Old 06-04-2013, 09:19 PM   #29
Hotchkis
Hotchkis's Avatar
Originally Posted by OICU812 View Post
Hotchkis bar..
So I got this, easy enough to place in. Without even driving yet went to take off due to my master cylinder brace came in. Long story short what's the trick to removing? Pulled every which way like a mad gorilla and seems the two points where it bolts to the strut studs is literally wedged onto those bolts??
I installed the master cylinder brace obviously without removing the hotchkis strut tower brace but... I can see more cursing the day I actually need to remove this brace...
That AEM with incorporated brace looks "simpler" Ahhh well seems my patience is my enemy sometimes ...
Hi OICU812,
The strut tower brace should remove just as easy as is installing. Is the vehicle on level ground?
regards,
-Aaron
Hotchkis is offline   Reply With Quote
Old 06-05-2013, 01:38 AM   #30
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Originally Posted by Hotchkis View Post
Hi OICU812,
regards,
-Aaron
Yes of course level etc... Don't really get it. Not in panic to remove it just found it odd. Just hopefully when I do need to that it won't be too big of a fight lol.
Old 04-01-2014, 01:07 PM   #31
JDogg
JDogg's Avatar
Drives: 2013 Black Scion FR-S
Could someone measure the clearance from the top of the intake manifold to the brace?
JDogg is offline   Reply With Quote
Old 04-08-2014, 09:28 PM   #32
MeehowsBRZ
Drives: BRZ 6MT
That damned AC line is in the worst spot, over time has anyone seen some of the hose externally rub away? Wish it was as easy as an unbolt and over, but with the Hotchkis design is there enough slack to go over and under the bar anyhow??
You can try wrapping the ac line in mesh and zip tying it. (I got that from reading the Grimmspeed strut bar installation thread)
Also, I'm surprised this one is so cheap. It looks real good.
MeehowsBRZ is offline   Reply With Quote
Old 01-03-2015, 03:42 PM   #33
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Question
I found a great price on Amazon 41% off @ $147.26
[ame="http://www.amazon.com/Hotchkis-20445-Strut-Tower-Brace/dp/B009P4KRNW/ref=sr_1_9?ie=UTF8&qid=1420313377&sr=8-9&keywords=hotchkis+brace"]Amazon.com: Hotchkis 20445 Strut Tower Brace for Scion FR-S: Automotive[/ame]
Anyone have issues with the holes not lining up? This is according to the reviews.
Chad86 is offline   Reply With Quote
Old 01-03-2015, 03:52 PM   #34
wootwoot
Drives: FRS
Can anyone do this real quick? Wanting to know if it fits with crawford power blocks installed....
Old 01-03-2015, 06:28 PM   #35
Liquid6
Liquid6's Avatar
Drives: 2014 FR-S
probably not. i think theres like 3/4"-1" clearance
Liquid6 is offline   Reply With Quote
Old 01-04-2015, 01:37 PM   #36
wootwoot
Drives: FRS
The AEM unit fits with the blocks, but just barley. I would prefer to have the hotchkis.....
Can anyone grab a tape measure and check?
Old 01-04-2015, 03:22 PM   #37
Gunman
Drives: 2019 Mazda Miata RF
1/4" maybe 3/8" to the cover (with Subaru/Toyota). Not sure how much you gain by removing that cover.
Old 01-04-2015, 03:26 PM   #38
wootwoot
Drives: FRS
Cool. Thanks.
Won't fit then. Need nearly 1.5".
Old 01-10-2015, 01:00 AM   #39
Hiros86
Hiros86's Avatar
Drives: whiteout FR-S
@NickFRS that was my first upgrade, I noticed a difference right away it felt more planted.
Hiros86 is offline   Reply With Quote
Old 08-23-2016, 09:54 PM   #40
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Reading through amazon reviews I found one claiming this bar induced a lot of body roll and understeer. A front strut bar should decrease both roll and understeer while not increasing oversteer though, so I'm confused.
Anyone here notice worse body roll and understeer?
Old 08-23-2016, 10:36 PM   #41
Gunman
No
The Following User Says Thank You to Gunman For This Useful Post:
Yoshoobaroo (08-23-2016)
Old 08-23-2016, 11:16 PM   #42
Spectre20
Spectre20's Avatar
Drives: 2013 BRZ Limited
None whatsoever. What a silly review.
Spectre20 is offline   Reply With Quote
The Following User Says Thank You to Spectre20 For This Useful Post:
My Strut Brace Mod... Andrew666 AUSTRALIA 4 03-04-2013 11:38 PM
FS: [VIC] *NEW* Cusco Front Strut Brace w/ Brake Cylinder Stopper green_comet Australia Classifieds 1 12-11-2012 11:10 PM
DIY - Strut Tower Brace - FT-86 SpeedFactory F1point4 DIY (Do-It-Yourself) Guides 4 10-28-2012 05:30 PM
Which Rear Strut Brace? 86_ZN6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-21-2012 11:01 AM
