Old 08-07-2012, 06:50 PM   #43
SYC086
Drives: JDM MA70 beater & 86 GTS on order
Originally Posted by os86 View Post
Did you not hang around to see the results ???
Believe me I wanted to but I didn't have time
SYC086 is offline
The Following User Says Thank You to SYC086 For This Useful Post:
os86 (08-08-2012)
Old 08-07-2012, 07:14 PM   #44
MANDALAY
Drives: MR2
Originally Posted by Rocketogre View Post
Wait, so are you claiming that the lower inertia dyno rollers used on that 4wd dyno make it more accurate than single high-inertia roller 2wd dynos?
Yep,
If i was a dyno queen i can put my car on a single wheel dyno and up will go the figure.
MANDALAY is offline
Old 08-07-2012, 08:24 PM   #45
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
I claim BS. A mustang or a dynojet reads the same, regardless of where on the planet you are located. If you guys can't get a dynojet, then it sucks to be you :P
Dynojet and mustang are like the gold standards. And everyone knows dynapack reads high, so neener neener.
Coheed is offline
Old 08-07-2012, 09:49 PM   #46
xwd
Will be interested to see the numbers.
Comparing dyno numbers from different dynos is stupid. Just want to see the before and after and the difference on the same dyno.
At least we aren't like the UK guys who like to state flywheel HP (BHP) for everything, that's even more of a guessing game.
xwd is offline
Old 08-07-2012, 10:20 PM   #47
WTF
WTF's Avatar
Drives: FT86, BMW 5, JZA80, Porsche 986S
Most places in Australia use the dyno dynamics dynos. I have never actually seen a place in Aus with a single roller dyno, and I have been to a lot of shops.
Australian dyno's typically read lower than USA dynos, for this reason, at the end of the day unless you are after outright dyno queen numbers, it shouldn't matter. All that should matter is that you compare before/after mods on the same dyno.
600hp Built FA20 Widebody Toyota 86/FRS.. build thread
WTF is offline
The Following 3 Users Say Thank You to WTF For This Useful Post:
Coheed (08-07-2012), fuddbutter (08-08-2012), meeks (08-26-2012)
Old 08-07-2012, 10:25 PM   #48
Coheed
Coheed's Avatar
Exactly right. In a way, a hp is a hp. It would be ridiculous if 1/4 mile times were affected because every country made up their own length of track. Imagine running 11.50 in USA, and 11.80 in AU, and 10.0 in EU. That's how I feel dyno numbers can be a lot of times.
At the end of the day, 550lb moving 1ft/sec is 1 hp. With a fixed measurement like that, why are some dynos reading low, and others reading high? It's like buying calculators in different countries, plugging in the same numbers and equations, and getting a different result. What a joke.
Coheed is offline
Old 08-07-2012, 10:28 PM   #49
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
it's not unusual to see a 300hp "Dyno Dynamics" car run more MPH than a 300hp "Dynojet" car at the 1/4.
JP is offline
Old 08-07-2012, 10:34 PM   #50
Danzzt231
Drives: GT86
Hi Jason.
Danzzt231 is offline
Old 08-07-2012, 10:38 PM   #51
xwd
Aren't all the 1/4 mile (or whatever it is in metric) tracks in Australia run downhill at a 10 degree slope?
xwd is offline
Old 08-07-2012, 10:41 PM   #52
serialk11r
Drives: '06 AM V8V Coupe
550lb acting on a 1 ft long lever spinning 1 revolution per second you mean? (I have no idea what the correct number is)
I'm pretty sure it's a matter of calibration, and drivetrain mass. When you run a car on a dyno, the data gets fudged because you have the drivetrain accelerating, the rollers have rotational inertia, etc. So they may all be standardized and supposedly accurate to say a few percent, but then the actual amount of power they're measuring isn't so clear because not all the power makes it to the rollers in the "intended" way, whatever that is. So you can end up with huge differences.
serialk11r is offline
The Following User Says Thank You to serialk11r For This Useful Post:
M3power326 (10-18-2012)
Old 08-07-2012, 10:47 PM   #53
Coheed
Coheed's Avatar
Originally Posted by serialk11r View Post
550lb acting on a 1 ft long lever spinning 1 time per second you mean? (I have no idea what the correct number is)
I'm pretty sure it's a matter of calibration. When you run a car on a dyno, the data gets fudged because you have the drivetrain accelerating, the rollers have rotational inertia, etc. So they may all be standardized and supposedly accurate to say a few percent, but then the actual amount of power they're measuring isn't so clear because not all the power makes it to the rollers in the "intended" way, whatever that is.
By definition, a "horsepower" is the ability to get work done at the rate of 550lbs moved 1ft in one second. Or 1lb moved 550ft in 1 second. If you took a 1ft circumference, sure your method works. But on a 1ft lever it would be ~6.28ft, so it doesn't make sense to the calculation.
I like the dynojet for actual hp calculation. Spin a roller of xxx weight to xxx speed in xxx time = whp. Very simple and basic math. Use the RPM signal to reverse calculate the wtq output.
Coheed is offline
Old 08-07-2012, 10:50 PM   #54
serialk11r
By definition, a "horsepower" is the ability to get work done at the rate of 550lbs moved 1ft in one second. Or 1lb moved 550ft in 1 second. If you took a 1ft circumference, sure your method works. But on a 1ft lever it would be 3.14ft, so it doesn't make sense to the calculation.
It takes zero horsepower to move 550lbs 1ft in 1 second
Sorry, nitpicking is my hobby. You mean it's exerting a force of 550lbs over a distance of 1 foot in 1 second.
Old 08-07-2012, 10:55 PM   #55
Jordo!
Enjoy it, destroy it.
Jordo!'s Avatar
Drives: Datsun Racing Hen
This is exactly what the car needs.
Nice!
Slap on a A2W IC, offer a nice re-designed hood with fat bulge and/or scoop and call it a day.
You want a flat and fat torque curve -- can't beat a roots blower!
Jordo! is offline
Old 08-07-2012, 10:57 PM   #56
Coheed
Coheed's Avatar
No. If it is moving 1ft/sec, work is being accomplished. Now applying 550ftlbs torque to something doesn't mean work is being done, but by moving it you are causing work to be done. Work being done is calculated in hp.
Coheed is offline
Our Silver Bullet - FT-86 SpeedFactory FT-86 SpeedFactory Member's Car Journals 151 10-06-2016 11:57 PM
