Old 08-30-2012, 08:06 PM   #15
Duo
Drives: 86 pending move
Originally Posted by Scooby South View Post
No...the Stockers will work...I have plates on the front and the stockers on the rear...
Camber set at -2.5 zero toe front
Camber set rear -1.75, 1/16th toe in
I will have to dig it out of the garage ..(in the attic)
17x9 with a 42. 245/40/17 Hankook RS-3's... I will be running in ST Class.. either STX or STR... the car with Coilovers can easily fit 265's if needed...probably will go up to a 255 for the extra gearing... topping out right now at 59.6 in 2nd.. so should easily be 61 or so with a bit taller tire.. 255/40/17
Bill
How much clearance do you have up front between the tire and strut at negative 2.5 camber? I have 17x9 wheels coming in but still haven't decided on whether to go 235 or 245 cause I don't have a car to measure against. Planning on getting Star Specs.
Motorsports: Because basketball, baseball, and football only require one ball.
Duo is offline   Reply With Quote
Old 08-30-2012, 08:38 PM   #16
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
^^^about 2inches in other words..With coilovers..I have NO clearance issues at all...go with the 245's...better gearing..
Bill
Scooby South is offline   Reply With Quote
The Following User Says Thank You to Scooby South For This Useful Post:
Duo (08-30-2012)
Old 08-30-2012, 08:41 PM   #17
Duo
Thank you, sir, for clearing that up for me! Now about that PM, when is the best time for me to contact you bout that box's dimensions?
Old 08-30-2012, 08:47 PM   #18
Scooby South
Conedancer
probably this weekend sometime..
Old 08-30-2012, 08:56 PM   #19
Scooby South
Conedancer
current Setup/look as of last weekend..
SkAsphalt (09-04-2012)
Old 08-31-2012, 02:59 AM   #20
Nardi330
Nardi330's Avatar
Drives: 86
i must get some V3 now. thanks for your info.
Nardi330 is offline   Reply With Quote
Old 08-31-2012, 07:21 AM   #21
driver01
Drives: brz 13
Whats the drop that the kw v3 comes with from factory. I mean if i installed them out of the box, what would the drop be?
driver01 is offline   Reply With Quote
Old 08-31-2012, 08:27 AM   #22
Scooby South
Conedancer
not sure... I don't think they were at any particular height... Basically I counted threads... I remember going up on the rears quite a bit..like 15 threads.. the front I went up just a bit.. I am a firm believer of parallel arms and other components.. so I adjusted to achieve that.. then fine tuned the rake and alignment...
ALIGNMENT is critical on these cars.. they are very sensitive to the correct attitude on the alignment... to little..they skate all over the place.. to much..they won't turn that well..
Bill
Old 08-31-2012, 09:33 AM   #23
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
The minimum drop is 20MM. I just installed these on my car yesterday! I also have the same wheel/tire specs as featured car (But I have Grids and he has DPT). I went with the 245/40/17 because it's exactly the same height as the stock 215/45/17.
Old 08-31-2012, 11:54 AM   #24
driver01
Drives: brz 13
Bill
Alignment wise, what would you recommend as starting point. I do lapping days mostly. Not a lot of autocross.
Curretly i am runnin front -2.5 camber 0 tor
Rear -1.8 camber (i want to run 1.5, hoever limited by stock toe adjustor) 0toe
Old 08-31-2012, 01:21 PM   #25
Scooby South
Conedancer
with Zero toe in the rear...the car Skates all over the place.. I would at least put a 16th on each side.. that settles it down tremendously
Bill
The Following 2 Users Say Thank You to Scooby South For This Useful Post:
Im_SPEED (09-06-2012), RAYSSPL (09-05-2012)
Old 09-03-2012, 02:34 AM   #26
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
I just bought the KW V3's from @DarrenDriven. I've only put a few miles on them and so far the initial impressions for a daily driver set up are good. I had Tein H-Techs installed and they were kind of harsh and bouncy, not too bad but once these were on I am noticing a better ride with a bigger drop.
I haven't adjusted anything yet and will ride the factory settings for a week or two so I can figure things out. I'm not planning on taking my car to the track until next season so I am trying to dial in a setup for daily driving. The specs for where my car currently sits is in the first post of this thread. With my current wheel and tire setup I am rubbing on the rears when cornering and over bumps and will either roll the fenders more or just raise it up a bit. The rubbing is not digging into the tire so lifting it up an 1/8" may fix it. I am also thinking if I go to a hard setting I may get rid of the rub this way too.
I have about 3/8" left to go down in the front and want to do it but until the Five:AD lip kit is reinstalled I am going to play it safe. The Five:AD front lip is going to kill me on approach angle.
digital_assassin is offline   Reply With Quote
Old 09-05-2012, 05:34 PM   #27
RAYSSPL
Drives: bicycle
I may have missed it, but how much do the KW V3's usually go for the FRS/BRZ? Thanks in advance
RAYSSPL is offline   Reply With Quote
Old 09-05-2012, 05:37 PM   #28
schtebie
Drives: CBS BRZ Limited
MSRP is $2299. Price will vary depending on where you buy them.
schtebie is offline   Reply With Quote
The Following User Says Thank You to schtebie For This Useful Post:
RAYSSPL (09-06-2012)
BRZ/FR-S Suspension Options List (Springs and Coilovers) WingsofWar Suspension | Chassis | Brakes -- Sponsored by 949 Racing 333 02-01-2022 05:32 PM
Suspension Review: Eibach Pro-Kit Lowering Springs DarrenDriven Suspension | Chassis | Brakes -- Sponsored by 949 Racing 136 10-09-2020 06:26 PM
Suspension Review: Eibach Sportline Lowering Springs DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 129 07-23-2019 09:59 PM
Suspension Review: Hotchkis Sport Springs Nitro22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 43 02-23-2016 06:01 PM
Suspension / Coilovers ~ How to Choose the Right Setup for YOU Circuit Motorsports Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 09-24-2015 01:53 PM
