Old 09-05-2012, 02:51 PM   #15
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
The page on japan parts is claiming (probably on behalf of the manufacturer) that you don't need a tune with this thing.
http://www.japanparts.com/db/parts_d...&SEARCH_page=1
Not so sure about that one.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 09-05-2012, 06:17 PM   #16
Turdinator
Señor Member
Turdinator's Avatar
Yeah the throttle should just be plug and play. No tune required. But unless the stock throttle is a restriction you won't see any gains at WOT. What you will feel is greater response as for any given amount of throttle it will allow more air in the engine. But at some point that will max out eg. at 75% throttle opening it will flow as much as the engine can suck in, so over the last 25% throttle there is no change in acceleration.
1974 TA22 Celica
2013 86 GT
Cusco Throttle Body? track_warrior Engine, Exhaust, Transmission 66 06-28-2016 06:28 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 07:44 PM
Throttle Controllers harajukukei Engine, Exhaust, Transmission 31 07-28-2012 12:40 AM
Cusco Rear Diff Covers!!! Cusco LSD Units! vividracing Transmission and Driveline 0 06-18-2012 03:24 PM
