Old 08-31-2012, 06:35 PM   #15
gmookher
how does it run?
Old 08-31-2012, 07:27 PM   #16
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Originally Posted by gmookher View Post
how does it run?
I've put about 500 miles on my airaid intake and I only just today deleted the snorkel. It sounds good, I can't tell if you it adds any legitimate power but it does sound good. Deleting the snorkel seems to have changed the noise. Everyone will tell you it sounds best at high revs but this is simply not true. It sounds best at 50% throttle. Even if its only 2-3k RPM.
It makes a hilarious "BAHHHHHHHH" sound if you just go WOT in top gear. Lots of noise, no power
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
The Following User Says Thank You to Laika For This Useful Post:
AJUSA.com (09-04-2012)
Old 09-01-2012, 04:07 PM   #17
W2
W2's Avatar
Drives: Firestorm FR-S
how does it run?
Runs great with this setup, I also have about 500+ miles on mine now. I love the sound, much more aggressive than before. There does seem to be added power and slightly quicker/better throttle response.
W2 is offline   Reply With Quote
The Following User Says Thank You to W2 For This Useful Post:
Old 09-01-2012, 08:44 PM   #18
_F-R-S_
Drives: 13 whiteout scion frs
would this be even worth getting of the injen intake ?=
_F-R-S_ is offline   Reply With Quote
Old 09-04-2012, 07:22 PM   #19
AJUSA.com
AJUSA.com's Avatar
Great install thread. Thank you for sharing!
AJUSA.com is offline   Reply With Quote
Old 09-26-2012, 06:56 PM   #20
Burn
Slack Bum
Burn's Avatar
Drives: FT86
To W2:
Thanks for sharing this great thread and I've managed to take out the snorkel and the rest of the silly noise generating pipes.
Burn is offline   Reply With Quote
The Following User Says Thank You to Burn For This Useful Post:
W2 (07-12-2014)
Old 09-28-2012, 03:12 AM   #21
winsometang
Drives: Scion F-RS 2013 Asphalt MT
snorkel delete?
does the snorkel delete result in power increase on any aftermarket intake?
winsometang is offline   Reply With Quote
Old 09-28-2012, 01:41 PM   #22
winsometang
^ btw i have an injen intake
Old 10-03-2012, 05:09 PM   #23
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
I've read "slight" gains, but have not seen any info on how much. Hopefully worth while to justify snorkel removal
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 10-03-2012, 07:13 PM   #24
TAP Auto Parts
Drives: FRS
Snorkel delete has been shown to increase airflow up to 20% on a flowbench.
TAP Auto Parts is offline   Reply With Quote
The Following User Says Thank You to TAP Auto Parts For This Useful Post:
JPxM0Dz (10-04-2012)
Old 08-31-2013, 05:39 PM   #25
SciOnDrifTtSlIdeR
Drifter
Send a message via MSN to SciOnDrifTtSlIdeR
Great thread thanks for posting, my butt dyno says their I'd a bit of a gain, I get to fuel cut quicker in first for sure,
SciOnDrifTtSlIdeR is offline   Reply With Quote
Old 04-01-2014, 11:27 AM   #26
xlid007
Drives: Scion FRS
This has made a world of a difference. I installed the AFE intake but I didn't take out the snorkel since I didn't want to remove my front bumper. After seeing this thread I removed it following the instructions and it was very simple and straight forward. The easiest way to remove the bolts from the snorkel is with a 10mm wrench since the space is very limited.
Hats off to you sir for making this thread and the sound difference was night and day and I feel like the car breathes way better now and the butt dyno approves.
xlid007 is offline   Reply With Quote
Old 07-08-2014, 02:57 AM   #27
Junkwipe
Drives: Toyota Gt86
Sorry guys i have a question. Is not possible remove the snorkel from the side of intake? I tryed to pull out from the bumper but he doesn't pass, maybe if i unistall the airbox and than pull from the hole...
Junkwipe is offline   Reply With Quote
Old 02-03-2015, 06:24 PM   #28
Dohvak
Drives: 2013 Subaru BRZ Lmt, Silver
I put an airaid intake in, removed snorkel. I did love the sound difference. I had bad experience with it however: burnt out two sensors, after that I am back to stock.
The only thing I can figure might have any influence was that I did notice a lot of moisture accumulating in the airaid box. Just too much water in PDX I guess, will have to find a different air intake.
Dohvak is offline   Reply With Quote
Official AIRAID Intake System Feedback, Pictures Thread AIRAID Engine, Exhaust, Transmission 525 08-17-2014 04:20 AM
xcelir8brz's Stock Intake Tube Rubber Delete xcelir8brz DIY (Do-It-Yourself) Guides 99 04-09-2014 11:44 PM
AIRAID FR-S / BRZ Cold Air Intake system Sneak Peak / Development Information AIRAID Engine, Exhaust, Transmission 396 10-04-2012 07:27 AM
Airaid Intake System Official GB - The pre-order AJUSA.com Engine, Exhaust, Bolt-Ons 212 09-19-2012 06:36 PM
