Old 08-02-2012, 02:28 PM   #127
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added my review of the D2 Racing RS coilovers:
http://www.ft86club.com/forums/showthread.php?t=13553
Old 08-02-2012, 11:46 PM   #128
DetroitJake
DetroitJake's Avatar
Drives: '13 FR-S 6MT / '14 Prius-C
Firstly this thread is awesome and DarrenDriven is a mad man for putting this sort of stuff together.
Respect man.
However, I am wondering further about this subject.
What about compression and rebound damping?
Do manufacturers give values for this sort of thing?
The unit should be something like Newton per m/s (force per velocity).
In other words, the faster you hit it, the more it resists movement.
(viscous fluids such as oil have this behavior).
I believe there's much more to a shock than just spring rates.
There's constant rate springs, progressive rate springs, constant damping and variable damping, etc.
I don't have any practical vehicle level experience with this, but I've raced model cars a bit, and suspension set up is quite important.
I'd love to lower my FR-S, but when you restrict available motion, you'll probably need more damping as well to absorb the force in a shorter period. (Michigan is full of pot holes)
Probably this aftermarket stuff already considers this sort of thing, but maybe not. Maybe just a stiffer spring (spring rate increase) is enough to handle it?
Just I'm wondering this subject. Can anybody comment from practical experience? Do any of these coil overs have adjustable damping?
And how do you adjust it? Do you need to remove the shocks or is there access to valves for example?
DetroitJake is offline   Reply With Quote
Old 08-02-2012, 11:48 PM   #129
DarrenDriven
NW Region Moderator
As each spring or coilover is installed and reviewed by forum members I will link to their individual topics which should contain more information on each part. I am just about maxing out the amount of info I can cram into a table in the first topic already.
Old 08-07-2012, 01:05 PM   #130
DarrenDriven
NW Region Moderator
Added info for the K-Sport coilovers, which appear to be the same as the D2 product.
Old 08-07-2012, 01:50 PM   #131
Racecomp Engineering
Respect man.
Hey Jake,
Most (though not all) coilovers have externally adjustable damping. For large scale changes you may need to send the shock to the manufacturer to be internally revalved.
Usually it's one external knob that adjusts compression (aka bump) and extension (aka rebound) together, though sometimes it only adjusts rebound.
A few coilovers have two knobs...an adjustment for rebound and a separate knob for compression. KW Variant 3s are an example of a "2 way" coilover.
Fewer still will have 3 or 4 knobs. These separate out the damping into high and low piston speed situations. 3 ways are rebound and high + low speed bump. These are usually very expensive, race-only parts. 4 ways will run you around $10k.
Occasionally you'll see a manufacturer say something like 30 way adjustable damping. This just means that they have 30 clicks of adjustment. This isn't the proper terminology, just like the word dampening isn't really correct (vs. damping).
Number of clicks isn't really as important as the valving itself, total range of adjustment, consistency, etc.
Manufacturers occasionally release shock dyno plots, which are usually force vs. piston velocity charts. They are also sometimes displayed as force vs. displacement.
Shock valving is a little complicated...but the basics aren't too bad. It's not as simple as soft vs. stiff like a spring. Higher end shocks can be tuned to behave digressively instead of linearly (or progressively). You're right though, it's very important and there is much more to a coilover than the amount of drop and the spring rates. Unfortunately it's data that's often not released and much more difficult to interpret.
- Andrew
DetroitJake (08-07-2012), JoeBoxer (08-11-2012)
Old 08-07-2012, 10:48 PM   #132
DetroitJake
Hey Jake,
- Andrew
Great answer. Thanks for the post. I plan to feel out the stock suspension for a while, but after I'm familiar with how it feels, I'm going to start looking at this stuff. I'll definitely check you guys out. Thanks again Racecomp Engineering.
Old 08-13-2012, 01:29 PM   #133
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
Here is the link to the Hotchkis Coil Springs:
http://www.hotchkis.net/2013-scion-f...l-springs.html
Cheers
Nitro22 is offline   Reply With Quote
Old 08-13-2012, 11:01 PM   #134
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
The STI springs lower by 15mm (0.6") front and rear.
Old 08-15-2012, 01:20 AM   #135
DarrenDriven
NW Region Moderator
Added STi BRZ Springs:
http://www.sti.jp/news/2012/12024.html
Old 08-15-2012, 04:45 AM   #136
DarrenDriven
NW Region Moderator
Cheers
Thanks! I updated the link on the list.
Old 08-19-2012, 02:50 PM   #137
DarrenDriven
NW Region Moderator
Added review of the Hotchkis Sport lowering springs
http://www.ft86club.com/forums/showthread.php?t=14816
The Following User Says Thank You to DarrenDriven For This Useful Post:
Nitro22 (08-22-2012)
Old 08-26-2012, 12:54 AM   #138
bpracer
Drives: Asphalt FR-S
In case you wonder why the FR-S is a bit tail-happy...
The FR-S spring rate ratio front to rear is by far the most aggressive of all the spring rates of the OEM models and even aftermarket (non-coilover) makers. Of course there may be some variable effects of the lowered springs heights for the aftermarket but you get the idea...
Model Fr Rr Fr/Rr ratio
FR-S 2.3 3.8 .605
BRZ 2.7 3.5 .771
GT-86 3.0 3.3 .909
Tein H 3.0 4.6 .652
Tein S 3.3 5.0 .660
Hotchkiss 3.3 4.7 .702
Eibach Pro 3.8 5.3 .717
Eibach Pro 3.6 4.9 .734
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
The Following User Says Thank You to bpracer For This Useful Post:
Sarlacc (04-03-2013)
Old 08-26-2012, 03:39 AM   #139
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Tein has different specs listed on site. I don't believe it was always listed as such.
http://www.tein.com/tech_info/q54.html
S-Tech ride height changed
H-Tech ride height and spring rate changed.
Now 2.9/4.8 (.60417 - see above post)
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 08-26-2012, 07:55 PM   #140
bpracer
They did change didn't they...
I'm coming to enjoy the FRS handling (only had it for 5 days!). The oversteer I first encountered seems to be limited to tight, low speed situations, where it is difficult to weight the rear end.
Asphalt FR-S
Ducati 848
brz aftermarket coilovers, brz aftermarket springs, brz coilover, brz coilovers, brz lowering springs, brz springs, brz suspension, fr-s coilover, fr-s coilovers, fr-s lowering springs, fr-s springs, fr-s suspension, frs coilover, frs coilovers, frs lowering springs, frs springs, frs suspension, scion fr-s coilover, scion fr-s coilovers, scion fr-s springs, subaru brz coilovers, subaru brz foru, subaru brz forums, subaru brz springs
Adjustable shocks+ springs vs Coilovers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 06-08-2013 03:59 PM
Canadian FR-S options VS U.S.A's options? Tino Scion FR-S / Toyota 86 GT86 General Forum 15 11-06-2012 10:07 PM
coilovers or springs? koyv90 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 04-01-2012 08:49 PM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 01:11 PM
Subaru BRZ different suspension / springs tuning ahausheer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 12-06-2011 12:52 PM
