Old 08-19-2012, 10:25 AM   #1
kc4mne
Drives: 2013 Scion FRS
Smile No more 1st gear thump or 2nd gear notchiness
Replaced the manual transmission fluid with Redline MT-90
http://www.redlineoil.com/product.aspx?pid=46&pcid=7
And the rear differential gear with Moblil 1 75W90
http://www.mobiloil.com/USA-English/..._75W-90LS.aspx
Transmission shifts much better, no thump on 1st gear and much much less notchiness on 2nd gear engagement
kc4mne is offline   Reply With Quote
The Following 7 Users Say Thank You to kc4mne For This Useful Post:
BMWDavid (08-19-2012), Bonburner (08-19-2012), Brzce (09-05-2012), GoSharks (09-06-2012), Guff (08-30-2012), neutral (08-20-2012), Shagaliscious (09-05-2012)
Old 08-19-2012, 12:16 PM   #2
NeedsmoreCowbell
toyotas are practical :)
NeedsmoreCowbell's Avatar
Drives: Hot Lava FRS
why did you decide on mobil 1 on the rear?
NeedsmoreCowbell is offline   Reply With Quote
Old 08-19-2012, 12:20 PM   #3
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Why did you use Mobil 1 for the diff? just curious
tonystewart is offline   Reply With Quote
Old 08-19-2012, 12:20 PM   #4
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
mobile one rocks... duhhh lol
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 08-19-2012, 12:21 PM   #5
S2kphile
Resident HoneyBadger
S2kphile's Avatar
Drives: Toyota Tacoma TRD Off-Road
Because NASCAR uses it
Walk like a King, Be like a Sir, Swag it out like a Boss
S2kphile is offline   Reply With Quote
The Following User Says Thank You to S2kphile For This Useful Post:
carbonBLUE (08-19-2012)
Old 08-19-2012, 12:22 PM   #6
carbonBLUE
Reverse Burnouts
i see what you did there....
(wont forget you)
2011 Infiniti G37x
The Following 2 Users Say Thank You to carbonBLUE For This Useful Post:
denkigrve (09-06-2012), Guff (08-30-2012)
Old 08-19-2012, 03:27 PM   #7
Hotlava86
Hotlava86's Avatar
Drives: 2013 Hot lava Fr-s, 2007 Mazda 3
This will be happening now! changing it next weekend for sure!
Raising the bar one step at a time!
Kansas City FR-S/BRZ Facebook group. https://www.facebook.com/groups/452909128083343/
Hotlava86's Build thread!http://www.ft86club.com/forums/showthread.php?t=14152
Hotlava86 is offline   Reply With Quote
Old 08-19-2012, 03:33 PM   #8
mashal
DADA
mashal's Avatar
Drives: 2013
How much did you use of each?
mashal is offline   Reply With Quote
Old 08-19-2012, 04:47 PM   #9
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I've definately been planning on swapping all my fluids at 3k
Old 08-19-2012, 05:53 PM   #10
kc4mne
used little les than 3 qt for the tranny and little less than 2 qt for th diff.
used mobil 1 for the diff because the place were I got the redline did not have 75w90 GL-5 gear oil in stock. Plus mobil 1 has limited slip friction additive in it which is needed if the limited slip axle has clutches, which I don't know if it does on not, but with mobil 1 it does not matter, you are covered either way
Old 08-19-2012, 06:21 PM   #11
D1cker
Drives: B9 S4/ND2
our limited slip is a torsen so no clutches.
D1cker is offline   Reply With Quote
Old 08-20-2012, 06:15 AM   #12
demby123
Drives: 86' Toyota Corolla GTSR5, 15' FRS
I thought AZ6 transmissions took that wierd 5w30 gear oil that honda uses...
demby123 is offline   Reply With Quote
Old 08-30-2012, 08:01 PM   #13
gmookher
so did the MT90 cure, lessen or did you NOT have the bitchy 2nd gear issue when cold?
Old 08-30-2012, 08:27 PM   #14
pinoyplaya
Drives: WRB MT-BRZ LMTD
Are these fluids easy to replace?
Easier than an oil change?
BYE: WRB MT-BRZ LMTD
Drove the car off the lot at 8/6/12 @ 8:06 PM
Traded for Black 2013 Camaro 2SS RS
pinoyplaya is offline   Reply With Quote
Top Gear blackfireball5 Scion FR-S / Toyota 86 GT86 General Forum 3 08-17-2012 01:58 PM
BRZ on Top Gear? pinoyplaya BRZ First-Gen (2012+) — General Topics 28 08-10-2012 02:45 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 07:44 PM
86/BRZ/FRS on Top Gear: When??? FT-86GOD Scion FR-S / Toyota 86 GT86 General Forum 20 07-04-2012 12:08 AM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
