Old 01-15-2019, 11:42 PM   #1
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
SCCA T4 Build thread
JUNE 2021 UPDATE: BUILD LIST
It was time to put everything in 1 place.
SAFETY:
  • Cage
  • Window net
  • Window net kit
  • Fire Extinguisher w/ quick release mount
  • Kill Switch
  • Seat - Recaro
  • Belts - GFORCE (schroth replicas) 2" HANS 6pt pull up
  • Wheel/Hub/Release - NRG Wheel with NRG adapter and Quick release
  • Seat mount/slider - Buddy Club low profile mount, sparco slider
  • Tow straps - Sabelt on Amazon
  • Tug shafts for tow straps - Raceseng. If I had to again I would probably get the Tug Strap which wasn't around when I built this: https://raceseng.com/tug-strap-model-specific#
SUSPENSION/BRAKES
  • Eibach kit - per rules
  • Shocks - MCS w/ Custom perches (From Dynasty), Bilstein B8s/B14s are great too - will need custom perches for B14s. If you're wealthy you can always get the $7000 Penskes.
  • Rear Top hats - Not needed for Bilstein, 1" or 2" top hats from Raceseng with MCS.
  • Camber Plates - Raceseng CASCAM + lower crash bolt
  • SPC 67660
  • SPC 67655
  • Enkei RPFI and Motegi Traklite
  • Spacers - 15mm w/ RPF1 and 20mm w/ Motegi
  • Studs - ARP
  • Brake duct - Verus or ARP kits are fine. I did a custom 5" intake duct behind front grill.
  • Brake Pads - Raybestos ST47 Front, ST43 rear. May try G-LOC, seem to perform equally but have contingency
  • Rotors - Centric Premium, Duralast Gold (high carbon) Napa high carbon
  • Fluid - Diff: 75w-90 syn, Trans: Pennzoil synchromesh, Engine: 0w-40 or 10w-30High Mileage (zinc), Amsoil or Swepco grease in Axles. ATE Type 200 brake fluid
  • Tires - Hoosier A7/R7 225/40/17
  • Air filter - K&N
  • Strut Tower Brace - Switch back to stock braces.
  • Diff cover - Greddy
  • Sway bar end links: RacerX Fabrication
  • Stock Clutch (which is exedy) but I think the Stage 1 Exedy is now legal per the rules.
OTHER:
  • A/C Delete
  • Oil Cooler - Jackson Racing
  • OEM header Cat removal - Local fabricator
  • Gauges/senders - Oil pressure/temp. I no longer use the AFR gauge, not necessary.
  • Fumoto valve
  • Exhaust/overpipe/frontpipe - JDL 3" over/front pipe combo with 2.5" flange to work with stock manifold and 3" rear flange to work with Greddy RS 3" catback exhaust.
  • ECUTek license, cable/tune
  • Aim SOLO 2 DL
  • Wheel Bearings/Hubs - Centric or SKF. Switching away from Timken because China.
  • Custom made Cool shirt box
  • 17mm head steel lug nuts
  • 55mm Restrictor Plate
  • GeraldJust TracBOX w/ custom pushbutton for pedal dance.
  • Lead bar for ballast weight - I have since removed the spare tire and tow hitch
  • Pedal spacer to adjust gas pedal for better heel-toe and pedal covers.
  • Heat Shielding - OEM manifold shields, header wrap on collector part of manifold, Over pipe and most of frontpipe and heat shields on exhaust where it passes by the diff/CV joint. Without managing the Exhaust heat you will experience shorter life in: Coil pack, Trans fluid, Diff fluid and CV joint. Shielding dramatically improves the service interval of all these things.
GENERAL SETUP:
  • Lowered about 1.5" - corner balanced
  • Front Toe zero, Front Camber -3.5*
  • Rear toe zero, rear camber -3.0
  • Flip front pads on the rotor every couple sessions, flip rears on rotor every couple weekends. This counters the tapering.
ORIGINAL POST:
After 15 years of w2w racing I learned something about myself... I like racing more than wrenching so it's time to build a car for a class that doesn't require metric tones of cash and time to play in. That's SCCAs Touring-4
Relatively affordable entry price, relatively low operational expense.
T4 is great because I don't have to touch the engine, transmission, clutch or differential. It's just safety, suspension, cooling, chassis setup, tune, tires and brakes. No fancy shop here, no sponsors and it's all done in my garage with only some exception (like the cage). I will even be doing paint in my garage.
My goal is to take my current FRS to make it fully race ready for <$15k. I like to spoil myself so this may be difficult but here it goes.
Out with the old and in with the new:
IMG_0081 by Rice Classic, on Flickr
Due to the rules that specs the suspension (eibach prokit and non adj shocks) and an exhaust that exits in the stock location - you can easily build a race car with off the shelf parts.
