-   Suspension | Chassis | Brakes -- Sponsored by 949 Racing (https://www.ft86club.com/forums/forumdisplay.php?f=59)
-   -   Suspension Review: KW v3 Coilovers (https://www.ft86club.com/forums/showthread.php?t=16068)
DarrenDriven 08-30-2012 11:25 AM
Lifted from another topic...
Installation note: When installing these KWs we measured the amount of exposed threads below the lower spring collar to determine where to set the coilovers for future installations.
Front: 3/8" remaining thread = 1 9/16" drop
...12 7/8" distance from fender to center of hub (14 7/16" stock height)
Rear: 2 1/8" remaining thread = 2 1/4" drop
...12 3/8" distance from fender to center of hub (14 5/8" stock height)
Originally Posted by Scooby South (Post 285526)
Bliss is getting a great package from FEDEX...and then looking forward to putting on something to make a difference..:).. Thanks StranoParts...:)
https://sphotos.xx.fbcdn.net/hphotos...30205499_n.jpg
https://sphotos.xx.fbcdn.net/hphotos...29098954_n.jpg
https://sphotos.xx.fbcdn.net/hphotos...26605238_n.jpg
https://sphotos.xx.fbcdn.net/hphotos...76893885_n.jpg
https://sphotos.xx.fbcdn.net/hphotos...14656839_n.jpg
going to wait til after work tomorrow night to install...that way I can read the manual...and study what I need to do...I wanted to install them tonight...but I wanted to make sure I get these absolutely perfect..:)
Bill
Originally Posted by Scooby South (Post 289520)
ok....KW's are ON...OMG...it is a sexy beast and man is it 'PLANTED'..... There is at least an inch of clearance between the tire and the Strut... sooo Camber isn't going to be an issue...AT ALL.. will easily fit 265's..if needed... So...STX...STR.....BRING IT...Its amazing how much Decent suspension does to a car...Installation...I give a 6...the front was no problem..however the ABS and Brake line is routed kinda funky..but I adapted and overcame the Rear.. was a bit more stubborn...but I got it...finally.. Stock 14mm rear sway is on now..with Kartboy links..running Recommended settings for now.. went on a short 'test' drive... I can't wait to get this thing on the course now......I LOVE the KW's...easy to tune... and pretty easy to adjust....I was going to have an event tomorrow but I didn't get to the alignment ...so Monday after work...then I also need to corner weight it.....so far...I am absolutely Beyond pleased with the KW's...They Got it right....On to the pics..
Stock Front Strut assembly....12.6 lbs...
KW Front Strut assembly... 12.9 lbs...
https://sphotos.xx.fbcdn.net/hphotos...91150355_n.jpg
Fronts.... adjusting the ride height..:)
https://sphotos.xx.fbcdn.net/hphotos...36886079_n.jpg
Front ...After adjustment...about a 1 inch gap between the top of the tire and fender... Coool thing of note...All 4 fenders are Factory Rolled..so nooo issue whatsoever with fitment...
https://sphotos.xx.fbcdn.net/hphotos...27082319_n.jpg
Obligatory Side shot..:)
https://sphotos.xx.fbcdn.net/hphotos...86670532_n.jpg
and...the Side Profile shot...soooo Sexy..:)
https://sphotos.xx.fbcdn.net/hphotos...55755091_n.jpg
Can't wait for Cent Divs Next week in Milwaukee.... running up our good buddy Neal Tovsen...and his wife in STX...should be interesting..:) ...we'll see how it does against a well prepped Bimmer..:)
More later
Bill
VSGTS14 08-30-2012 11:27 AM
perfect stance with a great coilover.
DarrenDriven 08-30-2012 11:27 AM
Still lifted...
Scooby South 08-30-2012 01:27 PM
Hello all.. I am the one that owns the car above...Thanks Darren..
Questions??
VSGTS14 08-30-2012 01:35 PM
yes, do the kws come with their own top hats?
BRZranger 08-30-2012 01:44 PM
Originally Posted by Scooby South (Post 412434)
Hello all.. I am the one that owns the car above...Thanks Darrin..
Questions??
How much lower are you?
What settings did you use for rebound/compression?
I have V3s also, and I love them. The ride does feel more "planted", but I will have to take some time to mess with the settings and fine tune it for my daily driving. I really like how adjustable it is.
I went about 1 3/4" lower, not sure if that is too much, but feels good right now. Supposedly going that low affects the suspension geometry drastically, requiring parts to compensate for the new roll center.
gmookher 08-30-2012 02:11 PM
bery nice
Duo 08-30-2012 02:48 PM
Questions??
This will seem like an odd question, but can you please tell/PM me the box's dimensions? Trying to figure something out.
Apex Chase 08-30-2012 04:03 PM
Questions??
Sweet set up! What are the specs on you wheels and tires?
FT-86 SpeedFactory 08-30-2012 04:08 PM
Awesome set of coils enjoy them. :)
You going to be at nationals?
jamal 08-30-2012 04:17 PM
No. They work with the stock tops, or you can get aftermarket plates for them. KW does make tops for some of their motorsports stuff but it is usually better to just use something else. RCE/GTworx and Vorshlag both have nice tops.
VSGTS14 08-30-2012 04:34 PM
that's what i wanted to know, thanks man. i have vorshalg on my sti, they are nice!
Scooby South 08-30-2012 07:52 PM
No...the Stockers will work...I have plates on the front and the stockers on the rear...
Camber set at -2.5 zero toe front
Camber set rear -1.75, 1/16th toe in
Mine measures from the bottom of the rim to the arch in the fender...23" front 23 1/4" rear..
Pretty much went with the Stock Settings from the factory in the Setup guide and adjusted from there..
Everybody has a different opinion on where to setup the car... It really is a personal preference... I kinda like a little bit of tightness..so I set up my car accordingly.. What works for me might not be the best option for you... :) start with the factory settings... then learn to adjust from there..
Originally Posted by gmookher (Post 412529)
bery nice
Danka..:)
I will have to dig it out of the garage ..(in the attic)
17x9 with a 42. 245/40/17 Hankook RS-3's... I will be running in ST Class.. either STX or STR... the car with Coilovers can easily fit 265's if needed...probably will go up to a 255 for the extra gearing... topping out right now at 59.6 in 2nd.. so should easily be 61 or so with a bit taller tire.. 255/40/17
Not this year.... Not Classed yet...After Nats it will be then Next year making a full assault on ST* whatever class..:)
Bill
