Old 09-05-2012, 01:18 AM   #1
michael317
michael317's Avatar
Drives: BRZ Limited
BRZ smart access customization (unlocking all doors)
If you have a BRZ with samrt access. you all know that the key only unlock the door that you are approaching (default setting). i have read throught the owners manual and it tell you to go to the dealer to perform custom setting to your desire. Well as being a tech at a lexus and seeing this car is mostly toyota influence including the smart access. I tried something with the remote to see if it works on a subaru smart access like it does with lexus. And yes it does work so i will pass it on to fellow BRZ with smart access so you dont have to drive to the dealer to get it done or be charge with it (lexus we do it for free the first time on all customization and will charge after, not sure how subaru does it.) To Unlock both doors when approaching the driver door. be inside the car key off (dont push the start button) hold lock and unlock button for at least 30 seconds and you will hear the door lock responding. once you hear that go outside lock the door and pull on the door handle to see if both doors unlock. There are a few settings but it should not take you more than twice to get the right set up. settings will eventaully cycle through if you do it a few times. It only took me 1 time to get the setting i want. Hope this helps
my setting is at both doors unlock when i approach either doors.
michael317 is offline   Reply With Quote
The Following 29 Users Say Thank You to michael317 For This Useful Post:
C4RBON (09-09-2014), codesplice (04-28-2014), crank (12-20-2012), Deepseadiver (03-04-2013), Die$eL (04-04-2014), dori. (09-06-2012), fasteddy (09-05-2012), gmookher (09-06-2012), GotBRZ1691 (09-04-2014), Hyper4mance2k (05-07-2015), Jfheisenberg (06-28-2015), kevinnivek8877 (09-05-2012), kgc (09-06-2012), kludger (11-08-2012), levifig (05-03-2014), loogs (08-13-2013), LXXXV1 (07-23-2014), mou (04-30-2013), Nardi330 (09-05-2012), neutron256 (09-05-2012), Ouhei (01-19-2014), ranisron (09-08-2012), rawbz (09-06-2012), Shaun. (05-04-2013), SkullWorks (09-06-2012), Turbowned (09-07-2012), willypongtb (09-03-2014), WRB5titch (09-02-2014), zoomzoomers (09-05-2012)
Old 09-05-2012, 02:52 AM   #2
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
That's awesome. Even though I will most likely be getting an FR-S, That is still great to know. Thanks
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 09-05-2012, 08:57 AM   #3
Hix
Hix's Avatar
Drives: 2017 WRB PP
Hmm all I did was open the door and hold unlock for 10 seconds and it changed.
Hix is offline   Reply With Quote
The Following 2 Users Say Thank You to Hix For This Useful Post:
PollosHermanos (01-04-2014), xjohnx (09-05-2012)
Old 09-05-2012, 09:04 AM   #4
xjohnx
Grip>Slip
xjohnx's Avatar
yep. there are a bunch of posts on this.
Trap63 (08-30-2014)
Old 09-05-2012, 09:53 AM   #5
proficience
proficience's Avatar
Drives: Velocity Orange 86 GTS M/T
Is there any way to disable/enable the car beeping when doors lock/unlock?
Our AUDM cars don't beep and its pretty annoying
proficience is offline   Reply With Quote
Old 09-05-2012, 10:18 AM   #6
xjohnx
Grip>Slip
xjohnx's Avatar
Your dealer should be able to turn that on via TechStream.
Trap63 (08-30-2014)
Old 09-05-2012, 07:12 PM   #7
proficience
Yep, I thought they had a mechanism to do that... but they had no idea when I asked them during my 1000k inspection. Do other Toyotas (i.e. Camrys/Corollas) have this sort of function? If so
Old 09-05-2012, 08:42 PM   #8
Nardi330
Nardi330's Avatar
Drives: 86
I think the aussie dealers are either too lazy or incompetence.
i asked about having the interior light not turned on when you get close to the car but they said it can't be done although the manual clearly said it can.
Nardi330 is offline   Reply With Quote
The Following User Says Thank You to Nardi330 For This Useful Post:
Surok (09-06-2012)
Old 09-05-2012, 09:41 PM   #9
xjohnx
Grip>Slip
xjohnx's Avatar
yep, it's pretty standard. tell them it's a customization set via techstream.
Or if you're the tech type, you can buy the USB cable on ebay and a lot of those will come with bootleg copies of techstream, so you can do it yourself.
Trap63 (08-30-2014)
Old 09-05-2012, 09:53 PM   #10
proficience
I found one on ebay here
Do you know what other things you can configure with Techstream? I have a few things in mind that would be great!
  • power folding mirrors linked to the ignition..
  • preventing the DRLs from dimming when in parkers/low beams modes
  • DRLs linked to the proximity key detection area (i.e. DRLs come on when dome lights first come on instead of waiting for handbrake down)
  • auto-locking when key is out of the detection zone
  • auto-locking at >30km/h etc
  • 'Guide me home' low beams that stay on for a few minutes after car is turned off
  • automatic door unlock when car is turned off
  • automatic window closing on lock
  • Beeps when car is locked/unlocked
  • automatic left-mirror parking assist on reverse selection
EDIT: also where is the OBDII port on these cars? should be <2feet away from the steering wheel right? I'll have a crawl under soon...
EDIT2: I found your thread . Thanks for the info there. I'll look into getting one and seeing what it can do. They are pretty cheap.
The Following User Says Thank You to proficience For This Useful Post:
Surok (09-06-2012)
Old 09-06-2012, 02:47 AM   #11
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
thanks, was wondering about that
dori. is offline   Reply With Quote
Old 09-06-2012, 03:30 AM   #12
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
Ahh great! i need the auto locking >30kph thing!
Surok is offline   Reply With Quote
Old 09-06-2012, 06:50 AM   #13
proficience
Just realised this whole thread is in the wrong section. But ah well...
Does anyone have anything like this but for the FR-S/BR-Z/86?
http://www.tundrasolutions.com/forum...lectronics.pdf
It's basically a list of allll the customisable electronics settings for the tundra, through techstream interface...
Old 09-06-2012, 02:43 PM   #14
hyper4mance
hyper4mance's Avatar
Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
To clarify this is all done (lock/unlock) with the remote?
hyper4mance is offline   Reply With Quote
Caliper Paint w/emblem Customization Kimsey47 Cosmetic Modification (Interior/Exterior/Lighting) 24 10-06-2012 03:08 PM
Scion, where are all of the customization options? cassidy0998 Scion FR-S / Toyota 86 GT86 General Forum 6 06-10-2012 06:56 PM
Anyone in Portland area have access to CNC milling? DarrenDriven Northwest 2 06-09-2012 02:36 AM
Signature Customization Thread CSSM FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 123 05-12-2012 04:32 AM
Keyless access option on limited brzninja BRZ First-Gen (2012+) — General Topics 25 04-12-2012 07:49 AM
