Old 08-16-2012, 04:20 PM   #29
wootwoot
Drives: FRS
The Greddy kit won't be out for a few months. I called them.
The HKS kit is $1200 according to their site. A bit too much for an oil cooler in my opinion.... Also, I can't find any vendors that have one in the USA.
Old 08-16-2012, 04:31 PM   #30
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
I am going to make a kit for the BRZ . It should be pretty straight forward for those DIY guys using Mocal parts. I will take pictures and do a write up when I do.
Whats needed -
1. Mocal oil sandwhich plate w/ thermostat 10AN - about $190
2. Oil cooler of your choice - Setrab or Mocal 13 or 16 row - about $165
3. 10an hose + 4 10AN fittings
4. Some kind of metal mounting bracket. Mocal sells universal mounting brackets.
Here is a link to all the kits and components
http://97.74.32.155/files/coolkit.pdf
No Limit Motorsport is offline   Reply With Quote
The Following 3 Users Say Thank You to No Limit Motorsport For This Useful Post:
ATL BRZ (08-16-2012), OjiGeorge (03-02-2014), Trap63 (12-16-2013)
Old 08-16-2012, 04:39 PM   #31
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Mishimoto makes two universal kits. I'm going to have a local shop take a look at my car Saturday to verify they see a way it could work well with the BRZ (reasonably easy mounting location, nothing out of the ordinary)
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 08-16-2012, 04:41 PM   #32
celica73
Whats needed -
http://97.74.32.155/files/cool$.pdf
Does the adapter clear the little oil cup on the BRZ, or is that cup easily removed? Also, is the sandwich plate part MOC-SP1FT or something different?
Old 08-16-2012, 06:20 PM   #33
wootwoot
Drives: FRS
Whats needed -
Awesome! Please keep us updated.
Old 08-16-2012, 09:34 PM   #34
No Limit Motorsport
Their oil cooler kits are pretty low quality. I just had a customer just get the WRX bolt on kit, and the only part we are going to use out of it are the mounting brackets for the cooler and the lines. The core is chintzy looking and worse is their sandwich plate. You can piece together a Mocal kit for not much more.
Mishimoto's radiators are pretty decent though.
Old 08-16-2012, 09:37 PM   #35
No Limit Motorsport
I am going to try and test fit soon, and if it doesn't just bolt on, maybe I will have an adapter(s) made.
Old 08-16-2012, 09:39 PM   #36
pdreams
I am already running it on my car for nearly a week. Your Greddy dealer should be able. to order it. Alternatively, u can order it thru websites like rhdjapan.
pdreams is offline   Reply With Quote
Old 08-16-2012, 10:36 PM   #37
bpracer
Drives: Asphalt FR-S
Originally Posted by dunphyjp View Post
this is going to sound a little funny, but with the HKS system and the lines being as long as they are... would be need to put in any extra oil into our engines? i mean i'm not saying that adding the line and core would suddenly suck up a liter of oil, but would the oil that's running to the cooler through approx 4m of line be lowering the oil level that normally stays within the engine?
I would say, check the oil level after the cooler is added and run once. All the oil will not drain back depending on the setup. Than add to the fill mark.
I'm still waiting on my FR-S to show up, but if the car holds less than 5 qts of oil, I bet it would noticeably lower. The longer the oil lines, the bigger diameter they need to be to lessen oil pressure loss over the hose length.
My road race car holds 12qts and a good part of a quart is in the -12AN oil cooler lines and cooler. -12AN are big lines though...
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
Old 08-16-2012, 11:10 PM   #38
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Yes. This is normal.
ill86 is offline   Reply With Quote
Old 08-17-2012, 12:21 AM   #39
wootwoot
Drives: FRS
Can you provide a link? Can't find it on that site. I also called Greddy in So Cal and they said it was still under development.
Old 08-17-2012, 06:28 AM   #40
pdreams
www.rhdjapan.com. Its the same price as the S2000 kit, so order that. Just specify that your car is 86/BRZ and the part number for the oil cooler when you order. Part number can be found from Greddy Japan website.
Basic - http://www.trust-power.com/php/updat...10410112014631 - 12014631
With duct - http://www.trust-power.com/php/updat...20410112014632 - 12014632
Greddy has 2 part numbers for the oil cooler kit, one of which comes with the oil cooler duct. I went for the basic one as there is more than enough exposure for the oil cooler core after mounting.
I notice that many people have been asking about the extra adaptor to raise the height due to the oil filter housing. From what I have seen, only Greddy has a part number for this part.
Those interested to build their own kit should just get this adaptor as well as the thermostat sandwich plate which has the inlets/outlets for the oil cooler hose as well as sensors.
If getting the Greddy oil cooler kit, everything is provided right down the the oil cooler core brackets, nuts, bolts, plastic hose etc.
Cheers
The Following 2 Users Say Thank You to pdreams For This Useful Post:
ill86 (08-17-2012), MSTiFK8R (08-19-2012)
Old 08-17-2012, 07:11 AM   #41
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
Is anyone planning on making a one-piece adapter plate? Not really a fan of the spacer+adapter design of the Greddy kit.
FrX is offline   Reply With Quote
Old 08-17-2012, 07:13 AM   #42
xjohnx
Grip>Slip
xjohnx's Avatar
$900?!
Greddy oil cooler coming soon DIG1992 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 08-20-2012 12:02 AM
Tomzilla's "That feeling when your car is far cooler than you" BRZ thread. Tomzilla Member's Car Journals 1 06-19-2012 12:10 PM
Greddy Oil and Diff Cooler pdreams Engine, Exhaust, Transmission 3 06-13-2012 08:41 PM
Cooler than drifting! Rampage Other Vehicles & General Automotive Discussions 8 04-03-2012 12:55 AM
