| FR-S / BRZ vs.... Area to discuss the FR-S/BRZ against its competitors [NO STREET RACING] |
#1275 | |
Drives: 2013"Road scalpel"FR-S MT
![]() I do think its the best handling car at its price point. I think theres a lot of jealous people out there that envy our supercar like handling, And feel need to post garbage to make up for there numb,sloppy handling car. This car is not about all out speed,its about FUN to drive. I bet some minivans can beat it in a drag race. ALl I know is in a tight course where a 370z is going to be struggling to get the power down, Theres going to be a frs passing him mid corner.
#1276 |
You mean all minivans can beat it in a drag race
![]() Do I care? I can make that poor bastard whose wife made him trade the sports car for the Sienna feel good when he can dust me at a stoplight, lol. Those things are fekkin' fast for minivans, too!
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
#1277 | |
#1278 |
Because it takes less than an hour to change four tires which are a wear item and relatively inexpensive. Engines are not a wear item, and they cost a lot of money. Not something the average enthusiast will do to their brand new car.
#1279 |
fine no engines. how about fuel, brake pads, shocks, and clutches? all wear and tear items
#1280 | |
Drives: Toyota Auris
fatoni, you wouldn't run an athletic event wearing boots, just because that's what you happened to wear that day; you would change them to running shoes, as everyone else's. Yes, tires are a wear item and in fact you're supposed to change them depending on the driving conditions (think winter/summer tires and, why not, race track). Judging a car's performance with under-performing tires is misleading, but maybe that's what you want? |
#1281 |
Glorious BRZ Master Race
Drives: Subaru Libird
Lol this thread should be re-titled "Circular argument for every little flaw that exists in the FR-S." Whenever I check in, I'm lost because the argument topic is always changing. If I read back a few posts I recognize the same base arguments being rephrased perpetually. A person who only loves apples will not love oranges. A person who only craves oranges will not be crave apples. If this car doesn't suit your tastes, you won't be happy with it. Let's just compare the cars stock-for-stock. If the FR-S is inferior, then it's inferior... TO YOU.
Somehow I feel like I've said this before in another way, shape, or form.
#1282 | |
Enjoy it, destroy it.
Drives: Datsun Racing Hen
#1283 | |
Drives: '13 BRZ Limited '10 370ZR
Do you mean faster around the Corkscrew at Laguna Seca or the Bus Stop at Watkins Glen. How far before corner entry do you start the timer and how far after exit do you stop it. From a standing or rolling start. What's the approach speed in your test? It's pointless to make such generalizations. Just say the 86 corners well and leave it at that.
2013 GBS Subaru BRZ Limited 6MT
2010 PG 370z Roadster: Sport/Touring 6MT |
| The Following User Says Thank You to Zaggeron For This Useful Post: | Turbowned (09-04-2012) |
#1284 | |
Drives: 370Z
#1285 | |
when you change things, things are changed. thats not fair. i understand using the same tires as a tool for evaluation, its just not fair to compare a modified car to a stock car. and if people seem to care so much about numbers i urge you to go buy the mustang gt as that thing is both cheaper and murders the frs in just about every type of performance driving. |
#1286 | |
Drives: Nevermorange FRS
I feel like I'm having deja vu? ![]() The wheel width and size is part of the car design holistically and as such changing tires should take into account stock wheel size/width. However the amount of "sticky" a tire has should be equal among all vehicles being compared otherwise, you're not doing a vehicle comparison, you're doing a tire test. If I wanted to compare the batting strength between two baseball players would I give one a metal bat and one a wooden bat and then compare the person? No, make the equipment equal so you can accurately compare the batter. Make the tire equal (brand/compound) so you can accurately compare the "Car". |
| The Following User Says Thank You to rice_classic For This Useful Post: | Turbowned (09-04-2012) |
#1287 | |
If you don't create a common variable between all three cars 370/rx8/FRS then the resulting information is misleading, at best. Subjects in testing: If I take a the RX8, 370z and FRS right off the show room floor and do skid pad tests to measure lateral g-force do you really know what I'm testing? Nothing. Why, because nothing about those cars is equal except for the fact they burn gasoline. You need each subject to have something in common that relates to what you're testing otherwise you're not actually testing anything.. you're just playing with yourself. The point of the test matters: What your testing matters! Are you testing top speed? Then tire compound isn't that important, but a speed governor is! So to test top speed between the 3 cars would you disable the governor? Of course you would. Are you testing lateral G's? Then tire compound is directly related (and speed governor not so) and thus the 3 subjects should be on the same compound for the sake of comparing "the car". In Racing: I race against an identically prepped CRX in ITA. If I go out on track on Toyo RA1's and he goes out on Hoosier R6's he will be consistently 1-2 seconds per lap faster than me at the very limit. Let's say (and this actually happened) he then makes huge changes to his suspension: Changes/removes sway bars, changes spring rates and changes shock settings.. He has actually now "changed the car". These changes to the car may have helped him with corner entry, apex speed or consistency but when we both go out because he's still on the R6 and I'm still on the RA1; he is still 1-2 seconds faster. The tire is THAT important. If I wanted to test my "setup" to his "setup" then we would need to be on equal tires. Ask NASA how well the first satellite to Mars worked out when one group did the measurements in Miles and the other group did the measurements in Kilometers? So why measure one car with 320 treadwear tires and another with 200 treadwear tires? Doing vehicle comparison tests where braking, accelerating or corning is part of the test and the equivalency of the tire are unaccounted for are a complete waste of time. |
| The Following User Says Thank You to rice_classic For This Useful Post: | Kunzite (09-05-2012) |
#1288 |
Finally, a voice of reason!!
By the way, anyone seen how the FR-S stacks up against the Z and RX-8 in C-stock auto-x? Yes, that's right, all three of these cars are in the same auto-x class. So let's all just be friends.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. Last edited by Turbowned; 09-04-2012 at 07:01 PM. |
| Tags |
| fanboi, lame |
| Nissan 370Z thread | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 116 | 04-07-2017 10:40 PM |
| FT 86 & 370Z similarities | blur | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 11 | 10-05-2010 12:39 AM |