IMG_0084 by Rice Classic, on Flickr
IMG_0088 by Rice Classic, on Flickr
IMG_0093 by Rice Classic, on Flickr
While putting the exhaust on the nut seized on the bolt for the exhaust flange..
IMG_0094 by Rice Classic, on Flickr
Improvise, adapt, overcome - use one from my many Honda parts bin with a couple washers to mirror the dimensions.. Voila!
IMG_0095 by Rice Classic, on Flickr
Now that parts starting showing up it was time to gut the car. Of course of course.. the VERY first bolt I touch (seat bolt) is stuck and bugger up the head forcing me to get out a cutting wheel, chisel, hammer etc etc.
But it came out..
IMG_0136 by Rice Classic, on Flickr
The rest of the interior was pretty straight forward, however I did have to watch a couple YouTube videos.
IMG_0143 by Rice Classic, on Flickr
I am gonna miss this stereo - I just worked. In a world of "smart everything" I loved the simplicity and functionality of it. I'm pretty sure there's a mystery CD in it for whomever wants this ol' relic.
IMG_0210 by Rice Classic, on Flickr
Next step - Roll Cage.
To be continued...
PRO86 | STL | LuckyDog
Last edited by rice_classic; 06-16-2021 at 03:11 PM. Reason: UPDATE With current BUILD list as the car sits 2021
Old 01-16-2019, 10:47 AM   #2
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Looking forward to following this!
T4 seems like a great place to play with these cars. I've thought about starting to work on the suspension bits toward this. Can get most of it on these and still play in 86 Cup stock class for awhile.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 01-16-2019, 11:19 AM   #3
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
T-4 is my favorite class to spectate at SCCA events. There is great diversity in the class with a lot of interesting eligible models. It is also a showroom stock+ class which I really enjoy because the cars perform and race like God and the manufacturers intended them to.
I have yet to see a T-4 race where there were not several drivers, with various model cars, vying for the lead in the late stages of the race. I really look forward to your build and development on the FR-S for the class.
Subscribed!
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 01-16-2019, 12:47 PM   #4
eastendraceshop
eastendraceshop's Avatar
Drives: '13 Scion FR-S & '17 Toyota 86
Awesome!
Can't wait to see the cage!
eastendraceshop is offline   Reply With Quote
Old 01-17-2019, 01:04 AM   #5
rice_classic
The Cage
Local cage builder that's been around for decades - took great care. The bars are nice and tight to body and base plates are terrific.
He pushed me to remove the door metal and glass so the door bars could go right up the outer skin of the door but opted to leave the doors untouched. With that he did a great job designing door bars that snug to the body yet allow me to get in and out easily.
But first! let me start by saying that when I bought my car in 2012 I had a thing for Mentos. An already opened roll fell under my seat and several of the mentos made it under the carpet, when would go around corners fast I could hear them rolling around... Here we are almost 7 years later and I finally got to remove the buggers - and find some spare change too!.
IMG_0146 by Rice Classic, on Flickr
IMG_0220 by Rice Classic, on Flickr
IMG_0216 by Rice Classic, on Flickr
IMG_0214 by Rice Classic, on Flickr
IMG_0213 by Rice Classic, on Flickr
IMG_0221 by Rice Classic, on Flickr
I had stopped in while they were finishing it and I'm glad I did because we got to line up the seat and realized that the bar would too low for my liking where the seatbelts would mount. I hate having my selt belts are below the plain of my shoulders - they should be either straight back or even at an upward angle. This keeps pressure off my back and keeps my spine from getting compressed during an impact. So we added a bar for the belts.
IMG_0219 by Rice Classic, on Flickr
I test fit the seat with the Buddy Club low profile slider mounts and because that seat is pretty narrow I was able to get it A) quite low and B) centered. Happy with that result.
For the bumper strap - I have a penchant for easy buttons so I just purchased the Raceng Tow Shaft for my pimpy orange tow straps!
IMG_0229 by Rice Classic, on Flickr
Next up - Painting the interior/cage.
Old 01-18-2019, 01:37 PM   #6
Evan55
Drives: 06 Exige, 17 BRZ PP
Love this.
Subscribed.
Evan55 is offline   Reply With Quote
Old 01-18-2019, 04:53 PM   #7
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
You can definitely have a competitive car within your 15k budget. I guess you could say I am partial to the class.
Good luck and have fun!
-Oscar Jr.
Jackson Racing is offline   Reply With Quote
Old 01-18-2019, 05:22 PM   #8
rice_classic
-Oscar Jr.
You and I met at Pacific Raceways last year when you were up for the Majors. You gave me a lot of time which was greatly appreciated. I also picked up a few parts from your online store. In our local conference (ICSCC) we created a new class called "CT4" (Conference-T4) and we're expecting fields of 10-15 (or more) cars in CT4 at those events - should be fun.
My 2019 goal is to do the 2 Majors races in the NW (Portland and Seattle) and reset the T4 track records on my first outing. In my ITA car, my fastest times were within 1 second or less of the current T4 race records at both tracks - you being the current T4 record holder at Pacific Raceways....
