Old 09-04-2012, 12:31 PM   #29
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I would prefer something application specific as opposed to a universal one if any vendors are checking this thread...
Old 09-04-2012, 12:44 PM   #30
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Just want to get some clarity on this. I just received my Cusco Oil Catch. Is it actually functional or should I not open it and send back?
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 09-04-2012, 12:46 PM   #31
Apex Chase
El Presidente
Apex Chase's Avatar
Drives: it like I stole it!
Originally Posted by AVOturboworld View Post
On the turbocharged Subaru motors there was a lot of "blow-by", with a lot of oil being fed back into the breather line. Which feeds into the inlet pipe, and thus got routed back into the piston area. I've taken top mounts intercoolers off of 2 year old cars and literally poured the oil out of it.
Now, other than it looking nasty, it also increased detonation on those motors. Presumably that could be an issue with these 12:1 compression motors, but nobody has the mileage to determine how much.
I've got a couple of different breather catch tanks we make (different brackets for different models) so I'll probably fit one up. There is not many (if any) FR-S/BRZ specific catch tanks at this point, probably just adapted ones from the Turbo Subaru or Evo models. The typical older gen Subaru has two breather lines that T into one to the inlet - the FRisBee twins just have a single line from pcv straight to inlet. So one of the inlet ports will need to be blocked off.
Paul, I would love to see a FRS/BRZ specific set up from you guys. Do your systems use any sort of baffling?
Apex Chase is offline   Reply With Quote
Old 09-04-2012, 01:10 PM   #32
ngabdala
Paul will an Oil Catch come with the AVO turbo kit?
Old 09-04-2012, 01:33 PM   #33
AVOturboworld
We do use baffling in the system, nothing too complicated - but then, catch cans are not complicated technology.
Old 09-04-2012, 02:43 PM   #34
Visconti
Drives: 05 STi
Originally Posted by Memphis View Post
Is there a place to get a Crawford one?
Crawford will have them...
I'll also carry them because they're badass
Visconti is offline   Reply With Quote
Old 09-04-2012, 02:47 PM   #35
Jamifra
Jamifra's Avatar
Drives: 2013 Civic Si
Attachment 14435
they are really badass pieces but i think $300+ for a oil catch can is a little to much when you can have pieces with the same quality and do the same work for a lot less...my 2 cents.
Driving Style: Highly Spiritual, Sometimes Aggressive, Never Abusive
Jamifra is offline   Reply With Quote
Old 09-04-2012, 03:06 PM   #36
celica73
Um, yeah, if I'm going to spend money on oily cans with nipples attached, it sure as hell won't be what you guys are buying!
Old 09-04-2012, 07:00 PM   #37
Apex Chase
El Presidente
Apex Chase's Avatar
You might want to do some more research.
The Following 2 Users Say Thank You to Apex Chase For This Useful Post:
20valvewynn83 (09-07-2012), adprokid (11-02-2012)
Old 09-04-2012, 07:17 PM   #38
zoomzoomers
zoomzoomers's Avatar
Need some education on these. So they help prevent oil from returning the motor via the breather tube? How do they function in conjunction with oil coolers?
Old 09-04-2012, 07:24 PM   #39
Apex Chase
El Presidente
Apex Chase's Avatar
Modern engines feature a variety of emission control devices and systems to reduce the toxic gases released into the atmosphere. One of these is called the Positive Crankcase Ventilation (PCV) system. During the combustion process a small amount of gases leak or “blow-by” the piston rings and create a positive pressure in the crankcase. The PCV system vents these gases along with oil mist from the crankcase and routes it back into the intake manifold so it can be burned off. The problem is that over time the excess oil vapor collects along the inside of the intake tract and forms a “gunk”. This can lead to a variety of issues including carbon build up, retarded timing, detonation, and decreased performance.
A catch can or air-oil separator is a device that will condense and collect the oil vapor before it has a chance to reach the intake system. As the gases and oil vapor enter the can they typically pass through a screening mechanism that gives the oil vapor something to condense against. As the droplets form they drop harmlessly into the bottom of the reservoir so that they can later be drained or in some cases returned to the engine. The other gases are allowed to pass through so that they can be burned of as intended.
None of this has any interaction with an oil cooler.
The Following 3 Users Say Thank You to Apex Chase For This Useful Post:
TheMedakaBox (04-04-2016), WRB-DZA-BRZ (10-05-2012), zoomzoomers (09-05-2012)
Old 09-04-2012, 08:41 PM   #40
Turbowned
Turbowned's Avatar
I'm running a Cusco in my MR2. No idea how well it's working, but it looks purdy! You could always powdercoat the can if it's too blingy for your tastes. I feel like this part doesn't have to be too fancy to work, I.E. the Crawford one looks like overkill on an otherwise stock car.
I like the location of the Cusco; it's pretty out-of-the-way:
Old 09-04-2012, 08:48 PM   #41
wootwoot
Drives: FRS
I called Crawford today. They said the frs/brz specific can is on order with their fabricator but things are running slow right now and they are not sure when they will be available. At least they are on the way!
The Following User Says Thank You to wootwoot For This Useful Post:
Apex Chase (09-04-2012)
Old 09-04-2012, 09:05 PM   #42
JoeBoxer
JoeBoxer's Avatar
Has anybody running one actually had any accumulation in the can?
blow by, carbon build up, catch can, crawford catch can, radium catch can, saikou michi
Catch Can ArKiTeCkT Engine, Exhaust, Transmission 31 09-15-2013 03:07 PM
Oil Catch Can? eblamble3 Engine, Exhaust, Transmission 4 03-15-2013 10:58 AM
where to plug the oil catch can hose... :S dompower Engine, Exhaust, Transmission 29 11-14-2012 12:30 PM
Cusco Oil Catch Can for BRZ/FR-S at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 0 07-01-2012 03:16 AM
Purpose of oil catch can? denverizzles Engine, Exhaust, Transmission 1 06-28-2012 03:55 PM
