Old 09-23-2025, 12:49 PM   #1
WNDSRFR
Drives: FR-S,GTI
Does anybody use octane booster?
The price of gas around here is getting ridiculous. It used to be the difference in price between regular and premium was about 40 cents. Now it's more like 80 cents. And I've seen the difference at over a dollar a gallon. So, it costs over 10 dollars more to fill your tank with premium than regular and since we can't use regular, I thought it might make sense economically to mix regular gas with octane booster.
Any thoughts on this?
Old 09-23-2025, 01:03 PM   #2
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
Can work short term if you use a quality OB in modest quantities. Pretty much all commercially available octane boosters will leave residue in the engine and are not advised to use day-to-day.
If you need a boost at a HPDE that’s probably fine.
BlueWhelan is offline   Reply With Quote
Old 10-02-2025, 11:12 AM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
As Whelan said, additives are OK short term but they are not a bandaid and will cost you much more than just filling with the correct octane.
One of my tunes requires an additive called Boostane, and it turns my valves orange, who knows what else is coated in the strange leftovers.
Old 10-03-2025, 10:08 AM   #4
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
The only good octane boosters I'm aware of are products like VP racing octanium which is literal unleaded race fuel which physically raises octane by putting a higher octane fuel in.
Everything else I am aware of it a wash and I less specifically third party tested.
Old 10-04-2025, 08:04 AM   #5
WNDSRFR
Drives: FR-S,GTI
Anyone here old enough to remember Sunoco 260? Back in the day at Sunoco stations you could dial in the octane you wanted up to 260 octane. I think what they did was blend in tetraethyl lead at the pump. And it would cost less than a dollar a gallon. And they would wash your windshield, check your oil and give you free stuff. Those were the good old days.
Royal Purple Max Boost Octane Booster brillo Engine, Exhaust, Transmission 2 02-28-2014 07:12 PM
Octane Booster? Djen Forced Induction 12 11-05-2013 04:27 PM
Octane booster: 91 to 93 or higher? mike the snake Forced Induction 18 08-13-2013 08:54 PM
Octane booster... yeah, I know, I know.. silverbullet Engine, Exhaust, Transmission 10 05-07-2013 01:55 PM
Octane booster? SanDiegoFRS Off-Topic Lounge [WARNING: NO POLITICS] 5 02-17-2013 01:20 AM
