#44 |
Drives: MR2
#45 |
Drives: DGM BRZ Limited
I claim BS. A mustang or a dynojet reads the same, regardless of where on the planet you are located. If you guys can't get a dynojet, then it sucks to be you :P
Dynojet and mustang are like the gold standards. And everyone knows dynapack reads high, so neener neener. |
#46 |
Will be interested to see the numbers.
Comparing dyno numbers from different dynos is stupid. Just want to see the before and after and the difference on the same dyno. At least we aren't like the UK guys who like to state flywheel HP (BHP) for everything, that's even more of a guessing game. |
#47 | |
Drives: FT86, BMW 5, JZA80, Porsche 986S
Most places in Australia use the dyno dynamics dynos. I have never actually seen a place in Aus with a single roller dyno, and I have been to a lot of shops. Australian dyno's typically read lower than USA dynos, for this reason, at the end of the day unless you are after outright dyno queen numbers, it shouldn't matter. All that should matter is that you compare before/after mods on the same dyno.
600hp Built FA20 Widebody Toyota 86/FRS.. build thread
| The Following 3 Users Say Thank You to WTF For This Useful Post: |
#48 |
Exactly right. In a way, a hp is a hp. It would be ridiculous if 1/4 mile times were affected because every country made up their own length of track. Imagine running 11.50 in USA, and 11.80 in AU, and 10.0 in EU. That's how I feel dyno numbers can be a lot of times.
At the end of the day, 550lb moving 1ft/sec is 1 hp. With a fixed measurement like that, why are some dynos reading low, and others reading high? It's like buying calculators in different countries, plugging in the same numbers and equations, and getting a different result. What a joke. |
#49 |
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
it's not unusual to see a 300hp "Dyno Dynamics" car run more MPH than a 300hp "Dynojet" car at the 1/4.
#50 |
Drives: GT86
Hi Jason.
#51 |
Aren't all the 1/4 mile (or whatever it is in metric) tracks in Australia run downhill at a 10 degree slope?
#52 | |
Drives: '06 AM V8V Coupe
I'm pretty sure it's a matter of calibration, and drivetrain mass. When you run a car on a dyno, the data gets fudged because you have the drivetrain accelerating, the rollers have rotational inertia, etc. So they may all be standardized and supposedly accurate to say a few percent, but then the actual amount of power they're measuring isn't so clear because not all the power makes it to the rollers in the "intended" way, whatever that is. So you can end up with huge differences. |
| The Following User Says Thank You to serialk11r For This Useful Post: | M3power326 (10-18-2012) |
#53 | |
I like the dynojet for actual hp calculation. Spin a roller of xxx weight to xxx speed in xxx time = whp. Very simple and basic math. Use the RPM signal to reverse calculate the wtq output. |
#54 | |
![]() Sorry, nitpicking is my hobby. You mean it's exerting a force of 550lbs over a distance of 1 foot in 1 second. |
#55 |
Enjoy it, destroy it.
Drives: Datsun Racing Hen
This is exactly what the car needs.
Nice! Slap on a A2W IC, offer a nice re-designed hood with fat bulge and/or scoop and call it a day. You want a flat and fat torque curve -- can't beat a roots blower! |
#56 |
No. If it is moving 1ft/sec, work is being accomplished. Now applying 550ftlbs torque to something doesn't mean work is being done, but by moving it you are causing work to be done. Work being done is calculated in hp.
| Our Silver Bullet - FT-86 SpeedFactory | FT-86 SpeedFactory | Member's Car Journals | 151 | 10-06-2016 11:57 PM |
