| CANADA Canada |
#15 |
Drives: Raven Black
For an apples to oranges comparison:
My Honda CBR600RR has an 18 litre tank. I get about 220km before the fuel lite comes on. I fill up and put in about 14 litres. about 20% fule capacity left for the FR-S gas light coming on and filling up with about 40 litres means it also comes on with about 20% fuel capacity left |
#16 | ||
Drives: Subaru BRZ
I'm averaging about 7.5L/100km so I would imagine that 700km a tank is easy to obtain. I actually switched to 91 Shell and the mileage seems to be better (compared to Ultra 94). Have to see by the end of the week. Oh, and the chirping is gone, too.
Bryan.
#17 |
Drives: Ultramarine Blue
When I fill up immediately after the light goes on, the gas pump always reads 40L so theres 10L left. Huge contrast to my 91 e30 I had years ago where I learned the hard way that empty really means empty!
#18 | |
Drives: 2013 Whiteout FR-S MT
In order for the engine to remain running, it is using gas... |
#19 |
Drives: Subaru BRZ
^ As Mythbusters would say - Warning: Science Content.
![]() http://www.popularmechanics.com/cars...l-fuel-economy
Bryan.
#20 | |
When you clutch in and coast, the engine is using fuel to keep it idling. When you coast in gear, the engine is not using any fuel because the wheels are keeping the engine running. |
#21 | |
Basically the ecu knows when you've removed your foot from the accelerator, that you're in gear and that the car is traveling at sufficient speed (& engine rpm) that the momentum of the car will keep the engine (& all its accessories) turning over without having to inject fuel to keep combustion going. If the rpms drop enough (to the point where you'd otherwise stall), or you step on the accelerator or clutch, the engine instantaneously starts injecting fuel again, combustion resumes and everything works as it should. If you pay close attention to the car you can often 'feel' when the fuel cuts out and when it kicks in again. |
#22 |
Wow, thanks a lot for the info guys.
Apparently I haven't been keeping up with the times, lol. |
#23 |
Drives: Scion FRS Ht Lva(AT)
Best I have measured so far is 5.7L/100km which was 100% highway driving. I am sure that at least 5.6 should be possible, but you have to drive very carefully and ensure no heavy footedness and keep the speed lower: 80-100 kmph.
#24 |
Drives: 2011 Outlander XLS, 2013 FR-S Blue
You guys have the wrong car. If I'm under 10L/100 I'm mad.
#25 |
too nuts
Drives: Scion FR-S
Great info I actually thought coasting in neutral was a good idea
#26 |
Drives: fr-s
any idea on how many liters left when the tank signal turn on ?
#27 | |
Drives: BRZ!
qft... AND... I almost always fill up with over a quarter of tank left... Enough fuel in the tank cools down the fuel pump...
#28 |
Canadian
Drives: Frieda: Firestorm/MT (11/28/2012)
I was going to say. The guy with 7.5L/100km? I am averaging 9.1L in my 2010 Cobalt 4AT (2.2L NA base model piece of garbage). The fuelly average is 7.8 for that car and I think a lot of those are with the 260hp TC 2.0L engine. I will be happy if the FR-S is under 10.
| Gas mileage for first tank | terrypm | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 01-23-2017 03:10 AM |
| Dynosty Pushing the Limits... Fuel Pump and Clutch | Dustin@Dynosty | Engine, Exhaust, Transmission | 29 | 08-15-2012 07:53 PM |
| Dealer Limit | blackfireball5 | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 06-29-2012 10:25 PM |
| Anyone else have problems with their windows after pushing the car too hard? | track_warrior | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 06-22-2012 12:39 AM |
