Old 08-22-2012, 05:29 PM   #29
winter
winter's Avatar
Drives: Argento FR-S 6MT
If you need 32Gb in a small form factor this one works: [ame="http://www.amazon.com/SanDisk-Cruzer-Flash-Drive-SDCZ33-032G-B35/dp/B00812F7O8/"]Amazon.com: SanDisk Cruzer Fit CZ33 32GB USB Flash Drive (SDCZ33-032G-B35): Computers & Accessories[/ame]
winter is offline   Reply With Quote
The Following 2 Users Say Thank You to winter For This Useful Post:
gosaints420 (08-26-2012), mezdup (08-26-2012)
Old 08-22-2012, 05:33 PM   #30
winter
winter's Avatar
Oh, and a tip for listening to these thumb drives with the stock stereo - If you press the "random" key once it plays through whichever folder you're current song is in randomly, but if you have a lot of different folders and you want it to play randomly through all of your music HOLD the "random" button (I think its the #5 button) until you hear a beep and a USB drive icon will show up on the display and it will play randomly through the entire USB stick.
The Following 5 Users Say Thank You to winter For This Useful Post:
Dadhawk (08-26-2012), mezdup (08-26-2012), Smitty_89 (08-10-2013), Spartan65 (08-22-2012), TemeCal (08-23-2012)
Old 08-22-2012, 05:40 PM   #31
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
So I have one of these in a 8gb
There is a real good article about Micro usb's here http://www.squidoo.com/mini-usb-drives
The other day Half of my files disappeared, so I formatted the little bugger and decided to go with less sub folders, I update if it implodes. For 8.00 @ Wally World no big deal, just time.
Spartan65 is offline   Reply With Quote
Old 08-23-2012, 09:59 PM   #32
miodculae
FRS Adept
miodculae's Avatar
Drives: Firestorm FRS
well, i found a USB drive that the car does not see.
This Kingson DT 108 (8 GBs) does not connect:
[ame="http://www.amazon.com/Kingston-DataTraveler-Flash-DT108-16GBZ/dp/B005755U3U"]http://www.amazon.com/Kingston-DataTraveler-Flash-DT108-16GBZ/dp/B005755U3U[/ame]
I get a 'BTA does not connect' something or other message.
miodculae is offline   Reply With Quote
Old 08-23-2012, 10:40 PM   #33
mach330
Drives: Ultramarine frs
Originally Posted by winter View Post
Got one of these as well. So tiny I just have it in the car. Don't need another iPod to leave in the car.
Tap'd from my G-Nex
mach330 is offline   Reply With Quote
Old 08-26-2012, 04:30 PM   #34
SocalBurt
http://www.amazon.com/Kingston-DataT.../dp/B005755U3U
Sounds like you need to press the usb/bta button. I got this too and its starts off in bta mode (blue tooth adapter) press the button on the stereo one more time and it switches over to usb then you should be in business
SocalBurt is offline   Reply With Quote
Old 08-26-2012, 04:46 PM   #35
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
The issue I have with this setup is if you have several songs that are duplicated in multiple playlists, you're eating a lot of space up.
Would be nice if there was a simple open source way to create playlists out of a list of the same files.
Then again I guess this is what owning an iPod is for.
MmmHamSandwich is offline   Reply With Quote
Old 08-27-2012, 12:27 AM   #36
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
Apple doesn't have the patent on simplicity. I've used this many, many times, works great!
http://www.oddgravity.de/app-opc.php
michaelahess is offline   Reply With Quote
Old 08-27-2012, 09:49 AM   #37
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I assume you're talking about the FRS. Which is the random key? I have the upgraded Bespoke and didn't see it.
post_break is offline   Reply With Quote
Old 08-27-2012, 09:51 AM   #38
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
he's describing the stock setup not bespoke, check your manual :/
Old 08-27-2012, 09:55 AM   #39
Justin.b
Drives: 13 Hot Lava, 01 Miata, 09 Outback
Originally Posted by Spartan65 View Post
I picked up one of these from Wally Worldhttp://www.walmart.com/ip/HP-8GB-v16...Drive/15913494
I have the same one in 32gb. I have big fingers, and I wanted to have enough of the drive sticking out to grab. A lot of these very small USB devices have a 'barbed' USB port that makes them very difficult to remove, so I didn't really want to go with the practically invisible ones.
-Justin
Justin.b is offline   Reply With Quote
Old 08-27-2012, 10:00 AM   #40
colHolm
Default User Title
colHolm's Avatar
Originally Posted by Bonburner View Post
that's not true.
you can shuffle by folders/by entire usb.
you can play by folders/by entire usb
How do you change the settings for how the head unit reads the files on the USB input? I can't find it anywhere... Do you have the base head unit?
colHolm is offline   Reply With Quote
Old 08-27-2012, 10:22 AM   #41
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
yes, I suggest sitting in the cabin with the header manual bc its a little weird .. it uses some weird and small symbols to display what settings/shuffle/etc its set to
Old 08-27-2012, 08:00 PM   #42
jmkv
Drives: really slow
just picked on up for my car! I sometimes forget its even there
jmkv is offline   Reply With Quote
Tiny chip in Windshield JohnATL Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 10 10-16-2012 03:37 PM
New Stick Driver, looking for advice. Sythellri BRZ First-Gen (2012+) — General Topics 49 08-23-2012 09:47 PM
To Drive a stick or cruise an Auto? MrFRsLa Scion FR-S / Toyota 86 GT86 General Forum 54 04-30-2012 07:50 PM
Car Name; Reason why FT-86 won't stick xantonin Scion FR-S / Toyota 86 GT86 General Forum 54 07-17-2011 12:52 PM