...for now.
Old 01-19-2019, 02:34 PM   #9
Sgt.Gator
Drives: 2005 STI Race Car- 08 Spec B DD
Did you sell the CRX? Hopefully a local ICSCC racer if you did.
Sgt.Gator is offline   Reply With Quote
Old 01-21-2019, 02:29 PM   #10
rice_classic
CRX went to a LuckyDog team, very nice guys too and I get to drive it in their first Enduro which is exciting.
ITA stopped being a "growth" class in conference years ago despite my many efforts to revive it. Had some great seasons though. I see T4 being a growth class in both SCCA and now in Conference with CT4.
The Race schedule this year is a little odd and early-season heavy. Because of that, I'm going to miss the first couple Conference races because of the SCCA Majors. With 5 races in May alone, I have to prioritize. I plan on making the Spokane Triple though!
Old 01-21-2019, 02:45 PM   #11
rice_classic
prep prep prep prep then... PAINT!
Since I'm not doing any fancy wire tucks or anything I figured I'd just tape the wires, leave them in place and get the darn thing painted. The factory-matched paint turned out great!
I usually do a Single stage but this time I went Primer ->base coat ->clear coat, and it is fantastic. A friend of mine helped out after about 12 hours of prep and 5 hours of spraying it was as done as it was going to be.
IMG_0236 by Rice Classic, on Flickr
IMG_0235 by Rice Classic, on Flickr
PREP:
IMG_0262 by Rice Classic, on Flickr
IMG_0263 by Rice Classic, on Flickr
IMG_0265 by Rice Classic, on Flickr
IMG_0264 by Rice Classic, on Flickr
BASE COAT:
IMG_0266 by Rice Classic, on Flickr
IMG_0267 by Rice Classic, on Flickr
IMG_0268 by Rice Classic, on Flickr
CLEAR COAT:
IMG_0270 by Rice Classic, on Flickr
IMG_0271 by Rice Classic, on Flickr
IMG_0272 by Rice Classic, on Flickr
IMG_0273 by Rice Classic, on Flickr
IMG_0275 by Rice Classic, on Flickr
IMG_0276 by Rice Classic, on Flickr
I'm going to let it all call cure for a couple days. Then I'll take all of the masking off and start installing the dashboard, seat, belts etc.
On the 28th it goes to Toyota for the Valve Spring Recall so I won't have an update until it's back from them. After that though is when the fun begins. Oil cooler, Air ducts, brakes, suspension, header cat-delete, setup, ride-height and eventually tuning.
Feb and March are gonna be busy!
Old 01-27-2019, 11:18 PM   #12
rice_classic
Great googly moogly - the dash is back in, so is the seat and the belts. Holding off on the gauges and window nets until it's back from the dealer.
The seat is on the Buddy Club low profile slider brackets and they work well, a bit lower than stock on the lowest setting but I'm 6'0 and I'm happy with the height. However, they don't perfectly center the seat to the steering wheel, Im just left of center but once I'm moving I don't notice.
I racked my brain trying to figure why my headlights didn't work and then after someone said "check yur plugs" I found a plug under the dash that was disconnected and voila.. back in the saddle.
Now I'm fighting a P0500 code (left rear vehicle speed sensor code) and a seatbelt door chime that I will have to turn off via software. It may just be a bad sensor but I need to do some voltage/resistance test to find out.
Car goes into Toyota tomorrow morning for Valve Spring recall performed and then when it's back the real fun begins!! I hope the tech at the dealer is skinny because he's not getting in the car if he ain't - that seat is tight!!
IMG_0289 by Rice Classic, on Flickr
Old 01-27-2019, 11:24 PM   #13
Totemo_Hayai
Totemo_Hayai's Avatar
Drives: 2013 FRS
I hope my interior ends up looking that nice.
Is it possible to jump a connector to give the car's brain a signal that the seatbelt is in use?
Totemo_Hayai is offline   Reply With Quote
Old 01-28-2019, 04:44 PM   #14
skylinekin
skylinekin's Avatar
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
Awesome build, looking forward to following along!
skylinekin is offline   Reply With Quote
SCCA T4 Race Car Build - Suspension ccdrift Tracking / Autocross / HPDE / Drifting 10 11-11-2018 12:50 PM
Daryl Harr's FR-S SCCA Race Car Build driver71 Member's Car Journals 39 05-28-2016 04:50 PM
VADERR's Tie Fighter (C Street SCCA Build) VADERR Member's Car Journals 49 02-10-2016 12:31 PM
My SCCA National budget RTR build SeanRTR Tracking / Autocross / HPDE / Drifting 69 09-05-2014 12:49 PM
Bad Panda Motorsports - SCCA Solo STX BRZ Build BadPanda Member's Car Journals 7 06-13-2013 01:08 AM
