Old 08-20-2012, 03:14 PM   #1
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
Safe to use DOT 5.1?
Is it safe to use Motul DOT 5.1 on the BRZ/FRS? I'm looking at this one: [ame="http://www.amazon.com/gp/product/B004LF1U40/ref=oh_details_o00_s00_i00"]Amazon.com: Motul 3364HL Dot 5.1 100 Percent Synthetic Non-Silicone Base Long Life Brake Fluid - 500 ml: Automotive[/ame]
Also, how much should I be buying? I'm planning to replace all the brake fluids.
Thanks!
mechaghost is offline   Reply With Quote
Old 08-20-2012, 04:19 PM   #2
Matt Andrews
Matt Andrews's Avatar
Drives: race cars
yes, its safe. Why are you replacing what comes from the factory out of curiosity? You planning on tracking the car? If so, I'd go with the 600. If not, then I don't see why you'd need to change it?
1 bottle should replace the whole system...which you would want to do instead of simply topping off the stock fluid with this.
11/19/12 - Just back from Redline TimeAttack's demo event. Video and write up in link below.
http://fecompetition.wordpress.com/
https://www.facebook.com/FECompetition
Matt Andrews is offline   Reply With Quote
Old 08-20-2012, 05:34 PM   #3
mechaghost
mechaghost's Avatar
I'm switching it out because of the occasional track use and moderate autox. Plus I am changing out the brake lines as part of the stoptech brake kit
Old 08-20-2012, 08:59 PM   #4
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
have you already tracked the car and found the OEM brakes to be insufficient for you? have you tried simply upgrading the pads?
i second the rbf600 instead of the 5.1 for track and autocross duty.
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 08-21-2012, 03:15 AM   #5
dave99rt
Drives: '22 BRZ
you might want to check the specs on that fluid.
i'm pretty sure all the newer dot 4 race fluids have higher boiling points.
dave99rt is offline   Reply With Quote
Old 10-27-2015, 04:04 AM   #6
BaBaFlyingSheep
Drives: 2015 BRZ Ltd 6MT
Manual says DOT 3 or DOT 4
Necro-thread but can't seem to find any other thread with DOT 5.1 in the title.
Did you end up switching to Motul 5.1, and was everything working fine?
I seem to have a hard time on really specific information on the web, but here's to summarize the main points. I'm sure everyone already knows the common knowledge, but I know people will restate it anyways.
Boiling point wise, dry and wet, in general (or by standard), DOT 3 < DOT 4 < DOT 5 = DOT 5.1.
We get some DOT 4 that's superior in boil temps than DOT 5.1, but it's not considered a DOT 5.1 due to it's higher viscosity.
With that said, viscosity: DOT 5 = DOT 5.1 < DOT 3 < DOT 4.
Sometimes, DOT 4, due to it's high viscosity runs into problems on certain systems, but the viscosity lowers at high temps, so it's usually fine for tracking, from what I gathered it because it's more "track-orientated" and the high temp lowers the viscosity for better operation. (I'm assuming this because, why not just call the DOT 4 a DOT 5.1 if it's got some high boil temp resistance)
Now here's why I'm asking if DOT 5.1 was ok for your brake system. As we all know, and I'm sure someone will state it, DOT 5 is silicone-based on not compatible with the other specs, there's also a lot of other reasons DOT 5 is not recommended, but I won't get into details. We do know it's usually used on older cars without ABS systems.
The reason is that the low visc messes with the ABS.
Now, DOT 5 and DOT 5.1 have the standards, visc. and boil temps, the only differentiating factor is silicone-based or not.
With that said, will DOT 5.1 screw up our ABS systems because it has similar visc specs as DOT 5?
Motul 5.1 claims it's "designed for ABS" systems, but is it meant for systems that can handle low visc?
I'm looking looking at the owner's manual and it DOES NOT state DOT 5.1, only DOT 3 or 4, FMVSS 116.
Even if the stock ABS system can handle the low viscosity of 5.1, does this void the warranty?
I was considering Motul 5.1 because it seems to have the best overall bang for your buck on performance & longevity.
BaBaFlyingSheep is offline   Reply With Quote
Old 10-27-2015, 04:32 AM   #7
ryoma
ryoma's Avatar
if the owners manual states to only use DOT 3 or 4, then stick with that. you won't even have to change out your brake fluid often with normal driving. if you're going to frequent the track, then no matter what fluid you're getting it will be changed out often due to the harsher conditions.
bottom line, don't cheap out on anything that will save your life. I personally am using Torque RT700 and that is expensive, but great results to justify the price in my eyes. RBF600 is great for the money as well.
State Farm's Drive Safe and Save: Anyone have experience with this plan? b.e Electronics | Audio | NAV | Infotainment 21 03-20-2013 10:54 PM
Is Stoner Invisible Glass safe for Tinted Windows? Mburolla Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 08-01-2012 12:32 PM
Safe at the Dealership? BP1913 BRZ First-Gen (2012+) — General Topics 19 06-18-2012 05:52 PM
Safe to wax new car paint? Nitro Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 06-09-2012 02:08 AM
