Old 09-04-2012, 08:21 AM   #15
CB762
CB762's Avatar
Drives: Scion FR-S
I have Cusco, it's just hollow can. I have it for for a while and don't see any trace of the oil yet. Will see after the track day.
CB762 is offline   Reply With Quote
Old 09-04-2012, 09:03 AM   #16
xwd
Crawford !!!
I used the Crawford on my turbo Subaru and it is the best AoS/catch can but I think the Grimmspeed AoS is probably okay with the amount of blowby on a NA motor.
For the turbo guys, definitely Crawford. No reason to look elsewhere imho.
Old 09-04-2012, 09:05 AM   #17
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Correct the Cusco is hollow. The Mishimoto is baffled.
[ame="http://www.youtube.com/watch?v=6vwt70YuOd0"]Mishimoto Engineering Behind the Scenes - From Concept to Completion - YouTube[/ame]
Catch cans are a pretty universal item though.
FT-86 SpeedFactory is offline   Reply With Quote
The Following 2 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
20valvewynn83 (09-07-2012), Tomzilla (10-18-2012)
Old 09-04-2012, 09:47 AM   #18
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
as someone said, if crawford makes one, that's the one to get...otherwise MOROSO is next in line for making a unit that actually WORKS.
the grimmspeed does nothing.
VSGTS14 is offline   Reply With Quote
The Following 2 Users Say Thank You to VSGTS14 For This Useful Post:
Crawford (09-11-2012), Visconti (09-04-2012)
Old 09-04-2012, 09:56 AM   #19
Visconti
Drives: 05 STi
Yup
It's also designed for the BRZ/FRS
Visconti is offline   Reply With Quote
Old 09-04-2012, 09:59 AM   #20
Memphis
Memphis's Avatar
Drives: Scion FantasticRoad-Sex
Is there a place to get a Crawford one?
Memphis is offline   Reply With Quote
Old 09-04-2012, 10:09 AM   #21
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
Can someone explain the purpose of a catch can?
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 09-04-2012, 10:11 AM   #22
Memphis
Memphis's Avatar
Basically it keeps oil from going into your intake and keeps it routed to the block. If you plan on doing auto-x or road course racing it is a good thing to get.
Old 09-04-2012, 10:16 AM   #23
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
This one is universal but I would check to see if it's compatible anyways as I am just learning about car mechanics.
http://store.crawfordperformance.com/store/products/334
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 09-04-2012, 10:19 AM   #24
Memphis
Memphis's Avatar
I saw that but was wondering the same thing.
Old 09-04-2012, 10:19 AM   #25
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
yea the universal should work. it's pretty simple since it's an NA motor.
Old 09-04-2012, 11:55 AM   #26
gmookher
so where does one get the oil cap that lets the oil back out of can into the block?
Old 09-04-2012, 12:08 PM   #27
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
In regard to how large the reservoir ought to be, how much oil are you users collecting with your driving habits?
Radium has been making some nice cans: https://radiumauto.com/index.php?p=p...id=28&parent=5
chulooz is offline   Reply With Quote
The Following User Says Thank You to chulooz For This Useful Post:
cobrabyte (09-04-2012)
Old 09-04-2012, 12:18 PM   #28
AVOturboworld
On the turbocharged Subaru motors there was a lot of "blow-by", with a lot of oil being fed back into the breather line. Which feeds into the inlet pipe, and thus got routed back into the piston area. I've taken top mounts intercoolers off of 2 year old cars and literally poured the oil out of it.
Now, other than it looking nasty, it also increased detonation on those motors. Presumably that could be an issue with these 12:1 compression motors, but nobody has the mileage to determine how much.
I've got a couple of different breather catch tanks we make (different brackets for different models) so I'll probably fit one up. There is not many (if any) FR-S/BRZ specific catch tanks at this point, probably just adapted ones from the Turbo Subaru or Evo models. The typical older gen Subaru has two breather lines that T into one to the inlet - the FRisBee twins just have a single line from pcv straight to inlet. So one of the inlet ports will need to be blocked off.
blow by, carbon build up, catch can, crawford catch can, radium catch can, saikou michi
Catch Can ArKiTeCkT Engine, Exhaust, Transmission 31 09-15-2013 03:07 PM
Oil Catch Can? eblamble3 Engine, Exhaust, Transmission 4 03-15-2013 10:58 AM
where to plug the oil catch can hose... :S dompower Engine, Exhaust, Transmission 29 11-14-2012 12:30 PM
Cusco Oil Catch Can for BRZ/FR-S at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 0 07-01-2012 03:16 AM
Purpose of oil catch can? denverizzles Engine, Exhaust, Transmission 1 06-28-2012 03:55 PM
