Old 08-19-2012, 09:00 AM   #1
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
Anyone change transmission lube yet?
I know there have been a couple of postings on this subject but I was hoping to get more feedback.
So for those who have changed their gear lube what did you use and what effect did it have on shifting quality/feel?
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Old 08-19-2012, 10:01 AM   #2
roddy
roddy's Avatar
Drives: '13 Ultramarine
I changed mine and used Redline's MT-90 (GL-4) transmission lube. Shifts were fine beforehand, and even better after. I used to get a (very) slight crunch into 3rd, but that is gone now. I will be driving the car through winter and it gets pretty cold here. If shifts degrade as it gets colder, I'll try switching to MT-85. By modern standards 90wt oil is pretty thick. It is a pretty easy job...the hardest part is removing the shields under the engine and transmission so you can access the drain/fill plugs. If you plan on being under the car anyway, I'd recommend changing the fluid in the differential as well. I used Redline's 75W85 GL-5 lightweight gear oil.
Old 08-19-2012, 06:02 PM   #3
coyote
coyote's Avatar
Drives: Slowly
The NS gear oil is a better choice with that differential.
coyote is offline   Reply With Quote
Old 08-19-2012, 07:10 PM   #4
roddy
roddy's Avatar
NS? The only NS I saw was a 75W140. It has less or no friction modifiers (which is fine for a torsen as they dont need 'em), but imo is way heavier than needed for this application. It did seem strange that the oil in the transmission (75W90) is thicker than the oil in the rear end (75W85), but that is what the manual calls for, so I used it.
Old 08-19-2012, 07:45 PM   #5
ArKiTeCkT
ArKiTeCkT's Avatar
Drives: 2010 Gen Coupe, 2013 BRZ 6MT S.Tech
Can someone make a DIY for this or is it straightforward? I believe they come with crush washers, correct me if I'm wrong.
ArKiTeCkT is offline   Reply With Quote
Old 08-19-2012, 07:53 PM   #6
coyote
coyote's Avatar
Drives: Slowly
There is a 75w90 ns too.
What you used won't kill it comma there is just a better option available.
Sent from my SGS2 using Tapa-fkn-talk
Old 08-19-2012, 08:21 PM   #7
roddy
roddy's Avatar
Gotcha... I must have missed it. I'll give that a try next time around. 75W85 seems really light for a rear end. I think the reasoning there is fuel economy.
Old 08-19-2012, 08:55 PM   #8
roddy
roddy's Avatar
It's pretty simple. If no one does a DIY soon, I'll do it next time. If you can change your own engine oil, you can probably do this, no sweat. Remove the plate under the engine first (10 or so bolts and 7 plastic clips), then the one under the transmission (5 or 6 bolts). Both drain/fill plugs are on the driver's side of the transmission case and are easy access once the plates (undertrays?) are removed. The transmission holds about 2.3 quarts.
The differential is even easier...there is nothing in the way. The drain plug is right in the bottom of the housing, and the fill plug is about 1/2 way up on the passenger side. It only takes about 1.3 quarts or so.
If you are thinking about picking up some magnetic drain plugs, don't waste your money...the factory ones are magnetic.There are crush washers. I thought I had the right size here already, but I did not, so I re-used the OE ones and haven't had any leaks.
Old 08-19-2012, 09:11 PM   #9
ArKiTeCkT
ArKiTeCkT's Avatar
^ Im gonna see if I can get those washers for free when I get my oil filter from the dealer
Old 08-20-2012, 01:07 AM   #10
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I'm "once bitten, twice shy" with Redline MT-90.
When I changed my trans oil I noticed it appeared to be identical to the Honda Manual Transmission Lube/Fluid (MTL/MTF). Look, smell, viscosity... Still kicking myself for not catching it and sending it off for analysis along with some Honda stuff for comparo.
Either way, I have the Pennzoil Synchromesh in my transmission and Amsoil 75w-110 in my Diff.
rice_classic is online now   Reply With Quote
Old 08-20-2012, 05:28 AM   #11
BMWDavid
How is that Pennzoil Synchromesh working?
2005 Honda XR650L
2006 VW GTI/DSG
Old 08-20-2012, 07:39 PM   #12
rice_classic
Great. I've used it in my S2000, my 198k mile Prelude, my CRX ITA racecar and now my FRS.
Other than the OEM stuff, it's the only fluid I trust in there to be thin enough at low temps, strong enough at high temps and friendly enough to my yellow metals.
Old 08-20-2012, 08:19 PM   #13
BMWDavid
I've seen it at my FLAPS and I don't recall if it is a synthetic?
2005 Honda XR650L
2006 VW GTI/DSG
Old 08-20-2012, 11:36 PM   #14
rice_classic
Semi-syn is my understanding.
In need of a AT Transmission FRS !! Cowbun CANADA 3 07-27-2012 02:48 PM
What transmission? Ess Vee Engine, Exhaust, Transmission 9 06-25-2012 02:56 PM
Transmission? Pplater AUSTRALIA 1 06-05-2012 07:17 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
Which Transmission ? gatchaman Engine, Exhaust, Transmission 15 10-29-2009 12:48 PM
