Old 09-15-2013, 11:21 AM   #1
Djen
Drives: GT86
Post Octane Booster?
using octane booster on our small engine car will harm the injector or engine ? dose it help the turbo gain more power? will use it often damage orings or rubber stuff?
Djen is offline   Reply With Quote
Old 09-15-2013, 11:24 AM   #2
Frs300
Frs300's Avatar
Drives: Pile of junk
there is a thread in here about it already and i posted a link to videos that showed almost all of them did nothing for power. there was one or 2 that showed a minor hp incrase.
EDIT: found the thread #5th post down think lucas was the one that showed hp increase others showed a loss in hp
http://www.ft86club.com/forums/showt...octane+booster
Frs300 is offline   Reply With Quote
Old 09-15-2013, 11:41 AM   #3
sw20kosh
Drives: 2013 Black FR-S
The only one that works for me and is recommended by my tuner is Torco Accelerator Fuel additive. It itself is not a fuel. It is a additive that adds MMT which is a knock suppressant. I run it at the track to keep things happy and safe.
Don't bother with typical autozone "octane boosters".
Old 09-15-2013, 02:00 PM   #4
PineappleFriedRice
Truuu
PineappleFriedRice's Avatar
Drives: 2013 FRS, 88 EF Civic, 05 Matrix
Yea torco does work. Its concentrated race fuel you mix with your pump gas to boost the octane.
GARRET .60 TRIM-UEL HEADERS-1150cc INJECTORS-DW FUEL PUMP-RACESENG CAM PLATE-PERRIN 3" CATBACK-ULTIMATE RACING 2.75 OP/FP-FBM CATCHCAN-SINGER 275AMP ALTERNATOR-MEGAN TRACK COILS-MEGAN F/R STRUTBARS-AXLE EXCHANGE ALUMINUM DRIVESHAFT-ACT 6 PUCK-ANARCHY MOTIVE SHIFTKNOB-XXR 535-HANKOOK VENTUS EVO V2-CS LIP KIT
Build Thread - FA20FAIL Archive
PineappleFriedRice is offline   Reply With Quote
Old 09-15-2013, 05:04 PM   #5
Djen
Drives: GT86
thanks all for feedbacks
Old 11-05-2013, 02:23 PM   #6
Noob4Life
86 Noob
Drives: Firestorm FR-S
Hate to bump an old thread but didn't want to start a new one, I was thinkink about running octane boost ever fillup since I'm stuck in CA with the closest e85 station 40 miles away. If I decide to run 32oz of the torco every fillup it'd boost my octane to around 100 according to the graph. (Since our tanks are only 13 gals) I'm getting my car tuned next week and he said for safety if I wanted to run octane booster I should tune for 91 so the car isn't reliant on it. If I tune for 91 and run the torco would the ecu be able to calibrate for it? Or would I need to tune for around 100 oct? Thanks for any help, BTW going to be doing a road tune with BRZEdit. Car is still NA.
Noob4Life is offline   Reply With Quote
Old 11-05-2013, 02:46 PM   #7
frslee
Just drive it
Drives: 13' FR-S
+1 Torco!! I used to run my A4 100 Octane all day.
frslee is offline   Reply With Quote
Old 11-05-2013, 02:49 PM   #8
frslee
Just drive it
Drives: 13' FR-S
I'm sure tuner guys can help more here, but here is what I can share.
If you're tuned with 91 but your tank has 100 octane, your car will not perform fully using 100 octane. It'll still look for 91 octane, since it's tuned that way. Ask the tuner if he can give you 2 different maps; 91 and 100. You can run 91 on a regular day and swap it to 100 if you decide to use torco additive. However, never run 100 octane file with 91 fuel! Make sure your tank is filled properly before you change maps.
Old 11-05-2013, 02:54 PM   #9
Noob4Life
86 Noob
Will I still feel a difference running 100 on an 91 tune? (I've been reading that the top end is alot better on higher grade fuels) Just not as much as if I were tuned for it? Didn't think about running 2 tunes, I'll have to ask him about that when I head up. Thanks!
Old 11-05-2013, 02:56 PM   #10
frslee
Just drive it
Drives: 13' FR-S
You should feel better, but you won't see the full potential that way. It's like running 93 on a corolla. However since this is a forced induction application, the car will be more sensitive.
Old 11-05-2013, 03:04 PM   #11
Noob4Life
86 Noob
Not forced induction yet just NA with full bolt ons lol thanks again for your help. Just trying to do what I can to get that 200whp NA until I get my SC
Sent from my SAMSUNG-SM-N900A using Tapatalk
Old 11-05-2013, 03:47 PM   #12
wlfpck
Drives: 2015 GTI
Power is lost when using lower octane fuels due to the ECU adjusting to compensate.
[ame="http://en.wikipedia.org/wiki/Octane_rating"]Octane rating - Wikipedia, the free encyclopedia[/ame]
You're not increasing the hydrocarbon content or oxygen content with a higher octane fuel.
E85 vs fuel is a whole new issue as they do have different contents.
When you have a high compression build or forced induction, the ecu will retard the timing. (Sentence in the article explains the knock sensors).
The whole point is, if you're going to get 93 octane gas and boost it up to 100 octane through octane booster, you're not really going to see any improvements if your tune is meant for 93. If your tune is meant for 100 octane, then yes. There will be a HUGE difference as it will run it's tune for 100 at 100 octane and when the ECU senses a lot of knocking, it will retard the timing to what is adequate for 93 octane.
2013 GTI - Gone
2015 GTI
wlfpck is offline   Reply With Quote
Old 11-05-2013, 04:27 PM   #13
Noob4Life
86 Noob
Thinking I'll just head up with 100 Oct fuel and have him tune it on that then lol thanks for the help all, I don't mind paying 114 for a case of torco, 6 bottles should last me 2 - 3 months based on how I drive. Thanks guys!
Octane booster: 91 to 93 or higher? mike the snake Forced Induction 18 08-13-2013 08:54 PM
Octane booster... yeah, I know, I know.. silverbullet Engine, Exhaust, Transmission 10 05-07-2013 01:55 PM
Octane booster? SanDiegoFRS Off-Topic Lounge [WARNING: NO POLITICS] 5 02-17-2013 01:20 AM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 01:23 AM
Anyone tried the Sprint Booster? Black Tire Engine, Exhaust, Transmission 6 01-27-2013 04:13 PM
