Old 08-30-2012, 12:07 PM   #197
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by jpit View Post
You torque it to 14.5 lbs and then turn it another 90 degrees. Comes out to about 95 lbs.
Please, no.
Per Perrin's instructions, the correct procedure is:
  1. Apply engine oil to crankshaft pulley bolt seat and threads. Tighten bolt to 33ft-lbs. Taking note of angle, tighten bolt to 94ft-lbs. During this final tightening, bolt should have tightened more than 45 degrees. If tightening angle is less than 45 degrees, replace bolt.
Old 08-30-2012, 01:21 PM   #198
jpit
Drives: Subaru BRZ
The BRZ engine manual states that you tightened the crank bolt to 14.8 lbs and then turn another 90 degrees.
jpit is offline   Reply With Quote
Old 08-30-2012, 01:51 PM   #199
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Originally Posted by VSGTS14 View Post
driveshaft is actually easier to install in my opinion, i've dropped my sti's before. it slides in one end, couple silly looking nuts/bolts for the diff connection.
with that in mind, i'll be buying perrin's pulley. anything agency power is garbage (vivid racing).
I've never changed a driveshaft, but I don't imagine it's all that hard. You do however need to get the car up in the air, and that alone raises the level of difficulty for your beginner mechanics.
Old 08-30-2012, 02:46 PM   #200
xjohnx
Grip>Slip
xjohnx's Avatar
It also assumes you're using the crankshaft pulley removal tool. Not many people are.
Old 08-30-2012, 04:31 PM   #201
mike2100
mike2100's Avatar
Drives: 23 BRZ
Originally Posted by Ozzy View Post
How is the daily drive-ability with lightweight crank pulley? Do the revs fall to quickly and require rev matching for downshifting?
It's fine, not that big of a difference really
mike2100 is offline   Reply With Quote
Old 09-01-2012, 10:06 AM   #202
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I put the Perrin pulley on my car yesterday, not sure if its because I have an auto or not but I probably wouldn't buy it again. Manual cars may "feel" a little better but I honestly can't tell much difference.
Old 09-01-2012, 10:30 AM   #203
travace
travace's Avatar
Drives: Scion FR-S
its just sitting here staring at me.poking its little face out the box as if to say HELLOOOO im over here dont you want to start using me ?
hopefully i can get some help on the install from some mechanic types i know real soon
travace is offline   Reply With Quote
Old 09-01-2012, 05:04 PM   #204
kwood9000
kwood9000's Avatar
Drives: Limited WRB AT6 BRZ
Might notice more of a difference when using the paddle shifters.
kwood9000 is offline   Reply With Quote
Old 09-01-2012, 07:41 PM   #205
neutron256
neutron256's Avatar
I agree I have an AT and I noticed th difference right away, but I pretty much always drive in Manual mode.
Old 09-01-2012, 07:53 PM   #206
zoomzoomers
zoomzoomers's Avatar
So you guys with AT's is the pulley worth while? I ask because I'll need to buy the pulley tool (costs $50) to install it. Due to the added cost of the tool, plus the hassle, I'm on the fence on buying it. Would like your opinions on it.
Old 09-01-2012, 07:58 PM   #207
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Think of it this way, charge people 5 bucks to use the wrench + majic = profit?
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 09-01-2012, 08:26 PM   #208
neutron256
neutron256's Avatar
Personally I think it's very worth it. And if you don't care about keeping the tool you could always resell it. I bet you would have no problem finding a buyer given the number of people on here who have asked to borrow/buy mine at a discounted price.
Old 09-07-2012, 05:04 PM   #209
Celica00
Celica00's Avatar
Drives: 86
instead of starting a new pulley thread.. after installing the perrin pulley my est. mpg went from 31-32 to 27-28. is that happening to anyone else? this is the only mod on my car so far so i'm guessing thats the culprit
Celica00 is offline   Reply With Quote
Old 09-07-2012, 05:11 PM   #210
mike2100
mike2100's Avatar
Drives: 23 BRZ
Oh and how do you think a lighter weight pulley is causing your engine to consume more fuel?
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
pulley installed issue Sall Issues | Warranty | Recalls / TSB 31 08-14-2012 11:36 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 07-07-2012 10:24 PM
