Old 08-23-2012, 06:54 PM   #4929
Giccin
Giccin's Avatar
What these two up to now lol can't wait to see next option vid
Attachment 13504
Did Orido lose more weight?!
I am the Ice Queen.
Logic > Emotion
┬──┬◡ノ(° -°ノ)
TOYOTA FT-86
Giccin is offline
Old 08-23-2012, 06:56 PM   #4930
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Yeah, in his blog, he's talking bout he have been dieting.
ichitaka05 is offline
Old 08-23-2012, 07:42 PM   #4931
serialk11r
Drives: '06 AM V8V Coupe
Well, just napped 5 hours O_O
I really hope that I haven't gotten used to needing 14 hours of sleep a day.
serialk11r is offline
Old 08-23-2012, 08:11 PM   #4932
Dimman
Kuruma Otaku
Dimman's Avatar
Needing???
Because titanium.
Dimman is offline
Old 08-23-2012, 08:18 PM   #4933
serialk11r
Needing???
Been oversleeping everyday, today I get 8 hours and I feel tired as s*** and end up napping for 5 hours more :/
Old 08-23-2012, 09:00 PM   #4934
boucher
Leaux Down Krewe
boucher's Avatar
Drives: 2014 SSM Limited
I worked almost 24 hours in a row the two days ago. Last night I thought I needed 14 hours lol.
Random thought: I can't wait to get my FRS so I can start a journal and show everybody my completely stock new car.
boucher is offline
Old 08-23-2012, 09:43 PM   #4935
Dimman
Kuruma Otaku
Dimman's Avatar
You're not staying up to 4am figuring out SC efficiency again?
Heh.
Because titanium.
Dimman is offline
The Following User Says Thank You to Dimman For This Useful Post:
Allch Chcar (08-24-2012)
Old 08-23-2012, 09:59 PM   #4936
serialk11r
Heh.
What? Been there done that :P
But still thinking constantly about how to rev a 1NZ/1NR to 9000rpm. I would really appreciate if Toyota brought the 1NR 6sp combo to the US, nevermind the 1.33 displacement.
The Following User Says Thank You to serialk11r For This Useful Post:
Old 08-23-2012, 10:29 PM   #4937
Dimman
Kuruma Otaku
Dimman's Avatar
Small bore means small valves/ports which can choke rpm, even if the motor can survive mechanically.
Just remembered my buddy said Blitz makes (made?) an SC kit for his Yaris.
So MR-S + Yaris motor + Prius cams (+ 6m from Celica/Matrix/Corolla XRS?) + SC kit = not too expensive path to your goal?
Because titanium.
Dimman is offline
Old 08-23-2012, 10:54 PM   #4938
S2kphile
Resident HoneyBadger
S2kphile's Avatar
Drives: Toyota Tacoma TRD Off-Road
All I can say this weekend
Walk like a King, Be like a Sir, Swag it out like a Boss
S2kphile is offline
Old 08-23-2012, 11:08 PM   #4939
serialk11r
The C60 fits?
I'm interested in the 1NR because that transmission supposedly has some weight reduction done to it. The reason for dropping down in displacement is to decrease weight (a supercharger or electric motor can be mounted more flexibly). Problem is Toyota sucks and won't make a 6 speed for us.
The 1NZ is 65lbs lighter than the 2ZZ. I imagine a supercharger setup would add back at least half of that, but at least I can tuck the supercharger near the bottom of the chassis. Supercharger > variable lift.
My concern with Prius cams is that while they bleed off intake air just fine below 4000rpm, at 8000rpm things are pretty different. The first step would probably be to bolt in a 1NZ with built bottom end and milled heads, fitting with the Prius cams, and then dyno it to see how it behaves at high rpm. It would also give a small clue about how well the head is flowing. I don't think the bore is that big of an issue, because the 1NZ has a relatively small stroke and big bore for its displacement.
I am also wondering if it would be a good idea to attempt to dry sump it since it's getting custom chassis mounts.
Speculating about how you're going to blow tons of money and time is so fun!
Old 08-23-2012, 11:25 PM   #4940
Dimman
Kuruma Otaku
Dimman's Avatar
The C60 fits?
I don't know if the tranny will mate up but people have been working around that for ages with adapter plates.
Funny thing is even if the NZ is dirt cheap, everything for it will be big one-off custom dollars because of zero support.
A 2ZZ/6m would probably be much, much cheaper.
What about 2ZZ (easy, but boring) then adding a mild hybrid (motor in the frunk area, powering the front wheels?) with ultra caps (hard, but interesting)?
Plus sorting the swap relatively easily/quickly can be good for building confidence for the later stuff.
Because titanium.
Dimman is offline
Old 08-23-2012, 11:33 PM   #4941
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
Just installed Linux and WOW, I gotta say...
ITS AMAZING. I love every bit so far. As a casual Internet browsing/Word processor user, it's perfect. Too bad I'm on a VirtualMachine
Snoopyalien24 is offline
The Following User Says Thank You to Snoopyalien24 For This Useful Post:
Guff (08-24-2012)
Old 08-24-2012, 12:00 AM   #4942
serialk11r
Pretty sure there are forged internals available, and capable piggybacks. Everything else...well, I figure I'll get pretty good at machining/welding :P
2ZZ swaps are quite cheap, but like I said they aren't nerdgasm inducing. The 2ZZ is such a beautiful motor from the factory, if I put one in it'll feel like there's nothing left to do.
I insist on decreasing the displacement, because I think the displacement is too high for the MR2. Still trying to decide what "Miller cycle ratio" (physical expansion ratio/true compression ratio) to use, the higher it is the higher the static compression should go to maximize the efficiency and power, but as you know high compression interferes with in cylinder flow.
The biggest piece of the puzzle is still obtaining the unicorn Eaton TVS supercharger...may have to just settle for a centri
