| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#43 |
Oversteer > Understeer
Drives: GT86
Lightweight 17s (RPF1s) w/ 215s sounds like the way to go. (or maybe w/ 245/40R17?... same diameter)
18s look nice, but clearly not the best for lap times. Let alone Portland's shitty streets. Can't wait for Enkei to come out with their 17x9 +35 RPF1s in 5x100! |
#44 |
Interesting read. I'll look into stickier tires for next summer!
#45 | |
Drives: 13 Hot Lava, 01 Miata, 09 Outback
I'm pretty sure the stock tires were installed as training wheels, with the understanding that they be replaced when the owner/driver is ready to push the car a little higher. (They also, no doubt, were installed to try to get acceptable mpg numbers for the car). -Justin |
#46 |
Drives: 2008 Fit Sport
The larger diameter 18" rim will have it's weight farther from the hub that the same weight 17" rim so it's very likely the straight line performance was reduced as well as braking. It would be a very small amount but the margin as pretty small. So lighter wider 17's would give you more grip and if you can stay under or very close to the weight of the stock wheel tire combo you will see that wider is in fact better.
#47 |
Drives: B9 S4/ND2
The problem I see with this is that they went 235/40/18 instead of 235/40/17. I bet the car would have been fastest on the 235/40/17's because it would actually slightly increase the gearing...
#48 |
Drives: FR-S Whiteout
#49 |
Loves the Smell of Track
Drives: '13 86
I'm running Enkei PF01 17x8 w 235/40 17 Star Specs. Compared to stock, diameter was ~1/4" less and weight was up ~ 4oz. See post #16 here:
http://www.ft86club.com/forums/showthread.php?t=7934 I ran 17x9 RPF1s with the same tire on my NC Miata, which probably gives slightly better turn in. Surely the magazine guys knew the 18s would be slower. Maybe that was just the size they could source for free/cheap. For me, the best news in the article was that the stock suspension help up to the extra grip, as I have not tracked my 86 yet. Then again, there's a reason the only car mag I read is GRM.
2020 86 Hakone MT build thread: https://www.ft86club.com/forums/show...31#post3326231
2013 Toyobaru 86/FR-S 6MT, Red, aka Candy O SOLD http://www.ft86club.com/forums/showthread.php?t=7934 Last edited by phm14; 08-10-2012 at 06:10 PM. |
#50 | |
Drives: 4 wheels
| The Following User Says Thank You to bucket For This Useful Post: | phm14 (08-10-2012) |
#51 |
Hypnotic FRS Member
Drives: FR-S [Raven]
so, do you sacrifice any MPG with stickieer tires ? i meant to say, with the same size-diameter -- im assuming the compound might not be as gas friendly as the prius tires...
just wondering...
MotegiRacing - TRD Racing -OemAudio++- Michellin Pilot SuperSports- Greddy -FiveAxis - SparksScion - BlueBat Overlays -Pioneer -SWIFT Engineering Sports- Evasive Motorsports- SoCAL |
#52 |
Performance nut
Drives: Nissan Twin turbo 300zx
but then there is also the issue of brakes. you can only fit a 13 inch rotor under a 17. with 18's you can do a 14inch.
#53 | |
FRS Adept
Drives: Firestorm FRS
rolling resistance may increase with a higher UTQG (250-300+) but the difference in MPG would be negligible. |
#54 |
Drives: 23 BRZ
#55 |
#56 | ||
Drives: Car
See below. Quote:
| Road & Track: 5 minutes to a faster FRS (/BRZ) via Tires | xjohnx | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 11-18-2013 05:31 PM |
| Road and track vid | DIG1992 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 6 | 11-29-2011 09:00 PM |
| Road & Track: Scion FR-S Preview | FutureFT86 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 08-29-2011 09:54 PM |
| GT5 - fastest Suzuka (full track) times | NESW20 | Other Vehicles & General Automotive Discussions | 11 | 04-03-2011 12:20 AM |
| Road & Track says 2013 | Champion | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 09-08-2010 11:33 AM |
