Old 08-16-2012, 07:59 PM   #2213
Tman08
Tman08's Avatar
Drives: DGM BRZ Limited
Originally Posted by Don@Accelerated View Post
That is Phils car. John was here setting up the automatic flash file.
Originally Posted by sportsguy83 View Post
Ok, cool. Thanks for the heads up guys. I'm anxious to see how the Auto version progresses as well. Don, Is your top priority at the moment for reliability mostly, or are you looking at both reliability and power, equally in these early stages?
Tman08 is offline   Reply With Quote
Old 08-16-2012, 10:30 PM   #2214
Philly
Philly's Avatar
Drives: Eighty Six Turbo
The auto is doing fine, absolutely no issues after 800 km so far. Other than a few electronic errors which John sorted out, the car is a blast to drive. And I have been testing it out thoroughly (i.e. driving hard)!
Having said that, the engine does get pretty hot still, and there's that droning noise (from the oil scavenge pump?) and rough "bubbly" idle (around 900 rpm, warmed up).
Perhaps Don or John can chime in on these things.
2013 Raven FRS Auto: Accelerated Performance Turbo, Downpipe, Overpipe, Frontpipe, Intake, EcuTek Tune, Perrin Pulley, Greddy SP Elite, Tein S-Tech
Philly is offline   Reply With Quote
Old 08-16-2012, 11:31 PM   #2215
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
How do you know the engine gets hot as compared to stock? Burning fuel always makes heat, are you seeing specific indicators of heat like higher engine water temp or ........? Or do you think it smells hotter or you see whisps of smoke?
If you see/smell none of these things then you may be ok
The idle should be smooth as stock, no reason to be otherwise at all
Toyota 86 test driver
Tradewind is offline   Reply With Quote
Old 08-16-2012, 11:42 PM   #2216
Tradewind
A question here?
Why is the air intake/filter at the hottest point of engine bay?
There is no sense taking in air at 180-200f then compressing and adding at least 150f more before trying to scrub it all off through Intercooler which can only get rid of 65 - 80ish % of whatever temp air came in at. Customers in a hot climate would want to be careful indeed
It's a definite redesign point for next kit iteration AP
Will make turbo compress with less loss (internal leakage due to very hot/thinned air) and provide a lower temp to throttle body allowing either safer tuning or more aggressive tuning. Probably longer turbo life too if truth is known.
In taking hot underhood air is not the go for any true performance arrangement
Old 08-17-2012, 12:10 AM   #2217
Synack
Boosted
Synack's Avatar
Drives: Sideways
Sigh, as my build pictures are coming out, more people who have heard the original results of Don's turbo are talking smack. Seems like the only numbers floating around are the original 215whp @3psi that you guys had. I have to keep telling people 285whp @8spi with the basic kit. Let alone a more advanced kit.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 08-17-2012, 12:35 AM   #2218
3MI Racing
Pro Subie Engine Nerd
3MI Racing's Avatar
Drives: empty spot for an FR-S/BRZ
Originally Posted by wcbjr View Post
Standard Walbro 255lph high-pressure?
edit: hmmm, walbro may not be short enough to drop in
Deatchwerks has that covered...emails are going out to shops for beta. If Don hasn't received something yet, shoot me a message and I'll have Chris contact you.
3MI Racing is offline   Reply With Quote
Old 08-17-2012, 08:09 AM   #2219
Don@Accelerated
Don@Accelerated's Avatar
No it just smells hotter. Most of that will go away. New pipes always smell for a while.
The idle on my car is equal to stock. Not that stock idle was perfect.
Don@Accelerated is offline   Reply With Quote
Old 08-17-2012, 08:10 AM   #2220
Don@Accelerated
More advanced kit? The 290hp setting is still the basic kit, we just needed a little more injector to go further.
Old 08-17-2012, 08:11 AM   #2221
Don@Accelerated
A question here?
The filter arrangement is not going to change. If you would like cold air, you can simply upgrade to the cold air version.
Old 08-17-2012, 08:16 AM   #2222
Don@Accelerated
The stages thus far lean more towards long term reliability. I've been continuing testing at 10psi and will increase here shortly. We will be adding a fuel injector to the car to move forward.
Don
Old 08-17-2012, 08:40 AM   #2223
#87
I usually post drunk
#87's Avatar
Is it possible to use the stock intake location/air box?
#87 is offline   Reply With Quote
Old 08-17-2012, 09:41 AM   #2224
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Might have something to do with the Dyno graph on the first few pages of this thread. maybe he should throw the most recent one up there?
blackfireball5 is offline   Reply With Quote
The Following User Says Thank You to blackfireball5 For This Useful Post:
civicdrivr (08-17-2012)
Old 08-17-2012, 10:06 AM   #2225
Kochinopride
Kochinopride's Avatar
Drives: 13 FR-S, 12 CLS AMG, 05 Lotus Elise
Wouldn't a hood scoop help out with this? Although, I don't think it'd compliment the aesthetics...
2005 Lotus Elise
2012 Mercedes Benz CLS AMG 6.3
2013 Scion FR-S
2011 Land Rover LR4
2013 Lamborghini Gallardo LP570-4 Superleggera
Kochinopride is offline   Reply With Quote
Old 08-17-2012, 10:11 AM   #2226
Don@Accelerated
I'd think the hood scoop would look like dog!
The Following User Says Thank You to Don@Accelerated For This Useful Post:
tripjammer (08-19-2012)
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 11:24 AM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-03-2012 11:24 PM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 07:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 08:14 PM
