember someone telling me that premium in other countries is different than premium in the US. So their 93+ is probably rated differently to our 91 premium here.
Old 05-28-2012, 11:58 AM   #13
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
97 RON = 92-93 AKI, at least according to Wikipedia.
You're most likely thinking of RON vs. AKI octane ratings.
Subie is offline   Reply With Quote
Old 05-28-2012, 12:14 PM   #14
Fish
Fish's Avatar
Thanks Subie. I couldn't remember what it was they told me, I'm pretty sure that was it though.
Fuel Additives ArKiTeCkT Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 40 06-13-2012 03:26 AM
Fuel Filler is on the Right!! Guaruja Scion FR-S / Toyota 86 GT86 General Forum 43 04-01-2012 05:55 PM
Premium Fuel riceracer8888 Scion FR-S / Toyota 86 GT86 General Forum 64 12-16-2011 10:27 AM
E85 Fuel? Siriusly.Andrew Scion FR-S / Toyota 86 GT86 General Forum 60 02-11-2010 05:00 PM
Flex Fuel? VenomRush Scion FR-S / Toyota 86 GT86 General Forum 12 01-15-2010 02:55 AM
