Old 08-17-2012, 10:12 PM   #2241
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Originally Posted by Don@Accelerated View Post
No. I had it on mine for a short period, but then had to cut it up for a turbo kit I sold. I need to pop together another. I just hate taking the bumper off.
Ahh, I see. Cant wait to see a pic of it though, Im curious. The itch to go FI is very strong.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 08-17-2012, 11:17 PM   #2242
EN2_Squirrel
EN2_Squirrel's Avatar
pretty sweet
EN2_Squirrel is offline   Reply With Quote
Old 08-18-2012, 09:18 PM   #2243
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
So how is cruising fuel economy with this little turbo? And 280whp is limit of injectors and clutch only, or is there something else limiting you guys?
Coheed is offline   Reply With Quote
Old 08-18-2012, 09:18 PM   #2244
Visconti
Drives: 05 STi
Limit of the injectors on pumpgas.
Visconti is offline   Reply With Quote
Old 08-18-2012, 10:38 PM   #2245
Coheed
Coheed's Avatar
So replacing the port injectors with larger ones only goes so far right? Is the DI the reason for the engine being reliable at 12.5:1? Replacing PI only may give you the headroom to max out the disco potato, but is it going to work reliably without upping the DI as well?
Your thoughts John?
Old 08-19-2012, 01:27 AM   #2246
noAE86
Drives: ae86, etc..
Your thoughts John?
good question,
its going to be pricy to replace DI injectors, i think 280 is going to be a great sweet spot of power to weight for this car,
noAE86 is offline   Reply With Quote
The Following User Says Thank You to noAE86 For This Useful Post:
tripjammer (08-19-2012)
Old 08-19-2012, 01:53 AM   #2247
Visconti
Drives: 05 STi
Your thoughts John?
We'll do just fine with larger Port injectors
Old 08-19-2012, 06:47 AM   #2248
Junebug
Junebug's Avatar
Drives: 2013 scion frs firestorm m/t
Might have been asked before, sorry in advance if it has been asked already but are you guys making 280whp with the stock exhaust still on the car?
Junebug is offline   Reply With Quote
Old 08-19-2012, 08:21 AM   #2249
sierra
Drives: Skoda Yeti DSG diesel 4x4
Originally Posted by Philly View Post
The auto is doing fine, absolutely no issues after 800 km so far. Other than a few electronic errors which John sorted out, the car is a blast to drive. And I have been testing it out thoroughly (i.e. driving hard)!
Having said that, the engine does get pretty hot still, and there's that droning noise (from the oil scavenge pump?) and rough "bubbly" idle (around 900 rpm, warmed up).
Perhaps Don or John can chime in on these things.
Let's hope there aren't any problems with too much heat in these early conversions?
sierra is offline   Reply With Quote
Old 08-19-2012, 09:57 AM   #2250
Don@Accelerated
Don@Accelerated's Avatar
The factory exhaust system is ot a restriction until well over 300hp. We have not reached the point as of yet where we have seen a gain with just the exhaust.
Don@Accelerated is offline   Reply With Quote
Old 08-19-2012, 09:59 AM   #2251
Visconti
Drives: 05 STi
+1
But I would buy Dons exhaust. Sounds perfect, not loud - very very tasteful
Old 08-19-2012, 10:01 AM   #2252
Don@Accelerated
I was getting around 35mpg while cruising. I was out driving like an idiot last night and I averaged around 50 miles on 5 gallons. I did alot of racing. Won a few, lost a few.
The Following User Says Thank You to Don@Accelerated For This Useful Post:
carbonBLUE (08-19-2012)
Old 08-19-2012, 11:53 AM   #2253
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
50 miles on 5 gallons, that aint too bad with a turbo set up...
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 08-19-2012, 01:34 PM   #2254
Don@Accelerated
So looks like I need to upgrade to some drag radials now. The 255/18 Nitto 555's are not up to the task now!
civicdrivr (08-19-2012)
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 11:24 AM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-03-2012 11:24 PM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 07:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 08:14 PM
