Old 08-19-2012, 07:38 PM   #1
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Schroth Rallye 3 Harnesses
I like the feel of a harness when racing. Being securely held to the seat lets me keep a lighter hand on the wheel, and lets me concentrate on racing instead of staying put.
The Schroth Rallye harnesses are a good light duty/AutoX/RallyX choice. They adhere to DOT regulations and can be put on really easily with one buckle. Installation is straightforward and relatively easy, using the stock belt locations and no welding.
I've used the Rally 4 harnesses on both my RallyX WRX and my STI. But for the BRZ, the lower belt hard points are too close to the front seats for good harness angles. So I went with the Rally 3. The rear mount will bolt to the bracket for the rear shoulder reels. The lap belts mount to the lower shoulder belt mount on the outside and the buckle on the seat on the inside.
Removing the inner body pieces is outlined in this thread: http://www.ft86club.com/forums/showt...terior+removal Just stop after his step 2. The second picture in his Step 3 shows the upper bracket mount for the shoulder reel. That's the bolt I used for the rear harness mount. Then I just fed the strap through the same slot as the shoulder belt.
The lap belt is a lot easier to install believe it or not. First, the seat has to be unbolted from the floor. It is held in by reverse torx bolts. An E10 socket is needed to loosen these. Once they're out, the seat can be moved forward to make the lower shoulder belt bolt more accessable. To get to the buckle mount, just tilt the seat partway out of the door and the nut is easy to get to on the side.
Now, these are "4-point" harnesses without a submarine belt, so they may not qualify for some forms of racing. But for smaller amateur motorsports, they are a great choice.
Old 08-19-2012, 08:18 PM   #2
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
Nice! I wonder if Schroth will come out with a Quick-fit Rallye harness for the BRZ/FRS like they have for some other popular car models. I've got a Schroth Rallye Quick-fit harness in my Mini Cooper, and have had the universal Rallye 3 & 4 in my Neons about 10 years ago.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 08-19-2012, 08:24 PM   #3
Draco-REX
Corner Junkie
Draco-REX's Avatar
Subaru changed the buckles on the Impreza in 2007 and Schroth never updated the Quickfits. So I don't think we'll be seeing a quickfit for the BRZ/FRS.
Old 08-19-2012, 08:40 PM   #4
Miniata
Yeah, I wasn't very hopeful. Thankfully the standard universal fit Rallye harnesses work in most cars without too much difficulty on the installation process.
Old 08-19-2012, 09:40 PM   #5
Nardi330
Nardi330's Avatar
Drives: 86
do you have pic to show how the lap belts are mounted?
thanks heaps.
Nardi330 is offline   Reply With Quote
Old 08-20-2012, 07:21 AM   #6
Draco-REX
Corner Junkie
Draco-REX's Avatar
thanks heaps.
Unfortunately, I don't. But if you follow the stock shoulder belt down to the frame rail, that's the bolt that the outer belt attaches to, just pull up the rubber cover.
If you slide your hand down the belt buckle on the inside you'll feel the nut holding it on, that's where the inside belt attaches.
Old 08-20-2012, 07:42 PM   #7
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
This is not something I would feel safe in.
Old 08-20-2012, 07:54 PM   #8
Nardi330
Nardi330's Avatar
Drives: 86
cool thanks. i think i know how to install this now.
Old 08-20-2012, 09:28 PM   #9
Draco-REX
Corner Junkie
Draco-REX's Avatar
I'm petty sure Schroth knows what they're doing. As it is, due to the lack of a submarine belt, this is for light street/AutoX duty only. Schroth has better 5 and 6 point belts for track duty.
Old 08-20-2012, 09:38 PM   #10
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Hey that's pretty cool! What'd you do about the seatbelt chime?
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 08-20-2012, 09:52 PM   #11
Draco-REX
Corner Junkie
Draco-REX's Avatar
Pull the stock belt around behind the seat and put it in the buckle.
Old 08-20-2012, 10:39 PM   #12
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Are they designed to be mounted on the rear shoulder reels (with an angle)? It just doesn't look right.
iLuveKetchup is offline   Reply With Quote
Old 08-20-2012, 10:51 PM   #13
Draco-REX
Corner Junkie
Draco-REX's Avatar
Old 08-20-2012, 11:05 PM   #14
iLuveKetchup
Drives: EFF JAY
^ wow that's crazy, but I'm glad that there is a solution out there. Now I want a set. lol
