Old 08-12-2012, 09:12 PM   #15
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
-OEM crash bolts
-Stock wheels w/ 225/45/17 star specs. -Sheet attached below. Name:  ImageUploadedByTapatalk1344816683.237434.jpg
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 08-12-2012, 09:14 PM   #16
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Originally Posted by NYC BRZ View Post
-OEM crash bolts
-Stock wheels w/ 225/45/17 star specs. -Sheet attached below. Attachment 12696
Picture of me and QuikJ. Mine was done and his was going on the Hunter Hawkeye at RCT Performance in Queens, NY. He elected to go with 215/45/17 star specs.
Old 08-12-2012, 09:20 PM   #17
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Forgot the pic. Lol. Name:  ImageUploadedByTapatalk1344817247.464339.jpg
Old 08-12-2012, 11:26 PM   #18
hankster
hankster's Avatar
Drives: 2013 FR-S Argento
What is the source and part number for the crash bolts?
hankster is offline   Reply With Quote
Old 08-12-2012, 11:38 PM   #19
simpleisbest
Senior Citizen
Drives: Scion FR-S
Picked up mine from a Subaru dealer.
Edited: PN# 901000394.
simpleisbest is offline   Reply With Quote
The Following User Says Thank You to simpleisbest For This Useful Post:
hankster (08-13-2012)
Old 08-13-2012, 12:33 AM   #20
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
PN# 20540AA090.
That's them we got them on our FR-S as well for Nationals.
A must have for RTR or CS.
FT-86 SpeedFactory is offline   Reply With Quote
Old 08-13-2012, 01:38 AM   #21
xwd
The right bolt is 901000394, not the Impreza concentric bolt which I think is the 20540AA090 one. If the Impreza one fits its not the right bolt and technically at an event you could get protested for using it.
Old 08-13-2012, 03:17 AM   #22
simpleisbest
Senior Citizen
Drives: Scion FR-S
My bad. The PN I bought was 901000394.
(Got lazy when I posted and copied PN from http://fecompetition.wordpress.com/ without checking my own bag of parts)
Post edited so as to not put out any mis-information.
Old 08-13-2012, 08:23 AM   #23
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
These are the ones I got. I believe they are just 14mm bolts vs the stock 16mm so you get some more play. Well worth the <$10 investment.
Old 08-13-2012, 12:29 PM   #24
hankster
hankster's Avatar
1) what is the torque setting for the crash bolts?
2) after installing crash bolts, do you adjust for max camber you can get? This is for a daily driver and autox
Old 08-13-2012, 12:32 PM   #25
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
You wont get more than -1.5 camber likely so it is plenty for DD, just get the car aligned after, get that toe corrected.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
The Following User Says Thank You to Kido1986 For This Useful Post:
Old 08-13-2012, 01:43 PM   #26
edj
edj's Avatar
Drives: 2022 Toyota GR86
torque on the front camber bolts is 115 ft./lbs.
edj is offline   Reply With Quote
The Following User Says Thank You to edj For This Useful Post:
Old 08-13-2012, 02:17 PM   #27
simpleisbest
Senior Citizen
Drives: Scion FR-S
Looking at the FSM, it seems that alignment on the rear can be wiggled for minor adjustment. For adjustment it recommends adjusting the installation bolt holding the rear suspension member to the vehicle body, or the bolt holding the upper control arm and rear suspension arm to achieve the recommended camber. Don't really know how much adjustability can be had, though...I should find out later this week!
Old 08-13-2012, 02:31 PM   #28
bladesamurai
Drives: 13 BRZ, 04 SV650
So PN#901000394 is an OEM part and I can use it while still staying in the stock class?
bladesamurai is offline   Reply With Quote
alignment, rtr, stock class
Alignment Specs? 86_ZN6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 06-10-2013 07:30 PM
where to get alignment? FML Hawaii 2 08-08-2012 02:36 AM
Alignment needed after lowering car? Lowellrenzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-16-2012 03:57 PM
Whiteline alignment products Nardi330 AUSTRALIA 4 06-16-2012 04:25 AM
is the alignment on the FRS/BRZ adjustable? neveronlinefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-05-2012 04:58 PM
