#1 | ||
Web Designer/Programmer
Drives: WRB BRZ Limited (Lemon)
towed at 717miles CEL severe shaking (apparently a huge issue)
![]() waiting for tow atm. the car started to shake at each red light each time more viscous. I'll update when i find out what's up seems to be leaking something Update: I uploaded the Service Bulletin they're going to use for my BRZ and parts are on order More about this issue Unofficial - CEL/SL/Idle Issue List for FR-S/BRZ Owners Car at dealership, decided to give them the laundry list.. First Drive - CEL - Cam Sprocket Fix Check engine light just came on after 2k miles. CEL and SL on -My experience so far Cel issue Idle issue? First Check Engine Light and Traction control Towing guy bent my front bumper luckily I recorded it [ame="http://www.youtube.com/watch?v=bm3Y3gdxm_4&feature=share&list=UUltX9dajnc CCww6DxIV8luQ"]CEL first 717miles in BRZ limited - YouTube[/ame] Quote:
#2 |
Gangnam Style Guru
Drives: Suzuki GSXF650, WRB BRZ
#3 |
Drives: 2013 BRZ premium dgm
looks like water were you running ac, could just be condensate... won't explain the hesitation though hopefully nothing major good luck
#4 |
Yeah that's what I figured it was too. I didnt run ac too long i actually had it off most on the time. I turned it on for a minute or two before the engine light turned on. I took pics just in case
#5 |
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Umm the picture you have of the tachometer and speedometer with the check engine light on has all of the lights on meaning the picture was taken right when the car was started
#6 |
This thread is loaded under the warranty section of the forums.
#7 |
Drives: CBS BRZ Limited 6MT
I know what's wrong.....it's an automatic.
Back in (Crystal) Black.
#8 |
I Love custom Turbo kits
Drives: Limited BRZ
Most probably it was taken with the ignition switch/push button in the "On" position because the revs are zero
#9 |
I get it. He couldn't replicate the CEL when it came time to take the photo. Me so stupid. Anyways it was most likely because he wanted us to see the ODO
#10 |
Drives: Limited BRZ
That's what I believe.
#11 | |
I'm going to update my original post. Apparently this is an issue with our cars and will result in a rebuild of the whole top end of the engine. More reports are showing up for the FR-S merely because there are more of them out there. The Parts are in back-order that's how much it's showing up.
PS: yeah the picture was meant for the ODO since the towing people needed to know it. I figured i might as well take a photo Quote:
#12 |
Drives: 2013 Hot lava Fr-s, 2007 Mazda 3
you picked the right quote. If your RPM's were dipping every time you came to an idle then you sir have yet another faulty Timing actuator in your VVTi system. Really sucks seeing this happen so frequently now...
Raising the bar one step at a time!
Kansas City FR-S/BRZ Facebook group. https://www.facebook.com/groups/452909128083343/ Hotlava86's Build thread!http://www.ft86club.com/forums/showthread.php?t=14152 |
#13 |
that's exactly what has been happening :/ 3 weeks in the shop would suck. they weren't able to look at it until tomorrow meanwhile they gave me an Outback which I hate: the brakes go in too deep, smells like cigarettes, it's huge, and, speakers suck. I only found two good points the sound fades when you turn off the car and it's very comfy
#14 |
Registered you sir
Drives: 99 impreza coupe
Sorry to hear it man. Lol at the TC comment, let him know whats up!
| Check engine light just came on after 2k miles. | danthedirt | Issues | Warranty | Recalls / TSB | 604 | 01-31-2015 04:26 PM |
| First Check Engine Light and Traction control | QFry | Issues | Warranty | Recalls / TSB | 26 | 10-04-2014 11:27 PM |
| Engine sputtering while idling with check engine light flashing, WTF | speedy racer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-27-2012 06:50 AM |
| FR-S: Highbeam turns on lowbeam, how to disable? | civicdrivr | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 07-03-2012 07:08 PM |
| Check Engine Light | b.e | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 06-17-2012 09:50 PM |
