| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#57 |
what do you mean by more poke/suck?
#58 |
Stretched tires are all the fad but not kosher.
#59 |
Ontario's FT86
Drives: 2016 Lexus GS-F
Can some one give me some insight if 18x9.5 +45 will fit in the front??
Really appreciated! |
#60 |
Drives: CBS BRZ Limited 6MT
17x8 +35 on stock tire?
Back in (Crystal) Black.
#61 |
Wether the offset will cause the tire to "poke" out of the wheel well more or "suck" it in further.
#62 | |
VehicleDynamicsSpecialist
Drives: iG FR-S
I believe you will rub on the strut/coil.
"The best track modification you can ever make is between the steering wheel and seat." - CSH |
#63 |
Drives: iG FR-S
| The Following User Says Thank You to ill86 For This Useful Post: | zohare (01-17-2013) |
#64 |
http://www.discounttiredirect.com/di...7.5&vid=022416
DR-34s 17x7.5 on stock tire with either a 42 or 45mm offset
#65 |
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
Will someone confirm if the following will fit? Looking for function over aesthetics even with limiting myself to street driving
Ive seen some people do 235s on 8" wheels; wanted to see if 245s will work too. From my estimation the below will still clock in slightly below OEM tire/wheel weight. Although I see 235s weighing up to 2lb less, 235/40R17 is just not a common size. * Stock suspension. Coil overs to lower are an option around 60k miles or so when my stock suspension wears out. * stock engine. No plans ever to mod engine for power * stock brakes. Pads and brake lines will be replaced later * Weds Tc105n 17x8 +42 square setup * 245/40R17 tires, probably the hankook Venus v12 Evo K110 (a mouthful) or dunlop star spec * Hub centric rings Another question, does tire rack list tire weights with air or is it just material? |
#66 | |
Drives: Whiteout FR-S
| The Following User Says Thank You to JoeBoxer For This Useful Post: | F1point4 (09-10-2012) |
#67 | |
Drives: iG FR-S
225 or 235 is ideal on an 8. 215 & 245 will also work fine.
| The Following User Says Thank You to ill86 For This Useful Post: | F1point4 (09-10-2012) |
#68 |
I would think it would cause the sidewalls to be pretty flexible and "roll over" during hard cornering but if you say thats not the case I will agree. No problem admitting it when i'm wrong lol.
#69 |
Drives: iG FR-S
I wouldn't say your wrong .. Just maybe a difference of opinion/preference.
But, no, it doesn't roll over. :happy0180: ultimately depends on tire selection.
| The Following User Says Thank You to ill86 For This Useful Post: | JoeBoxer (09-10-2012) |
#70 |
What size tire do you guys recommend for a 17x7.5 wheel with a 42 or 45mm offset? Any brands?
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
