Old 07-31-2025, 10:15 AM   #1
smackrel
Full Throttle!
Drives: 17 CBSP Limited PP
What is this noise?
After I turn the car off, when I open the door there is a noise that happens in the instrument cluster area. It almost sounds like a motor moving something?
Can someone please tell me what this is?
smackrel is offline   Reply With Quote
Old 07-31-2025, 10:24 AM   #2
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
A recording would be helpful.
Old 08-02-2025, 12:07 AM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I put my ear to the screen but all I heard was Chris Harris and Max Verstappen
blsfrs (08-02-2025)
Old 08-02-2025, 11:43 AM   #4
whataboutbob
AutoX-10/10ths every run
Is it the window in the door moving down to allow the door to open?
Build thread:Here
The Following 2 Users Say Thank You to whataboutbob For This Useful Post:
blsfrs (08-03-2025), The Red One (08-07-2025)
Old 08-02-2025, 03:14 PM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I'm betting the the window. Watch your driver's side window when you open and close the door. The top of it
blsfrs (08-03-2025)
Old 08-05-2025, 01:59 PM   #6
smackrel
Full Throttle!
Just went out and double checked it. It is not the window. It happens with the window cracked when opening the door engine off, but also at start up, right before the engine cranks.
It sounds like a small electric motor moving something. Took a couple videos on phone, will try to upload. Posting from work PC.
The Following 2 Users Say Thank You to smackrel For This Useful Post:
DarkPira7e (08-11-2025), whataboutbob (08-06-2025)
Old 08-05-2025, 04:03 PM   #7
smackrel
Full Throttle!
https://imgur.com/a/FNfOuNK
Hopefully that will work…
Old 08-05-2025, 10:49 PM   #8
Compelica
Compelica's Avatar
Drives: 86 GT
I know which sound you are referring - it's akin to a whirring sound that lasts slightly more than half a second.
Definitely not the window, but rather difficult to pinpoint the exact location.
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 08-06-2025, 01:58 PM   #9
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
It's the throttle valve resetting. It's a fly by wire system and it rehomes itself when the key is turned on or off. Or it could be the fuel pump building pressure. Unless it's something different...
sly is offline   Reply With Quote
Old 08-07-2025, 09:21 AM   #10
smackrel
Full Throttle!
I could see either when it does it at start up, but not when the door is opened after shutdown.
Hard to tell in the videos, but it makes the noise both times.
Old 08-07-2025, 09:24 AM   #11
sly
sly's Avatar
My car does the same thing. I have the push button start and when you shut off the engine, some accessories are still powered on until you open the door. Now that I hear it again, it could be the CD player resetting. The stereo stays energized until you open the door.
Road noise? Tread Noise? zERoTu Issues | Warranty | Recalls / TSB 21 10-07-2020 10:21 PM
Wind/road noise at highway speeds? Kieranz BRZ First-Gen (2012+) — General Topics 20 06-13-2013 10:11 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Strange noise Random_Art Other Vehicles & General Automotive Discussions 15 06-03-2011 03:31 PM
