| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#57 | |
Drives: 13 Hot Lava, 01 Miata, 09 Outback
Rolling resistance generally goes the other way. Stickier tires will have lower treadwear ratings and higher rolling resistance. -Justin
#58 |
Drives: B9 S4/ND2
#59 | ||
Drives: 4 Wheels Auto
#60 |
Drives: Car
Yes, most likely. A 235/40/17 or a 245/40/17 are within .1" of the diameter of the stock 215s. However, that is not an absolute. The contact patch, depending on the weight of each corner, may grow laterally and shrink longitudinally.
#61 | |
Drives: Nevermorange FRS
#62 | |
Drives: race cars
http://fecompetition.wordpress.com/ While I respect that they tested, its pretty hard to say a thinner tire is faster when the wider tire they tested has a larger overall diameter. Only think they learned is that a taller tire is slower. surpise...
11/19/12 - Just back from Redline TimeAttack's demo event. Video and write up in link below. http://fecompetition.wordpress.com/ https://www.facebook.com/FECompetition |
#63 |
In layman's terms, upgrade to wider rubber when your car makes enough power to warrant an increase. There is such a thing as "too much tire".
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
| The Following User Says Thank You to Turbowned For This Useful Post: | Justin.b (08-15-2012) |
#64 |
Performance nut
Drives: Nissan Twin turbo 300zx
#65 |
Ridge Racerrrrrrrrr
Or switch out the stock pads for a better track pad - I am sure that would improve the 5 lap average over the stock set up as well
#66 |
They went with 18s because a 'Plus 1' upgrade it pretty common for wheels/tires. I think a lot of guys new to cars would assume that the larger setup would improve everything. I'm not surprised it didn't, and I'm glad they took the time to document it (I's rather not see the Toyobaru become the next stance car tucking 22's while the owner thinks he's made the car faster).
-Justin
#67 | |
I am trying 17x9 +35 square setup (Weds TC105) with 235/40/17 star specs. I think ideal offset would be +38/39 though. Adam Last edited by No Limit Motorsport; 08-15-2012 at 04:19 PM. |
#68 |
Drives: 2008 Fit Sport
^ 3mm is peanuts
#69 |
This video brings up a very good point.
We have driven on few tracks where our car's gearing was not at its max potential. Instead of changing gears in your drive train, you can increase or decrease tire size to maximize the gearing for that particular track. Smaller, and more technical track... the car would benefit with slightly shorter sidewall. We have also noticed that just because you have Huge tires, you're not always faster. You may gain cornering speed, but you also gain drag from the additional rubber on the straightaway, and don't forget the extra weight of the tires. Just being able to drive the car smooth with less corrections will put down a faster lap then a guy with much larger tires that's just throwing the car into a turn and hoping the tires will stick...constantly correcting. |
| The Following User Says Thank You to Touge Factory For This Useful Post: | BRZ NA (09-11-2013) |
#70 | |
Drives: B9 S4/ND2
with that tire I think you're right. My wheels are the same size but I'm running 225/45/17. Ideally the go fast wheel size for this car is +42 or so to fit a 255. |
| Road & Track: 5 minutes to a faster FRS (/BRZ) via Tires | xjohnx | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 11-18-2013 06:31 PM |
| Road and track vid | DIG1992 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 6 | 11-29-2011 10:00 PM |
| Road & Track: Scion FR-S Preview | FutureFT86 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 08-29-2011 10:54 PM |
| GT5 - fastest Suzuka (full track) times | NESW20 | Other Vehicles & General Automotive Discussions | 11 | 04-03-2011 01:20 AM |
| Road & Track says 2013 | Champion | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 09-08-2010 12:33 PM |
