Old 08-24-2016, 03:06 PM   #43
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Originally Posted by Yoshoobaroo View Post
Reading through amazon reviews I found one claiming this bar induced a lot of body roll and understeer. A front strut bar should decrease both roll and understeer while not increasing oversteer though, so I'm confused.
Anyone here notice worse body roll and understeer?
I think there is confusion between "sway bar" and "strut brace/bar"...
Sleepless is offline   Reply With Quote
The Following User Says Thank You to Sleepless For This Useful Post:
Yoshoobaroo (08-24-2016)
Old 11-22-2017, 08:17 PM   #44
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Originally Posted by MeehowsBRZ View Post
You can try wrapping the ac line in mesh and zip tying it. (I got that from reading the Grimmspeed strut bar installation thread)
Also, I'm surprised this one is so cheap. It looks real good.
I'm looking at buying this hotchkis strut and I want to protect that AC line from rubbing, do you or anyone else know where to buy some sort of mesh or hose protector to keep that AC line from any rubbing damage?
sorry about replying on such an old thread but I finally can afford the strut and I've been wondering how to protect that AC line and what to use.
DandoX is offline   Reply With Quote
Old 11-22-2017, 08:32 PM   #45
new2subaru
Weight Weenie
Drives: 15 FR-S
Search for loom
http://www.ebay.com/bhp/wire-loom
The Following User Says Thank You to new2subaru For This Useful Post:
DandoX (11-22-2017)
Old 01-02-2018, 03:11 PM   #46
Brink
Drives: 2017 BRZ
Does the Hotchkis bar come with torque specs for everything, or where can I find that? Also for the install is it ok if the car is on a slight slope front to back? My driveway should be level left/right, but slopes down slightly towards the street. Otherwise I guess I could just do the install in the parking lot at work, easy enough to bring the needed tools along.
Brink is offline   Reply With Quote
Old 01-02-2018, 03:34 PM   #47
DandoX
Senior gif poster
DandoX's Avatar
Yeah it comes with some info about the torques although I just roughly hand tightened to around the same tightness the bolts where before I took them off. I did mine on a driveway with the front facing up slightly and it was fine, I did have to kind of force one part on a little which scratched up one of the bolts some. I would recommend doing it on a flat surface or drive onto a small ramp or piece of wood under one wheel so it fits on really nicely.
Also mine came with a plastic cut tube and zip ties to protect the AC line from rubbing against the strut bar.
The Following User Says Thank You to DandoX For This Useful Post:
Brink (01-02-2018)
Old 03-06-2018, 04:57 AM   #48
HSUBLU
Drives: 2017 BRZ WR Blue
I love the build quality on the one I got. Just finished installing it, and the tolerances are a bit tight. One of the diagonal arms didn’t settle on the exposed bolt near the firewall correctly. A very light tap with a mallet settles it and I was able to easily get the nuts all back on. The instructions say 12 ftlbs for everything but the strut bolt, which should be at 17.
Like with DandoX, mine came with a length of clear plastic tubing that’s cut along one length that you can open up and wrap around the portion of AC tuning that contacts the bar. Zip ties included to secure the clear tube on the AC tube.
HSUBLU is offline   Reply With Quote
The Following User Says Thank You to HSUBLU For This Useful Post:
Lakitu (07-06-2018)
Old 07-25-2025, 09:02 AM   #49
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
This is a longshot but if anyone has the Hotchkis Strut bar for sale ill buy. Tried posting in the WTB section. These are discontinued so hard to find. I prefer this over the AEM this is significantly lighter
SuperTom is offline   Reply With Quote
Old 07-28-2025, 03:59 PM   #50
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
This place lists them "In Stock":
https://86speed.com/20445-hotchkis-s...lx-zZyUJlpIYra
Whatever main company owns all these smaller websites that have the exact same format.
cmiovino is offline   Reply With Quote
Old 07-28-2025, 07:31 PM   #51
SuperTom
SuperTom's Avatar
When you click buy it says sorry not available tried all the umbrella sites similiar to 86speed. They dont update site. Tried 2 smaller sites that showed as well no luck. Also reached out to hotchkis to see if they held a few back, they basically told me keep trying around
My Strut Brace Mod... Andrew666 AUSTRALIA 4 03-04-2013 11:38 PM
FS: [VIC] *NEW* Cusco Front Strut Brace w/ Brake Cylinder Stopper green_comet Australia Classifieds 1 12-11-2012 11:10 PM
DIY - Strut Tower Brace - FT-86 SpeedFactory F1point4 DIY (Do-It-Yourself) Guides 4 10-28-2012 05:30 PM
Which Rear Strut Brace? 86_ZN6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-21-2012 11:01 AM
