Old 08-12-2012, 12:02 PM   #57
Justin.b
Drives: 13 Hot Lava, 01 Miata, 09 Outback
Originally Posted by miodculae View Post
for the most part, air rolls across and over the body. if the wheels are aligned and/or tucked in the wells, there should be no additional drag.
rolling resistance may increase with a higher UTQG (250-300+) but the difference in MPG would be negligible.
Unless the car is lowered to the ground, wider tires are still going to present more frontal area to the wind. It's not going to make a difference at low speeds and at high speeds it's about the difference of having larger mirrors on the side of the car.
Rolling resistance generally goes the other way. Stickier tires will have lower treadwear ratings and higher rolling resistance.
-Justin
Justin.b is offline   Reply With Quote
Old 08-12-2012, 12:34 PM   #58
D1cker
Drives: B9 S4/ND2
Originally Posted by UncleFester View Post
I was told the 17x9's will be +45.
This would make more sense. I have a set of 17x9 +35 RPF1's on my car now and the front sticks out a bit (stockish height and no camber adjustment yet.)
D1cker is offline   Reply With Quote
Old 08-12-2012, 05:31 PM   #59
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
Originally Posted by Jdogg180 View Post
The larger diameter 18" rim will have it's weight farther from the hub that the same weight 17" rim so it's very likely the straight line performance was reduced as well as braking. It would be a very small amount but the margin as pretty small. So lighter wider 17's would give you more grip and if you can stay under or very close to the weight of the stock wheel tire combo you will see that wider is in fact better.
Originally Posted by LSxJunkie View Post
That is entirely untrue and completely misses the difference between a 215/17 and a 235/18.
See below.
So what you are saying is to keep the 17" rim with wider track, while reducing the profile to keep the same rolling diameter and you should see the performance increase. Is this correct?
Originally Posted by Winding Road FR-S review
What is astonishing about the FR-S is that it combines the cruising comportment and function of the 128i with the dynamics of the Cayman, or Boxster, or S2000.
Want.FR-S is offline   Reply With Quote
Old 08-12-2012, 08:15 PM   #60
LSxJunkie
LSxJunkie's Avatar
Drives: Car
Yes, most likely. A 235/40/17 or a 245/40/17 are within .1" of the diameter of the stock 215s. However, that is not an absolute. The contact patch, depending on the weight of each corner, may grow laterally and shrink longitudinally.
LSxJunkie is offline   Reply With Quote
Old 08-13-2012, 01:09 AM   #61
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Originally Posted by Allch Chcar View Post
You can see that it slowed acceleration going to the wider tires. They use G-meters to monitor acceleration and grip.
I've seen this same phenomenom in Forza (they use a good tire physics system) so I'm not surprised.
Plus it just makes sense, unsprung rolling mass is multiplied compared to sprung mass. Plus bigger tires have more rolling resistance. On modest HP, it makes a significant difference.
Exactly, thus why I used the words "almost" and "within reason".
Old 08-13-2012, 02:17 AM   #62
Matt Andrews
Matt Andrews's Avatar
Drives: race cars
Originally Posted by feldy View Post
That's cool. I want to know what kind of times they would see with a 17x9 wheel with dunlops or even hankooks. Keeps the wider tire but not the gearing issue of the 18s.
I also have a set of 225/45/17 dunlops and kooks that I autocross with.
I've run the test you are curious about. You can see it here.
http://fecompetition.wordpress.com/
While I respect that they tested, its pretty hard to say a thinner tire is faster when the wider tire they tested has a larger overall diameter. Only think they learned is that a taller tire is slower. surpise...
11/19/12 - Just back from Redline TimeAttack's demo event. Video and write up in link below.
https://www.facebook.com/FECompetition
Matt Andrews is offline   Reply With Quote
Old 08-13-2012, 08:05 PM   #63
Turbowned
Turbowned's Avatar
In layman's terms, upgrade to wider rubber when your car makes enough power to warrant an increase. There is such a thing as "too much tire".
The Following User Says Thank You to Turbowned For This Useful Post:
Justin.b (08-15-2012)
Old 08-15-2012, 02:02 PM   #64
Supergoji
Performance nut
Supergoji's Avatar
Drives: Nissan Twin turbo 300zx
Originally Posted by mike2100 View Post
Why do you need bigger brakes?
One would need larger rotors for shorter stopping distances and for keeping heat down for fade free braking on track.
Supergoji is offline   Reply With Quote
Old 08-15-2012, 03:11 PM   #65
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Or switch out the stock pads for a better track pad - I am sure that would improve the 5 lap average over the stock set up as well
Old 08-15-2012, 03:23 PM   #66
Justin.b
They went with 18s because a 'Plus 1' upgrade it pretty common for wheels/tires. I think a lot of guys new to cars would assume that the larger setup would improve everything. I'm not surprised it didn't, and I'm glad they took the time to document it (I's rather not see the Toyobaru become the next stance car tucking 22's while the owner thinks he's made the car faster).
-Justin
Old 08-15-2012, 03:33 PM   #67
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
Originally Posted by D1cker View Post
I bet the car would have been fastest on the 235/40/17's because it would actually slightly increase the gearing...
This is my guess as well. As soon as my wheels get here I will let you guys know.
I am trying 17x9 +35 square setup (Weds TC105) with 235/40/17 star specs. I think ideal offset would be +38/39 though.
Adam
No Limit Motorsport is offline   Reply With Quote
Old 08-15-2012, 05:55 PM   #68
Jdogg180
Jdogg180's Avatar
Drives: 2008 Fit Sport
^ 3mm is peanuts
Jdogg180 is offline   Reply With Quote
Old 08-15-2012, 07:15 PM   #69
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
This video brings up a very good point.
We have driven on few tracks where our car's gearing was not at its max potential.
Instead of changing gears in your drive train, you can increase or decrease tire size to maximize the gearing for that particular track.
Smaller, and more technical track... the car would benefit with slightly shorter sidewall.
We have also noticed that just because you have Huge tires, you're not always faster.
You may gain cornering speed, but you also gain drag from the additional rubber on the straightaway, and don't forget the extra weight of the tires.
Just being able to drive the car smooth with less corrections will put down a faster lap then a guy with much larger tires that's just throwing the car into a turn and hoping the tires will stick...constantly correcting.
Touge Factory is offline   Reply With Quote
The Following User Says Thank You to Touge Factory For This Useful Post:
BRZ NA (09-11-2013)
Old 08-15-2012, 08:32 PM   #70
D1cker
Drives: B9 S4/ND2
Adam
with that tire I think you're right. My wheels are the same size but I'm running 225/45/17. Ideally the go fast wheel size for this car is +42 or so to fit a 255.
Road & Track: 5 minutes to a faster FRS (/BRZ) via Tires xjohnx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 11-18-2013 06:31 PM
Road and track vid DIG1992 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 11-29-2011 10:00 PM
Road & Track: Scion FR-S Preview FutureFT86 Scion FR-S / Toyota 86 GT86 General Forum 3 08-29-2011 10:54 PM
GT5 - fastest Suzuka (full track) times NESW20 Other Vehicles & General Automotive Discussions 11 04-03-2011 01:20 AM
Road & Track says 2013 Champion Scion FR-S / Toyota 86 GT86 General Forum 6 09-08-2010 12:33 PM
