Old 04-20-2026, 07:11 PM   #1
cgull
Drives: 2019 BRZ Limited
Improving camber on stock suspension
I'm doing 50/50 autocross/track on a daily driver. I want to improve front camber so my tire shoulders don't get eaten up and to get less understeer.
I'm on stock suspension, and this is a daily driver through the winter for skiing. I'm never going to be interested in lowering this car, I shovel a lot in the winter already. (It's a good trade off, I get to drive a sports car on twisty mountain roads all winter! On squishy 16" winter tires)
I'm thinking -2 or -2.5 degrees and 0 toe on the front. It looks like I can get there either by eccentric upper/lower bolts, or by the Pedders top hats and less bolts. Which is the better way to go? Do 245s clear the strut with eccentric bolts?
I see plenty of cheap eccentric bolts on Amazon, and then the Whiteline bolts at 3x the price. Any opinions there?
cgull is offline   Reply With Quote
Old 04-20-2026, 10:03 PM   #2
Ohio Enthusiast
Drives: 2018 BRZ
Pedders plus top hole camber bolt is probably the best bet. Although I did run camber bolts top and bottom I wouldn't recommend it much - very fiddly to adjust and setup, and you quickly run into clearance issues with the spring perch on stock struts.
Also consider adjustable top hats. Pedders have really gone in price in recent years (remember they' typically priced for one, so double the listed price).
What wheel specs (width and offset)? Spacers? Stock struts? Most likely not. I was having clearance issues on stock wheels and stock struts at -2 from camber bolts alone.
17x9 +35 should probably work. +45 probably won't or will need spacers.
I'd get SPC - most every aftermarket manufacturer just resells SPC bolts.
Ohio Enthusiast is online now   Reply With Quote
Old 04-20-2026, 10:42 PM   #3
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
I ran -2.75* front camber with Pedders top mounts and double camber bolts on Koni Yellows and TRD springs.
My alignment guru stated -3.50* was possible but too extreme for my 99% commuter situation.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 04-22-2026, 05:16 PM   #4
cgull
I went with Pedders top hats and SPC bolts. Pedders are still cheapest, and I'm not keen on the idea of aluminum top hats on a winter daily driver.
I'm still on stock 17x7 wheels and 215/45 tire size, I'm just looking ahead to the next set of tires and maybe wheels. Thanks for the info.
Improving at Buttonwillow with 86 Cup - shaving a second off my personal best mav1178 Tracking / Autocross / HPDE / Drifting 0 06-30-2015 12:03 PM
A discussion on improving ride quality RYU Suspension | Chassis | Brakes -- Sponsored by 949 Racing 305 06-10-2015 06:55 AM
Improving Steering Feel sittinSideways Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 08-18-2014 06:52 PM
Simple mods to improve handling while improving looks? Jinzen Scion FR-S / Toyota 86 GT86 General Forum 11 06-07-2013 11:48 AM
