Old 10-28-2025, 08:22 PM   #71
steverife
Drives: 2016 Scion FRS
I'm not sure if the Invidia has less clearance than other choices, but mine scrapes seemingly everywhere.
steverife is offline   Reply With Quote
Old 01-15-2026, 08:07 AM   #72
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Question. As far as I understand, you want to get as many bushings as you can as long as they fit where the OEM part goes, such as the Whiteline LSD Inserts, Transmission, ETC. Or get OEM+ components like the STi LSD bushings, transmission mount, engine mounts.
What would be the complete list of bushings/inserts that I would be able to get. So far I have;
STi Transmission Mount
STi Engine Mounts
STi LSD Mounts
Perrin Poly Sway bar bushings
@Racecomp Engineering Rear Subframe Mounts?
STi Trailing Link Set?
spcmafia is offline   Reply With Quote
Old 01-15-2026, 12:29 PM   #73
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
STI trailing link set uses sphericals so it's not legal, FYI.
The Following User Says Thank You to DocWalt For This Useful Post:
spcmafia (01-15-2026)
Old 01-15-2026, 12:48 PM   #74
spcmafia
spcmafia's Avatar
Alright, sweet, I'll remove it from my list.
The Following User Says Thank You to spcmafia For This Useful Post:
DocWalt (01-15-2026)
Old 01-16-2026, 09:19 AM   #75
Autoxer62
You can replace these with poly bushings, just make sure they aren't metal sphericals:
- Front lower (well, we only have lower) control arms
- Steering rack
- Rear subframe to body inserts
- Rear lower control arm
- Rear trailing link
You already have all the powertrain mount stuff that I can think of.
--Bryan
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
The Following User Says Thank You to Autoxer62 For This Useful Post:
Racecomp Engineering (01-19-2026)
Old 01-23-2026, 10:25 AM   #76
spcmafia
spcmafia's Avatar
- Steering rack
--Bryan
- Steering rack
I couldn't really find or I am not really sure what would be acceptable for the last two. I think I got most of the other bushings right?
Old 01-24-2026, 07:07 PM   #77
Autoxer62
- Steering rack
I installed SuperPro front control arm bushings, the kit came with both bushings for each control arm
Steering rack and subframe to body inserts I have Whiteline, what you have looks pretty much the same as I recall.
On the rear lower control arm, I have SPC adjustable arms with Diftech delrin bushings. Not sure what the availability is on those now.
Can't recall if I'd found anything for the trailing arms, I don't think I've put anything in yet. Right now the car is kinda stuck in my shop waiting for me to install the oil pan and pickup.
Old 01-28-2026, 01:08 AM   #78
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
- Steering rack
I got verus rear LCAs with the poly bushing. Very expensive, but also very pretty. SPC RLCAs is what most people go with. Just make sure it's not replacing the bushing with a pillowball.
Also: "Build Thread"
Spuds is online now   Reply With Quote
Old 01-28-2026, 07:17 AM   #79
spcmafia
spcmafia's Avatar
Ah, NoHaveMSG actually sent me the Whiteline Adjustable LCAs. I think those are good?
Whiteline LCA
Old 01-28-2026, 08:11 AM   #80
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
Whiteline LCA
Those ones are great. I had them before I moved to SPL. Now they are on the wife's WRX and, again, great.
RT-BRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to RT-BRZ For This Useful Post:
spcmafia (01-29-2026), Spuds (01-28-2026)
Old 01-28-2026, 08:24 PM   #81
Spuds
The Dictater
Spuds's Avatar
Whiteline LCA
Look good to me.
The Following User Says Thank You to Spuds For This Useful Post:
Old 01-31-2026, 08:47 AM   #82
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
FWIW Cusco upper arms save a lot more weight and then do MOOG K90473 camber bolts in the LCA to subframe position. Cheaper, saves more weight, and gets more useful adjustment. Plus you can effectively narrow the rear track for more space to cones.
RT-BRZ (01-31-2026)
Old 02-01-2026, 03:46 PM   #83
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
How do you feel about the racer x upper arms ?
autoracer86 is offline   Reply With Quote
Old 02-02-2026, 09:31 AM   #84
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Double the price of Cusco for no reason, IMO.
autoracer86 (02-02-2026)
2025 SCCA Time Trials Rules - General Discussion RT-BRZ Tracking / Autocross / HPDE / Drifting 13 01-26-2025 02:42 PM
SCCA T4 Build thread rice_classic Tracking / Autocross / HPDE / Drifting 278 08-09-2023 12:29 PM
SCCA XSA thread Breadman Tracking / Autocross / HPDE / Drifting 31 07-14-2023 05:42 PM
2019 CDC & SCCA Autocross Thread JakeRogue Mid-Atlantic 15 05-17-2019 09:58 AM
2015 SCCA Solo Nationals Thread Jawnathin Tracking / Autocross / HPDE / Drifting 140 09-15-2015 01:00 PM
