Old 08-09-2012, 08:42 PM   #15
DatDudeLoso
DatDudeLoso's Avatar
Drives: 2013 Scion FR-S Raven
Originally Posted by kmbkk View Post
If you come up with a solution to the gap, let me know!
I bought the Metra 95-8202 Toyota DDIN Multi Dash Kit off of amazon a few minutes ago. Gonna try that out and see how it looks. I couldn't really tell from the pics i've seen from that DIY (cable route near trans) if it's what i want it to look. If all else fail i'll probably use it as a baseline to fab something more flush. If i have to come up with a tweak or two during install i'll more than likely put up a new DIY thread.
DatDudeLoso is offline   Reply With Quote
Old 08-09-2012, 09:22 PM   #16
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
The brz in Canada has a really nice kit for their nav. I'm sure it has to be available somewhere.
Flat Black VW is offline   Reply With Quote
Old 08-10-2012, 02:12 AM   #17
cruzinbill
Drives: Argento 6spd FR-S
Originally Posted by Flat Black VW View Post
you can use a harness that plugs into the factory ports. Its a metra part # 70-1761. when you use that it still has open ends on the other side which will need to be soldered to the harness that comes with your radio. I assume this is the soldering everyone is talking about, you can cut your factory harness off and solder the aftermarket radio connections directly on, but it is a bunch of extra work tracking down color codes and its harder to revert back to factory if you ever want to.
I thought he was talking about needing to splice in for ebrake and reverse, hell no on cutting off the harness. There should be one out to adapt already.
cruzinbill is offline   Reply With Quote
Old 08-10-2012, 10:06 AM   #18
DatDudeLoso
I just thought about this. I dont think i wanna do the whole routing of the USB cable for my iPhone. anyone know a way to get the factory USB/AUX port right near the shifter to work with aftermarket units??
Old 08-10-2012, 10:17 AM   #19
encity5
encity5's Avatar
http://www.ft86club.com/forums/showt...ftermarket+usb
encity5 is offline   Reply With Quote
The Following User Says Thank You to encity5 For This Useful Post:
DatDudeLoso (08-10-2012)
Old 08-10-2012, 11:32 AM   #20
wheelhaus
wheelhaus's Avatar
Agreed. I've installed all my friend's audio units, soldering and taping each time. There were probably a few cold solders, but that's better than a vampire tap or quick connect coming loose.
tape? no no, gotta use heat shrink!
Old 08-10-2012, 12:19 PM   #21
OrbitalEllipses
Drives: Attitude
I hate heat shrink.
Old 08-10-2012, 03:17 PM   #22
Flat Black VW
I agree with this, if solder heat shrink is a must, electrical tape just wont hold up in the long run. I honestly prefer butt connectors to anything. Using them I could wire up quite a few harness' before someone could solder and heat shrink one, and as long as you don't use cheap crappy butt connectors they will hold up fine.
looking for a head unit for Fr-s like the Brz. enjoi23 Electronics | Audio | NAV | Infotainment 5 08-08-2012 02:51 PM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 02:42 AM
New head unit/speakers Dkittrell Electronics | Audio | NAV | Infotainment 5 06-27-2012 03:01 PM
head unit in GTA excited86 Electronics | Audio | NAV | Infotainment 1 06-18-2012 07:42 PM
Crappy Head Unit ? Why ! rikdrt1 Electronics | Audio | NAV | Infotainment 20 06-18-2012 09:57 AM
