Old 08-26-2012, 03:54 PM   #1
Niko
Drives: one
Space under rear seat
Don't have my BRZ yet, but I'm trying to plan ahead. I've looked around and only been able to find a few pics that don't tell me much. I'm wondering how much space is there under the rear seat. Thinking of mounting an amp under there for a cleaner install. Anyone had the rear seat off and can comment on how much clearance there is with the seat back in place.
Niko is offline   Reply With Quote
Old 08-26-2012, 04:21 PM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
I get the feeling I'm misunderstanding what you're trying to say. There isn't any space under the rear seat cushion, well, I plan on running wires under it, but even that will be tight.
Do you mean under the front seats, or maybe in the spare tire well?
Old 08-26-2012, 05:37 PM   #3
Niko
Drives: one
Sorry, I should clarify. If I were to remove the back seat, is there enough room to install an amp and then re-install the back seat.
Old 08-26-2012, 05:58 PM   #4
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
I havnt taken the seats out but there might be room where the stock amp is located
Lee358 is offline   Reply With Quote
Old 08-26-2012, 06:29 PM   #5
DBacon1052
DBacon1052's Avatar
Drives: Argento FR-S
I was actually thinking the same thing. I was going to check but the bolts on the seat were super tight. I dont feel like doing the work only to find out that theres no space.
DBacon1052 is offline   Reply With Quote
Old 08-26-2012, 06:49 PM   #6
Niko
Drives: one
Lee, I'm looking at a 4 channel amp + mono block, or a 6 channel. Not sure if 6 would fit in the stock location and if I went with 4 + mono I'd need somewhere to put the 4.
Old 08-26-2012, 06:53 PM   #7
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
No room. The rear cushions are essentially padding for buckets hammered out of the sheetmetal.
If you get a small enough amp, you could remove the styrofoam at the base of the rear seatback in the trunk and hide it under the trunk floor. If you have to have a large amp, you may have to attach it to the seat back.
Old 08-26-2012, 07:10 PM   #8
Niko
Drives: one
Thanks Draco. I'll probably end up cutting out the foam then.
Old 08-26-2012, 07:28 PM   #9
Lee358
Lee358's Avatar
Im not home im on vacation unless some one does it before i get back ill pull the flooring out of my trunk to show you how much room there is. Its really not much tho
Old 08-26-2012, 10:37 PM   #10
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Not to mention the cooling issues you'd have mounting an amp under the rear seat.
kmbkk is offline   Reply With Quote
Old 08-27-2012, 11:34 AM   #11
Niko
Drives: one
Thanks Lee, from pics I've seen there looks to be an inch or two.
That was definitely a potential concern, but it couldn't be too much worse than the stock amp location unless there's some sort of ventilation I haven't seen.
Old 08-27-2012, 02:04 PM   #12
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
That's true, which is one of the reasons I'm upgrading my system when I get my car back. I already have a complete system in my garage just waiting to be installed!
Old 08-27-2012, 05:26 PM   #13
zooki
Drives: waiting on a 2021...
From all the room it looks like there is by the rear speakers, I wonder if you could fab up a mount and stick the amp behind the rear side panel?
zooki is offline   Reply With Quote
Old 08-27-2012, 06:27 PM   #14
-max-
Drives: Firestorm FRS
Plenty of room behind the rear speakers. Put the amp behind the panel and replace the speaker with a fan.
-max- is offline   Reply With Quote
Rear Seat Deletes EvoFanatic Cosmetic Modification (Interior/Exterior/Lighting) 110 02-23-2015 08:59 PM
Sit in the rear seat for me ;) (with photos of people in back seat) D4ng3r Scion FR-S / Toyota 86 GT86 General Forum 125 11-14-2013 07:59 AM
Rear seat removal? Shizuma BRZ First-Gen (2012+) — General Topics 34 04-01-2013 04:36 AM
JDM 86 Rear Seat Silencer ZC6BRZ Cosmetic Modification (Interior/Exterior/Lighting) 28 12-01-2012 10:33 PM
Back seat space bill323 Scion FR-S / Toyota 86 GT86 General Forum 23 08-07-2012 04:11 PM
