Old 09-10-2012, 01:12 PM   #15
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
I don't think you can recover the amount you spend on the gears or final drive in gas savings
You can recover the amount in sheer fun factor if you change the gears out not considering a change in mpg
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 09-10-2012, 01:21 PM   #16
Wes B.
Automotive Enthusiast
Wes B.'s Avatar
Valid point. Maybe I am making a mountain out of a molehill.
Wes B. is offline   Reply With Quote
Old 09-10-2012, 01:33 PM   #17
ngabdala
And you might not be. The automatic gets way better mpg because of a taller 6th gear. I don't know enough to say whether or not something else/more economical can be done. Keep asking man
The Following User Says Thank You to ngabdala For This Useful Post:
Wes B. (09-10-2012)
Old 09-10-2012, 01:45 PM   #18
Wes B.
Wes B.'s Avatar
True. I really hope a company does come out with a 6th gear replacement. There is absolutely no reason why one can't both enjoy the sportiness that this coupe was designed for and the fuel efficiency that comes from using such a small displacement engine.
Old 09-10-2012, 08:35 PM   #19
TonyJZX
Drives: VN Commode
sure anything can be done with enough money
and the reality is that one gear wont be that expensive
i mean if you're that invested you can get an engineering firm to make you a replacement gear in the size you want
however the sheer downtime and getting someone who knows manual boxes to open it up and the ensuing potential warranty issues
the easier way would be to look at replacing the final drive with something a bit taller
apparently they are the same as the Lexus IS200/300 etc.
i dont think it would adversely affect acceleration too much but that's where research comes in
TonyJZX is offline   Reply With Quote
Old 09-11-2012, 11:22 AM   #20
Wes B.
Wes B.'s Avatar
Opening the transmission and replacing the gear is no problem. The problem would be getting the gear.
The problem with the final drive is that I'd need a pretty tall final drive to give me the overall ratio that I want. That, in turn, would drastically hurt acceleration.
Old 09-11-2012, 12:21 PM   #21
zooki
Drives: waiting on a 2021...
I would think that a taller rear gear would work better in boosted applications. The more torque you have, the less gear you need, and it would help fuel economy too, I believe. Maybe after the car's been out a while and people start getting more power out of them the market will offer different gear sets.
zooki is offline   Reply With Quote
Old 09-11-2012, 12:28 PM   #22
Wes B.
Wes B.'s Avatar
True, but by the time one boosts their car and slaps on a taller final drive, compensation takes place. You take a little from here, add a little there, and you're back to where you were in the beginning (performance-wise). It's a lot of work for little payoff.
The benefit of simply swapping out 6th gear is that you aren't sacrificing performance for fuel efficiency. Rather, you have both with one simple addition.
Old 09-11-2012, 12:57 PM   #23
SkullWorks
Drives: SSM LT MT BRZ
you guys are funny, I get 20 to 22 MPG, best I got was 30 on break in road trip and that was only on one tank, the other 2 or 3 tanks I got about 27.
I'd love to see what people think spirited driving is...I habitually keep the rpm above 4, unless im already at speed on the fwy there's no go anywhere else.
Honestly I can relate to the OP's POV though at 80mph (fwy speed afaiac) the motor is turning 3500
Old 09-11-2012, 01:02 PM   #24
Wes B.
Wes B.'s Avatar
It's not that I am against spirited driving. I love thrashing this car around the bends, but when I'm on the highway at 75-80 mph, I'd love it if it would rev below 3,000 rpm.
I'm simply trying to have the best of both worlds.
Old 09-11-2012, 01:56 PM   #25
BPAuto
BPAuto's Avatar
Drives: GT-R, S2000, Evo VIII-X, BRZ, FRS+
There are multiple brands with track tested final drive sets and differentials available from Japan.
From AutoFactory, Arrows, Max Racing, and more.
Visit our Driveline Catalog and look for our weekly update tomorrow with new limited slip differentials, final drive kits, and more!
Click here for the Thread
BPAuto is offline   Reply With Quote
Old 09-11-2012, 01:58 PM   #26
SkullWorks
really, you already got linked in this thread...and you were already asked this question in your thread...and didn't even bother to respond.
The Following User Says Thank You to SkullWorks For This Useful Post:
Wes B. (09-11-2012)
Old 09-11-2012, 02:06 PM   #27
Wes B.
Wes B.'s Avatar
As of right now, I'm not looking to replace the final drive or rear differential. I am looking for a taller 6th gear replacement.
The Following User Says Thank You to Wes B. For This Useful Post:
Rurounimidnight (09-21-2012)
Old 09-21-2012, 05:22 AM   #28
frusciantrix
Drives: Mini R56 JCW
A gearbox shop can mill the 6th gear or turn a new one.
It's not very uncommon to do this in Germany since many cars from Japan have this overdrive gear which destroys fuel economy on the autobahn (you tend to always drive in 5th gear because 6th has too low rpm).
frusciantrix is offline   Reply With Quote
aftermarket gear set, close ratio, dog engagement, quaife, trd
Straight from Japan: Motorfan 86 BRZ Magazine Sets! ksin86 Miscellaneous 1 08-27-2020 03:18 PM
Bespoke radio, 3 sets of RCAs? -max- Electronics | Audio | NAV | Infotainment 13 10-21-2017 06:09 PM
What's the weight on the passenger seat sensor? Iphone sets off airbag/seatbelt chime NeedsmoreCowbell Scion FR-S / Toyota 86 GT86 General Forum 67 03-28-2013 12:21 PM
Aftermarket Seats sets off SRS light? Hanakuso Cosmetic Modification (Interior/Exterior/Lighting) 1 08-25-2012 05:09 PM
